I created some kind of a UI chart for the SP33 V2.0 (XHP50.2)
A few more notes.
You can go from Eco mode to Turbo.
Double click from Turbo activates dual frequency Strobe.
From Strobe, a dbl clk goes back to Turbo. A single click goes back to last used mode.
That will complicate your diagram.
Thank you Jason! I will be glad to complete my chart.
And yes, it will be challenging to find some space for the missing parts of the UI.
Hello my dear friend!
Banggood is selling their stock of the
Product Description:
Package included:
1 x Flashlight
1 x O rings
1 x Stainless Steel clip
1 x Landyard
1 x Gift box
use my CODE: BGFIRE to get the discount!
XPL NW 4000K/5000K only US$ 49.90 ($83)
XPL CW 6500K only US$ 49.90 ($83)
Nichia 219B R9080 CRI98 US$ 49.90 ($73)
Fireflies E07 with XPL-Hi @ $49.90 would be a really good price… but I notice BG does not have stock at the moment…
Desert Yellow with XPL NW 4000K is still available.
“Only 1 pcs left” so better be quick
seems the last have been sold...
Ordered the silver SST-20 95CRI version. Thanks!
Hello my dear friends!
Members know: here are 2 new deals for you!
(the links in the pictures take you to the shop for more information)
some of Wubens Ads:
and the:
Features:
[1] By default the MT09R is set to use the very intuitive Narsil smooth RAMPING UI. Instant access to TURBO mode is also provided.
[2] A more conventional discrete level MODE-SET UI is available as an alternative. Any one of 12 predefined mode-sets can be selected.
[3] MOMENTARY mode is useful for signaling purposes or rapidly/briefly lighting up targets.
Package included:
1 x Haikelite MT09R XHP70.2 3 x LEDs 25000LM LED Flashlight
1 x Screw
1 x O-ring
1 x Lanyard
veröffentlicht am 29. March 2019 in Allgemein, banggood, EDC, flashlights von m4d m4x
A real monster flashlight and result of a flashaholics project is ON STOCK and sold for a nice price!
(valid only 10 days!)
my Code: BGQ8 my price: US$ 44.99
(MRSP: ~$80)
Specification:
Product name: | BLF Q8 4X XP-L 5000LM Professional Super Bright LED Flashlight |
Brand: | BLF |
Model: | Q8 |
Emitter Type: | XP-L HD V6 3D |
Light temperature: | 4750K-5000K |
Light color: | Neutral White |
Mode: | Smooth ramping or mode set operation |
Material: | Aerospace grade aluminum alloy construction |
Total Emitters: | 4x |
Battery Configurations: | 4 x 18650 or unprotected button top (not included) |
Working Voltage: | 3-4.2v |
Switch Type: | Electronic switch |
Switch Location: | Body side of the flashlight |
Peak Beam Intensity: | 30000cd |
Impact Resistant | 1.2meters |
Max Output: | 5000+ lumens |
Range: | 450+ meters (max) |
Lens: | High transmittance glass |
Reflector: | Aluminum alloy mirror reflective cup |
Waterproof: | IPX-8 waterproof |
Color: | Black |
Weight: | 400g without battery |
Size: | 132mm x 59mm x 50mm(length x head x body diameter) |
Features:
• Compact and lightweight 4500 Lumens flashlight
• Utilizes four XP-L LEDs
• Uses four 18650 batteries for maximum runtime up to 1500hours
• Features advanced temperature regulation (ATR) technology
• Integrated power indicator in side switch indicates remaining battery power
• Flashlight can blink out voltage with 0.1V accuracy
• Intelligent memory function for brightness levels
• Direct access to ultralow and turbo outputs
• High transmittance glass
• Stainless steel bezel ring protects core components from damage
• Constructed from aerospace grade aluminum alloy
• HAIII military grade hard-anodized
• Waterproof in accordance with IPX-8
• Tail stand capability
Mode,Lumens and runtime:
Mode Groups: | Runtime and Lumens (manufacturer tested,it will be a little bit different from the real data ) | |||||||
Group1: | Moon 2LM/1500h | Turbo 5000LM/40min |
Group2: | Moon 2LM/1500h | Low 160LM/33h | Turbo 5000LM/40min |
Group3: | Moon 2LM/1500h | Low 70LM/66h | Mid 1250LM/8h | Turbo 5000LM/40min |
Group4: | Moon 2LM/1500h | Ultralow 10LM/150h | Low 160LM/33h | Mid 1500LM/6h | Turbo 5000LM40min |
Group5: | Moon 2LM/1500h | Ultralow 10LM/150h | Low1 70LM/66h | Low2 160LM/33h | Mid 1500LM/6h | Turbo 5000LM/40min |
Group6: | Moon 2LM/1500h | Ultralow 5LM/150h | Low 70LM/33h | Mid1 240LM/17h | Mid2 1100LM/10h | High 2500LM/3h | Turbo 5000LM/40min |
Group7: | Moon 2LM/1500h | Ultralow1 10LM/400h | Ultralow2 35LM/140h | Ultralow3 95LM/54h | Low1 160LM/33h | Mid 1350LM/8h | High 2500LM/3h | Turbo 5000LM40min |
Group8: | Moon 2LM/1500h | Low 160LM/33h | Mid 750LM/17h | High 2100LM/5h |
Group9: | Moon 2LM/1500h | Ultralow 10LM/150h | Mid 520LM/20h | Turbo 5000LM/40min |
Group10: | Moon 2LM/1500h | Ultralow 10LM/150h | Mid 1500LM/6h | Turbo 5000LM/40min |
Group11: | Moon 2LM/1500h | Low 160LM/33h | Mid 1350LM/8h | Turbo 5000LM/40min |
Group12: | Moon 2LM/1500h | Ultralow 5LM/600h | Low 150LM/33h | Mid 1700LM/5.5h | Turbo 5000LM/40min |
Package included:
1 x BLF Q8 4X XP-L 5000LM Professional Super Bright LED Flashlight
2 x Flashlight Body Tube O-ring
1 x Flashlight Head Lens O-ring
1 x Switch cover
1 x English Manual
Note:
Before ordering please make sure that you know how to operate the flashlight.
How to use the UI: bit.ly/narsilinfo
For the safety to the battery: bit.ly/lionsafety
For more information to see: bit.ly/blfq8
Product review from BLF Forum:https://budgetlightforum.com/t/-/39069
today i present the all new
use my Code: MSP70 to get the discount
the following deals can be found here: M4D M4X deals
(the codes will work as soon as they are ready to buy)
Here is the thread on the SP70 if anyone has questions.
(Note: Most questions have already been asked so try searching first).
Looks like a Lego host….still going to buy one.
Hello my friend!
here are some new deals i got from banggood:
Members should remember to double check if there are betterd deals for them! M4D M4X deals
Any chance on getting the UT210E on discount again? I think the prior coupon brought it to $29…even lower would be better.
Hello Martin,
Any chance to get a nice code for the new Klarus 360T1 tail switch?
Thank you!
Cheers,
Thomas
A well known and good built Sofirn light was enhanced with the Anduril User Interface (by toykeeper) and the beautiful Samsung LH351D LEDs
from today the presale is open!
(links in the pictures and text bring you to the shop)
Features:
Package Included:
1 x Sofirn SP36 BLF Anduril Flashlight
1 x Spare Waterproof O Ring
1 x User Manual
for more detailed information about the light and UI please visit the shop
in my deals list you find the updated deals for:
