I’d like to use battery holders because I have them, and it would seem easier for me to pop them out and throw them in my charger. The holders I have are the ones that the cells snap in, with metal tabs not springs. My thoughts were to mount the holders 4 a side on a custom milled circuit board, then just have something like an XT60 connector at one end to plug into.
Would like to just buy a 10S LiPo but then I’d have to buy a charger as well as my charger will only do 2S or 3S.
I have two HyperBoosts. As of yet untested. But I like that a 50k pot can be wired directly to it for dimming - which is an important feature for me. I don’t need full tilt all the time, but it’s good to have.
I think if I can get my hands on an extension tube for my Convoy L6, I’m going to put a Vero29 in it. I’ll have to cut down a Lenina to fit in the head but it would be brighter than any other L6, probably cheaper than my 21x LH351D concept and more unique.
I take it back. Olivia won’t fit and the holder for the V22 is the same size as a Vero29 so there is no advantage there.
Looks like the best option is to turn down the Lenina to fit. The bad news is that the whole thing will probably easily overheat, it probably needs a copper tapered plug for the COB and assembly will be a royal pain.
Then again, if it was easy, it wouldn’t be any fun.
I just got a batch of CAD models from LEDiL and the Vero29//Lenina adapter won’t fit in the L6. The only option I’m seeing would be to modify the mount and then glue or tape it directly to the Vero29. However, it would also block the screws I was planning to use to mount everything into the light. I suppose I could drill hex driver access holes in the plate and then the screws would be captured….
I think I can make it work if I can remove the plastic bits of the Vero29 from the actual COB assembly… or just use a CXB3590 and machine my own adapter for the Lenina.
I don’t think I actually need the mounting lugs… just a tight press fit boss similar to what the LEDiL adapter plates actually have in the Lena series.
I cant work out to post photos but i used the L6 reflector with cmt 2850 and taskled HBflex in a scratch build. But it fried the driver, i think the shelf was too thin and ambient heat got it. Happened twice and now im waiting for more drivers. I will redo it with copper inserts for the led and driver i will also put them back to back with a gap in between so the copper protects the driver from the led.
Would like to see it. Easiest way is to upload your photos to imgur and copy the url to the box when you click on the add photo box above the comments box.
As I said earlier, my evil plan involves a tapered copper “shelf” for the COB and the HyperBoost will be mounted to the back of the shelf with thermal tape.
