It was a 4000K 90CRI LH351D from led4power. I have had that led from the first AEDe group buy too and I did not notice a different tint between the AEDe and led4power version, (which was an impression, I could not actually measure tints at the time).
I sliced that led before, and mind that slicing costs about 20% output.
So are those slots too narrow for 2mm? I was thinking if it can take those, just boring out a little at both ends to get it up to 10.5 mm (a little room for adhesive buffer) would work. But if not, it would require some special apparatus to bore out a wider straight line across the whole slot.
Hi Clemence, are you still planning on making something high cri available with this light? I’m holding off on buying one as I’m not modding savey and wouldn’t be happy with the stock led. Thanks in advance!
Having fiddled with different leds in the RRT01 yesterday, I’m not sure if this flashlight is happy with small leds like the E21A. If it really drives them at over 3A that is over the max for this led, that has its sweetspot at 2A in my opinion. Further, it seems that the smaller the led, the larger beam artifacts become (sharper rings in the spill, uneven hotspot), this light could then do with a OP reflector instead of smooth.
Thanks! You did a great job. I have a Dremel and some bits that can cut metal, but I don’t have an apparatus for ensuring a straight line. I think I’d likely go the route that Gunga took, to use 1.5 mm. I’m not sure there’s a 1.5 x 6 mm out there, but if so it would be interesting to combine the two. Since there would be a definite delineation between the 2 vials, would be an opportunity to do alternating colors within same line.
I always found the RRT01’s low-mode efficiency a little disappointing. It does the lowest levels I’ve seen on any flashlight, but its power use is unusually high. If I recall correctly, 9.7 mA is enough to run my D4 at, um… well, I suppose I should just measure it to find out. … 2.8 lumens. And at the lowest mode (~0.2 lm), it’s only 1.7 mA.
So with an 1150 mAh 18350 cell, the maximum runtime on those two is about 5 days vs 28 days.
Agreed. The light could really benefit from one. I had some TIR’s from Convoy’s Ali store. They are bit too small in diameter and a not quite tall enough. I made one work but it’s not an ideal fit. A friend found some TIR’s that are a few mm’s bigger in diameter and height. I will see how they fit when they get here. For now DCFix has made it quite enjoyable but am looking forward to trying the larger TIR’s.
I agree that the beam on the RRT-01 is ringy, when Im using N219b
the reflector sucks…
My bet is that Clemence will build a centered group of Four E21a, so the excess power issue will be solved
And I bet he comes up with a TIR that makes a perfect beam…
Regarding the trit slots issue with the new RRT-01… one option is to just use Two 1.5x5, and as xevious suggested, use that as an opportunity to mount 2 colors per slot
about clips:
Im seeking one of these short clips, if anyone has one available please PM me
or if you know a source for them, please share
This is the difference:
the long one comes on the present version of the RRT-01, and one of the earlier models,
the second run of the earlier model had the short clip, as pictured on my RRT-01 above, and on the Eye10 TiC
btw, Eye10 TiC does NOT fit my Keepower 1200mAh, that works fine in my RRT-01
Congratulations! That is a grail light.
nitpick:
The TCR-1 comes with a long clip… it interferes with the rotary ring… not acceptable to my snobby self:
The 2mm wide trit vials fit fine, no grinding, I measured around 2.25mm I think factory opening. Its the length of the 2x12mm trit vial that’s too long. I ground the ends a little to fit and went ahead and ground all the way down the slot to expose the bare aluminum, I was hoping this might help the trit illumination reflect back up and out, instead of just hitting the black anodizing. The ends are the only thing that needs ground if using a 2x12mm vial.
Great to know you didn’t have to bore out the width any further. So it’s not just width but also depth that’s sufficient to fit the 2mm wide vial while still remaining below surface? I agree exposing the bare aluminum might actually help just a little with reflecting the tritium light.
1.5mm cutting diameter 4 flute 5mm flute depth with a 3mm shank ball nose. I don’t use dremel stuff because their not as good as of a bit or end mill made for a actual mill. I have a mill so this works for both purpose for me. These last for a very long time, carbide is good stuff. I have had this one since this project here.
I just found more info in that thread. Those pics contain the part number and show the actual bit, the one in the link above doesn’t show a actual pic. You really wouldn’t have to have a ball nose just a 4 flute end mill with the dimensions above.
