Emisar D18 introduction
914 posts / 0 new
DB Custom
DB Custom's picture
Last seen: 8 hours 1 min ago
No maybe about it, lightning mode at high output is definitely fun! Big Smile 26,000 lumens especially! lol
mattadores
mattadores's picture
Last seen: 2 days 7 hours ago
What Anduril light has 26k lumens? Shocked
Or is it a Dale custom? Tired
Agro
Last seen: 5 hours 13 min ago
ToyKeeper wrote:
Easyrr wrote:
The fw can blink out the revision, right?
No, I never added anything like that. It’s not as simple as it might seem. Version numbers are complicated. For example, a program on my computer has version number “2.1.5+deb1+cvs20081104-13.2”. It’s not even a big program. That’s the version number for “eject”, and all it does is eject and retract the tray on optical drives.
Basically, to serve useful purposes, it’d have to be pretty long… like maybe one of the following:
  • Checksum of the source code (plus a big reference table somewhere to look up what it means)
  • Build date plus branch name and build target ID
  • Branch name and revno (like 188.1.213) plus something to indicate which build it was
  • Some sort of long and manually-updated version number which throws an error if not specified.
None of this is easy to communicate to a human by simply blinking a pixel on and off.
To be useful, the number would need enough detail to answer common questions. For example, is this the full-power build or the reduced-power 219C version? How old is it? Which repository version was this based on? Does it have bugfix X or feature Y? Is it part of the main repository or was it made from a different branch? Who built it? Does it match an actual repository version at all, or was it cowboyed without checking in the changes?
Tom tried to do a simple version number scheme with Narsil and NarsilM, and it worked okay at first when there was only one person making builds and only a couple of commercial lights using it… but it got messy pretty quickly when there were more people and more products involved. There are now a bunch of different versions all called “1.3”, but they’re all different and most don’t have the improvements Tom put in the official 1.3. People took earlier versions and bumped the number, which ended up being misleading in terms of how the code behaves.
So, long story short… no. I haven’t even tried to bake in a version number. It’s complicated, and I’m not sure it would even be a net gain.
I know it’s a complex solution but if one was really determined, a machine-readable blink-out would work.
I mean: do the same thing as optical programming but in reverse. Now it’s flashlight blinking out some binary code and a smartphone app receiving it.
JasonWW
JasonWW's picture
Last seen: 1 hour 59 sec ago
Probably HAM’R.
AEDe
AEDe's picture
Last seen: 8 hours 50 min ago
ToyKeeper wrote:
I assume this was due to poor calibration on the M43, because that is a known issue with the attiny85 chip and the M43 has no function to work around that issue.
M43 has calibration function 14fast click and hold. Temperature should be 25C.
ToyKeeper
ToyKeeper's picture
Last seen: 11 min 50 sec ago
Interesting. Thanks! That’s not in the manual. It only goes up to “12 Fast Clicks & Hold”.
Do you know of any other undocumented functions in the M43?
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 6 hours 54 min ago
Sorry for asking a dumb question but what does “Temperature should be 25C” actually mean? Does that mean I need to make sure that ambient temperature around the (cold?) flashlight is 25°C before I click 14 times and hold?
mattadores
Probably “HAM’R.”:http://budgetlightforum.com/node/63717
Just checked out HAM’R…
DB Custom
DB Custom's picture
LP, he’s saying the base setting should be 25C…I think. I found the M43 UI too confusing so I pulled it, stripped the driver, and piggybacked in an FET driver. I have Anduril in my M43 now too. And a Master/ 3 Slave configuration if I remember right. It gets really really REALLY hot in Turbo, way fast! 12 Samsung emitters will do that in this small of a light.
DB Custom
DB Custom's picture
Thanks Matt, it was one of those wild hair moments. Big Smile (unfulfilled due to the lack of the extension tubes Sofirn quit on)
Anduril works fine in Ham’r because the drivers are separated from the heat source by a significant amount of aluminum. By filling the head of the light with the base of the finned addition there is a LOT of mass underneath the emitters. My M43 has the drivers virtually up against the bottom of a comparatively thin emitter shelf, as such it floods heat into the Master driver in a very quick manner and Anduril isn’t set up for this… too much too fast by a wide margin so the thermal issues arise in the driver. Again though, in the even more powerful Ham’r it’s simply not a problem.
mattadores
lol… I found some behind the scenes footage from Dales HAM’R build!
Maybe this is a similar issue to what TA is experiencing trying to get Anduril to function on the MF01S?
mattadores
JasonWW wrote:
Firelight2 wrote:
JasonWW wrote:
(I don’t have any Emisar lights)
Gasp! You poor soul you!!! Emisar makes fantastic lights! No flashaholic’s collection is complete without some. Shocked
I’m not a flashaholic. Shocked
You’re an active member on BLF…
You’re well informed and have some pretty in depth knowledge from what I can see…
Yet you’re able to resist buying every amazing new flashlight that comes around!?
Tom Tom
mattadores wrote:
Nevertheless, you also provided some great resources for my drivers 101 course which I’m excited to dig into! Thanks for the help!
Here’s a link exploring some commercial buck and boost drivers, tests and modifications:
http://budgetlightforum.com/node/54900
AEDe
AEDe's picture
I send you link to extended manual.
It means that temperature of flashlight body should be 25C. After 14 times and hold light blink twice and button blink green – calibration is done.
if light blink once and button blink red than calibration failled due to large(>16C) difference between temperature of light and estimated temperature by m43.
The consequence of this procedure that you can adjast “50C” stepdown in some range .e.g. if you calibrate M43 at 20C stepdown would be at 45C
komeko
komeko's picture
Last seen: 6 hours 43 min ago
I will also ask for a link to the extended M43 instruction
Click on:        ANSI WHITE
Click on:        MY COLLECTION
Click on:        Q8, D4, D4S, D18, SDmini, Mini AAA, TIP, M43, H1, H03, TC20, TN40S, TN42, V6, UT01, H600Fw, SC600w, SC64w
AEDe
AEDe's picture
If not only TK is interested I post it here. manual but it in russian.
saypat
saypat's picture
Last seen: 2 hours 4 min ago
i am interested in this manual as well. Thank you for the link. Could someone who knows how please enlighten those who do not, on how to get this translated into English?
thank you!
AEDe
AEDe's picture
thank you!
eng translation made by some online translator.
aginthelaw
aginthelaw's picture
Last seen: 2 hours 33 min ago
!{width:50%}https://tlecanhappen.files.wordpress.com/2015/04/hahah-meme-generator-om...!
The village people are breaking out their pitchforks (they already have the torches out)
never fear shadows…it means a light shines nearby
saypat
saypat's picture
AEDe wrote:
thank you!
THANK YOU AEDe!
Man Without Shadow
Man Without Shadow's picture
Last seen: 1 hour 24 min ago
AEDe wrote:
thank you!
Whoa! Thanks a bunch!
When I'm spending mony foolishly, I like to do it wi$ely...
I have all the flashlights I need, but not as many as I want...
mattadores
mattadores
Thanks Tom Tom,
I started with Jason suggestion on that guys youtube videos which are helpful in a practical diagnostic sense. I then took your advice and checked out some online free ee lectures where I stumbled across an old school one from a MIT EE engineering prof. lol WAY over my head but I like it. lol makes me wish I did go the scientific route in school instead of business. Nevertheless I might just learn about what you guys are talking about one day after all!
Thanks for the additional link. The EE course is vast compared to the more specific information I’m trying to grasp right now like the flashlight components
beastlykings
beastlykings's picture
Last seen: 1 day 23 hours ago
Quote:
I know it’s a complex solution but if one was really determined, a machine-readable blink-out would work. I mean: do the same thing as optical programming but in reverse. Now it’s flashlight blinking out some binary code and a smartphone app receiving it.
That’s a great idea, actually. Complex, I’m sure. But I like it haha
beastlykings
I’ll be bummed if there are no pogo pins, it seems like they are not that hard to add, and they add a whole lot of functionality.
Man Without Shadow
Or even if you could just tip out the driver like on the Q8 to flash the chip…super easy!
Tom Tom
FWIW, the variability of the ATtiny 85 (and 25), internal temperatures could be calibrated out quite simply, by selecting a calibration mode, turning off, soaking the torch at a specified temperature (ice bath 0 C, 20C household ambient, 70 C in fan oven, even boiling water 100C). Turn on again, sensor value measured, offset calculated, stored. Before anything has warmed up, confusing things.
Preferably done in manufacturing, before customer gets them and has to mess about with it themselves.
Sounds similar to M43 description.
SOP in automotive stuff, where we used sensors using base-spreading resistance, such as the KTY13 series from Siemens. Now Infineon. One of these on the MCPCB could transform things. Maybe not even needing another MCU pin, muxed in with something else.
Cheap as chips, very precise and stable with a 3-point calibration and curve-fit. Single point cal. good enough here.
Narsil lets you blink out the raw MCU sensor value and apply the offset yourself when setting up your personal preference for thermal control. Good feature. Helped me set up my Q8 with some scientific method, instead of just suck-it-and see.
Precise thermal control is essential to manage these thermally limited torches to their best, I’m not sure we are any where near there yet with the current approaches.
Re: firmware version. No we don’t need obscure build version stuff. Something like 4 digits, w x y and z.
W = base version. Starting at 0 for pre-production/prototype code.
X = revision level, 0 for prototypes, start at 1 for production releases.
Y = hardware build standard applicable. Same idea.
Z = detailed hardware standard applicable, such as tuning for different LED choices.
When signalling 0, make it ten blinks, so it’s clear that you have got pre-release code.
Put a QR code in the paperwork or engraved somewhere on the torch, linking to a model-specific site with the details:
Source code. With clear commenting.
Hex files, with checksums.
Change lists. Bugs fixed, known bugs not fixed, new bugs found. Features added, features removed, UI changes.
Much as PC manufacturers do when releasing their BIOS updates. User can decide whether to apply them or not.
Alpha code releases for the bold, explaining what things are being tried out. Stability warning. Also coded 0.
Feedback method to report issues.
May not suit “fast and light” coders for whom this is tedious. Or are “output only”.
Personally I would like to see torches only released at a solid stable tested 1.1.1.1 with no compelling reason to consider updating.
Then there is the question of regression testing, and how thoroughly it is done …
Manufacturers might not like this, e.g. customers receive V 1.1, but learn 1.2 is current and fixed some important things, so want it instead. Distributors with lots of 1.1 stock to sell, wanting to send it back to be brought up to date.
Meanwhile manufacturers have moved on to the next thing, and aren’t interested in updating old products that still work well enough. Leave that to the enthusiasts to figure out themselves.
Tom Tom
Not to mention useful in manufacture, to allow last minute firmware installation.
If really not there, as in some previous ones, I can only speculate that the driver on this one no longer shows the hand of e.g. Lexel or Texas_Avenger consultation.
Perhaps a decision to copy the proven base design and have it done elsewhere. Now that he has learned enough to have a go.
Today the hardware, maybe tomorrow the firmware ?
ISTM that Hank likes to plough his own furrow, and do things his own way.
His business is making unique torches, to sell to consumers as-is. Take it or leave it.
Our educated input perhaps listened to, and desire for mod-ability, add lustre, but are not necessarily a primary consideration, possibly a distraction.
Web searches when researching mostly lead here, and are generally very favourable, that’s surely worth cultivating.
Nevertheless we also contribute to his sales and his bottom-line, perhaps in a small way, as well as free beta-testing. A fine line to walk.
DB Custom
DB Custom's picture
I have yet to see you design and make a driver available Tom Tom, supposition and hyperbole are fun to discuss but where is your provenance? Why do you waste so much time telling us what is wrong instead of producing your supposed right? In the context of our old saying here, pictures or it never happened… or more simply, show me.
SKV89
Last seen: 1 min 37 sec ago
Ordered an XP-L HI v2 5D from Hank for $50 extra! Can’t wait to try it. Hopefully the tint is as good as the XP-L HI 5D in the D4S. The XP-L Hi 5D batch in the M43 I got wasn’t that rosy.
If the E07 with XP-L HI can make 7k real lumens, I wonder if the D18 with XP-L HI can make 18k lumens. Big Smile
