just installed in my Q8 a driver from Lexel, great quality and max 7135x15 regulated brightness, also running with anduril!
I also wanted to thank Lexel for all his help when installing the driver!
the usual 21mm for H03 has the single on always on top side
the ones with on down side originate from C8F 21700 design and have it always in that position, but other sizes can be differnt
Any chance you could flash a version Anduril instead of NarsilM?
Its no problem to flash Anduril or Emisar Firmware as the drivers are compatible
Maybe I should have asked “can you sell them already flashed with Anduril or Emisar D4S?” to avoid confusion.
If you can I’d like to order 2x 17mm drivers with Anduril.
Thanks Richard.
hello, am i able to order a 30mm driver for an Convoy L6?
Yes, Lexel will send you a personal message asking you what options you want.
Is there a possibility to tactically use the tail button in the Convoy L6 with Narsil or Andúril as in the Sofirn C8F 21700?
Yes
For the initial power on option you can choose two blinks, turbo or nothing.
Unloco:Is there a possibility to tactically use the tail button in the Convoy L6 with Narsil or Andúril as in the Sofirn C8F 21700?
Yes
this is for NarsilM Anduril I dont know how to change that start up
JasonWW: Unloco:Is there a possibility to tactically use the tail button in the Convoy L6 with Narsil or Andúril as in the Sofirn C8F 21700?
Yes
I got a build of Anduril working with the tail switch by un-commenting this bit of relevant code: // dual-switch support (second switch is a tail clicky) #define START_AT_MEMORIZED_LEVEL In addition I had to use the following fuse value (turning BOD on?) to make it work correctly: -U hfuse:w:0xde:m Now, when I use the tail switch it turns on in the last memorized brightness. Basically, it acts like a normal forward switch but it cannot change modes or anything. It just comes on in t…
L6 30mm diameter driver, NarsilM 2S either Blink at the tail cap or Turbo at the tail cap?
I’m in for 1. Already PMed you Lexel.
Yes
OK.
Thanks.
Interested in one L6 NarsilM, PO=turbo.
I have also made a crowdfunding campaign for the new reflow oven as I will not make the drivers more expensive
First sort of Crowdfunding I try here, to start with latest Gear that I bought making my dri… Stefan Vendel needs your support for reflow oven for BLF drivers
Hi Lexel, I’d need a 30mm 1S driver for a tail-clicky host (Olight M22).
Bistro UI would be cool
sure there is the 24-30mm Bistro 1S possible to build
~~X3~~:Hi Lexel, I’d need a 30mm 1S driver for a tail-clicky host (Olight M22).
Bistro UI would be coolsure there is the 24-30mm Bistro 1S possible to build
Can I get a quote by private message please?
I would like to buy (2) 20mm drivers for the Convoy M21A & Convoy S21A
I’m fairly comfortable with a soldering iron but have never “modded” a flashlight. What would I need to add Narsil to my Astrolux MF01?
First, you would need to swap in a new driver that was already setup with NarsilM. That’s pretty easy. The potential hard parts with the MF01 is if it’s not an early unit, it will probably be glued shut and very difficult to open. Secondly, the emitters will probably be set up at the wrong voltage requiring you to cut traces on the led board (mcpcb) and add jumper wires.
I would start by seeing if you can get the front bezel off your light.
You don’t list your location, but if your in Europe you might be able to ship it to Lexel for a conversion. Outside of Europe the shipping costs go way up.
BTW, do you know about the new MF01S It would be way cheaper to sell your current one and buy the new one since it already comes with many improvements. No NarsilM, but Anduril is based from it with nice ramping and user adjustable features.
