well ask yourself why the emisar d4 became so popular ? same with this, nice looking light ( the clear anodize is very pretty ) nice ui, tint options etc and u have a winner. i have the sst20 4000k, so not really that much higer then my d4/d4s, but i got it because i like the looks and i got a reason to buy first 21700 light.
There is no way I can speak for what anyone will do with such a light as this, but it has 7 emitters and can produce a lot of heat, better to keep that heat away from the cell if possible.
Mine makes 10,000 lumens, I don’t want a copper tube in my hand under this level of power so I speak to this end. It doesn’t require full Turbo to get hot, anyway… and besides, I may make this one do more than the last one.
Thermal config is under blinky modes, starting at line 74. It might seem complex, but each step is very simple.
From off:
Triple click to enter blinky modes (starts at battery check)
Double-click to sunset mode
Double-click to beacon mode
Double-click to temp-check mode (will blink out the current temperature)
Click 4 times rapidly to enter thermal config
Light will blink once, signaling temperature calibration, then start “buzzing” or blinking rapidly. If you want to set the ambient room temperature (do this when the light is cool), while it is “buzzing,” click the number in degrees Celsius (eg - 21 degrees C or 70 degrees F, click 21 times).
When done, or if you want to skip temperature calibration, wait for the “buzz” to stop. Light will blink twice, signaling temperature limit, then start “buzzing” again. Click N times to set the maximum temperature as N + 30 degrees C, then wait for the “buzzing” to stop. So if you want 55 C, click 25 times.
That is because he shipped mine first
(sorry, could not resist that . I think that Neal has been selling the E07 and the GT Micro for more than a month without actually having stock. They are seeping in from the manufacturer now and who compains first gets their lights shipped. I complained first. :person_facepalming: )
A possible positive side of having to wait is that maybe you (and hopefully I too already) will recieve the updated version of the E07.
I am interested in copper and titanium body, I would prefer black or grey body, it would look good with the copper head.
Anyway I am mot sure which emitter I want yet, there is a lot of fanboyism, people buy nichia and not even considering the other option.
for 4000k options the fact is still CREE XPL HI V2 5A offer superior thermal performance, it does not heat up as fast as sst20 or nichia options. Also the CREE XPL HI V2 5A option gives 2000 more lumens over sst20 and nichia.
Not sure about the CRI rating on the CREE XPL HI V2 5A, but considering better thermal performance and a lot higher lumen output it might be worth to sacrifice some CRI, I am not even sure how much it will be noticeable in reality. The big difference in lumpen output difference might be more noticeable then the CRI difference.
the E07 has been the hottest flashlight for months now yet there is very little pictures of beamshots etc, I am surprised not a flasholoic have done a camparison yet comparing all emitter options, with beamshots, and mesrements how much throw and candela and lumen and thermal performance.
E07 biggest weakness is thermal problems, so it makes a lot more sense to sacrifice CRI to choose the CREE XPL HI V2 5A option.
But I still want to know more about the emitter to compare it.
I want to see the difference in candela, cause I use a lot indoors, I think my Manker MK14 is kind of perfect for that but lumen output could be more powerful and little bit more throw so maybe SST20 and Cree 4000k options will give better balance between flood and throw but I need to see with my own eyes before I decide, cause the 219C is very good to lit up indoor rooms, I simply just want see how big the difference is, so I am disspointed to see there is no one who have done compariosn, cause 99% of all people buy the nichia model because of the high CRI number, both nicha and sst20 have big thermal problems compared to the CREE options, and the lumen output is about 40% worse.
