The AVS head can take 6-9 volts in regulation. AVS stands for Auto Voltage Sensing. At 6 volts you get 650 lumens on the 2 cell Bravo body and 900-930 really on the 3 cell Charlie body.
I gave Elzetta lights serious consideration for a while, but eventually realized that while they are incredibly rugged, they’re far too over-built for my needs. I do not have any firearms so I don’t need weapon mounted lights that can deal with that kind of shock. My lights are not exposed to frequent hard knocks, submersion in mud, etc. If they were, I’d likely consider an Elzetta.
Which lights worked for you may I ask? If you are breaking Surefires even diving into rocks I can tell you been there done that and swam across rivers afterwards firearm submerged with the WML dozens and dozens of times my friend.
Please let me know what is better because I will be first in line to buy one.
Thank you very much for you opinion. Yes , I completely agree that not everyone needs a top tier weapon light and for those people the over built light is most likely not price justified. I understand that, In fact I have my next two light purchases narrowed down to a D18 and an Elzetta Charlie. If the Charlie works for me, I will be getting several. If the Emisar D18 works for me I will be getting more of them as well.
I completely respect your opinions and reasons why you have not sold them. I have Hinderer knives I should sell, and a lot of Benchmade highly limited runs (as in 50 made total) I should sell them as they are not being used, but I am not paying Bladeforums another dime just to sell my knives. I have been a member there since 1999 one year after they opened in Oct 1998. I am not paying 30 USD a year anymore to make someone rich to do nothing.
EDITED* Can you please explain why you do not like the optics from the AVS head sir ? Do you think the Charlie with the extra lumen would help or not?
The lights seem pretty steep. Considering most use CR123A vs 18650. The outputs are somewhat low as well. These would be in Surefire class. Due to being over priced with low outputs.
I have my old duty ASP Triad CR bored for 18650 as my home weapon light and its has held up well on a deployment and now on my ARX. I also just had a Nailbender P60 in a Solarforce host and it serves well except I dont care for it being 2 mode. The ASP light it perfect because it is a single mode with a twist tailcap to select momentary only or FWD clicky on. Sturdy light and not badly priced.
I got two bravos and a charlie. All with my name and phone number engraved on them. I always tell people “If you get an Elzetta, you won’t be sorry… Until the day you lose it., at which point you will be quite sorry indeed.” That’s why I put my number on them, one of my bravos was returned to me after being lost for two weeks. There’s still a few decent people still out there.
I had had some bad experiences with nitecore, and went searching for better reliability just at the time the bravo/charlie thing first happened. This means my elzettas are pretty close to as old as they get, going on six years now. At least one of them has been with me, all day, every single day since I got them. I believe the construction job I do is just about as punishing an environment they could be in. The amount of water and dust they have to put up with is extreme. I do a lot of plumbing, and it’s more than adequate for the purpose.
The flood lens (LENS, not reflector) is completely awesome for close up work. It surpasses ANY other system of reflector or diffuser. I cannot say enough good things about the flood lens. It must be experienced to see just how good it is. The throw lens on my Charlie is also extremely nice. In my opinion it’s these lenses that keep Elzetta a hair above Surefires of the same brightness.
Forget waterproof, you can take any Elzetta apart and put it back together WHILE IT’S UNDER WATER. One time an idiot dropped one of my bravos into a bucket of latex paint, I didn’t even think twice, I just hosed it off and put it back in my pocket. It pays to keep the threads screwed down tight, but the head tends to not light if it’s even a little loose… so it’s always tight. But it wouldn’t matter if it was a little loose.
Tough? I used to tell people, “Go ahead, throw it down the street as far as you can.” AND THEY DID. Five times it was thrown, I had to file off a small burr once. No damage to the light but it does hurt the batteries, so i had to stop throwing it.
No, they are not the brightest, but that’s really the point. You are not overdriving the battery, the LED, or the electronics. Long runtime! How often do you really need more than 650 lumens? Take it easy, cowboy. Just today I left it running under a dishwasher and went out to the truck for half an hour. It was barely warm. Still had enough battery to finish the install. I get about 75 minutes on a 3400 ma/h battery, and 60 of those minutes are at near full brightness.
The only thing that’s a little wonky is the high-low switch. It’s not perfect but it does hold low well, after you fidget with it for a second or two. The only time i use low is when the battery is low, and i need stretch time.
About this time you’re wondering if I’m getting paid, and the answer is no. I’m just an extremely satisfied customer. After six years, what’s not to love?
If you’re collecting, I could see passing it by. But if you’re going to trust your life to a light…
I say again: If you get an Elzetta, you will not be sorry… until you lose it.
More:
I got all of mine bored by Overready, but going forward I’m not so sure they’ll be doing it forever. You might be stuck with the Bones light if you don’t want 123’s.
Never really cared exactly what the emitter is, it’s 650 lumens of great tint and just about the highest CRI there is, You can rest assured that Elzetta is not using jenkem emitters.
Elzetta’s spokesman, Dave Barnett, is also just about as good as it gets. Highly recommend going to Elzetta’s blog page and he will clarify any concern you have. The two “beam” vids are must-see.
Outputs are low because these lights stay within the safe current draw for CR123 cells. Most of the “normal” brightness rating you see for these emitters are them being over-driven too, so the lower max outputs are to ensure long lifespan and reliability.
Overready does not appear to be doing bore runs any longer. The thread was locked nine months ago, and they linked here as a possibility… https://precisionelectrical.us
Correct, as one of their blogs shows the Amp draw difference from the P3X to the Charlie, Bravo and Malkoff model.
The Surefire’s were drawing more the the cells rated max Amps at first, although I believe that was to get 1,300 lumens out of the light turn on and still get 1,000 lumens out of the light at 30 seconds. To me, I do not like that. Yes, I own P2X Tactical, P3X Tactical Titan and Titan plus , PLUS all my Surefire WML’s.
Mean while I currently own ZERO Elzettas but will soon and I love their Constant output of at or above 900 lumens for about one whole hour.
Meanwhile, Surefire starts about 1,300 lumens and then decides to run a quick drop to about 650 lumens after just a few minutes. I will try to look up their graph
I think you and I are like minded. I agree with everything you have mentioned. Remember everyone, sometimes it is not about sheer lumens but coming home alive. With a quality built illumination tool that is rarely rivaled.
Then there is the other side of the coin, BLF. Yes like a 100 USD D18 light that does 14,000 lumens for 20-30 seconds then goes to 2,000 lumens . Bright and fun yes, But give me that Elzetta OR Surefire to get me back home in one piece.
This explains it well. I can’t even imagine what many of the Chinese manufacturers are doing. Pushing LED’s past max, making them smoke or burn out, or maybe I can. Since the reliability is like flipping a coin on some brands. They are toys though so I understand it, and trust me the D18 I will buy it, but Emisar is one of the finer Chinese companies no question .
Sounds like you have has bullets whiz over your head and possibly pistols in your face as well. The shooting stuff, I am trying to move away from , but addictions are hard to break when offered to you on a GOLD platter, Just have you make it back alive…
