More parts and more electronics = more failures. If your life depends on light, it’s not a matter of brand but more a matter of diversity : don’t put all your eggs in the same basket.
Driver & LED, incandescent bulb, carbide lamp, kerosene lamp or oil lamp, candle, etc.
Myself and my family have never been in a life threatening situation that could be eliminated by having a torch. Like, has SOS mode ever saved anyone? On the occasion we go camping or have a blackout 1 light just won’t cut it. I’m not going to have a dozen surefires or elzettas on hand for that.
lol no not at all, don’t worry! I knew it was an impractical test… lol it was just cool to watch it crushed by a car in a block of ice…. this is a totally impractical test but because it looks cool it must be worth something! :smiling_imp:
lol anything to help justify yet another light purchase to the misses!
I’d go with Zebralight. I’ve never had one fail, and they’re solid with potted electronics.
I might also say Armytek, because they use massive amounts of metal. But although mine are fine, I’ve heard too many stories about them suddenly dying.
Though for reliability, I’d rather go with two budget lights than a single expensive light. The chances of both failing at the same time is a lot less than a single failure of an expensive brand.
PRIMARIES ARE THE ONLY CELLS I TRUST MY LIFE ON. CR123A CELLS for life critical applications only.
I do have a few dozen AAA Energizer Ultimate Lithium primaries for my Surefire Titan and Surefire Titan Plus. I run Eneloop pros in them now.
I can also replace the (2) Li-ion cells out of my Olight M3XS-UT (and use (3) or (4) CR123A cells in it.)
In my Olight S1 Baton, I can replace the Li-ion and use (1) CR123A cell in it.
In my Olight S2 Baton, I can replace the Li-ion and use (2) CR123A cells in it.
If there were less than optimal other charging solutions.
Only my Olight X7 and my Emisar D4 XPL-HI have me locked down to 18650 Li-ion cells. All other lights I own run solely on CR123A cells. Due to the fact they are WML’s or hand held tactical lights.
You can actually do the entire house for about a grand…….IF you are building new.
Believe it or not, use paper backed aluminum sheet that can be found in industrial supply houses. Put it between the gyproc and the studs. Down side, the cell phones are useless.
I never only have one high quality light on me so redundancy can be thrown out of this equation. I carry at least 3 Surefires on me when I am out, and sometimes the M3XS-UT depends on what I am doing. I am not looking for a single light to carry only one light. That is already a WML. And I carry others also a D4 and 2 more Surefires. If those 3 Surefires and the D4 all goes out, EMP hit.
I like carrying several more expensive reliable brands at once, less chance of them failing then two cheapo lights.
Ordering an Elzetta Charlie finally after I thin the Hinderer knife herd. Unused knives are worthless like unused lights or any other tools.
Hahahahahhaaha, OR just but Surefire Elzetta and Malkoff lights and never worry again. Not that I do my Surefires have been thrown 25 feet into the air to land on cement several times they work fine. :+1:
All lights fail in ANY circumstance at ANYTIME. Break down in choice selection is the Engineering Design, build material components, quality control, pricing, etc……
I have done some high impact, and other extreme tests on some of my reviews. I will give insights here.
Sofirn : GREAT
Maglite : WORTHLESS
Bushnell Pro : TOTAL JOKE
Wuben : GREAT
Klarus : GREAT
Thrunite : Decent
Olight : Decent
Fenix : Decent
Powertac : GREAT
SureFire : TOTAL JOKE ( friend gave me the Defender version) Cracked body one it hit hard concrete floor
Plus quite a others. Too long to list.
But to give you basic insight. Just because higher price point DOES NOT MEAN DURABILITY or BETTER QUALITY.
When my daughter went to Uganda for 3 years I gave her a Zebralight H502 and a Fenix AA. Both held up under rough conditions so I would not have any hesitation in depending on them on myself for critical situations.
