Cheap recoil thrower cheap ($7.95) via slow blimp from China
23 posts / 0 new
eas
eas's picture
Last seen: 2 months 3 days ago
I’ve seen some chinese recoil throwers in various old threads here, but I don’t think I’ve come across any for sale until now.
Here we have what the seller calls New C12 Q5 LED light lamp Waterproof Zoomable Flashlight Torch 5 mode camping. It’s not zoomable & the pictured light is clearly a recoil reflector.
I think this host has also been known as the UltraFire WF-008. This one has the “E-Smarter” “brand.” The venerated OldLumens reviewed a very similar light in 2013.
There was a similar light available (with a larger reflector?) branded with GoRead and Sipik.
I just ordered one to try out.
Edited by: eas on 06/17/2018 - 18:25
ImA4Wheelr
Last seen: 1 week 2 days ago
I ordered one because I need to have at least one recoil thrower in my collection, but received a weird traditional reflector light.  The battery tube says Ultrafire Z11.  Probably just an innocent mistake.  Contacted the vendor.
staticx57
Last seen: 38 min 17 sec ago
I offered 4 for it. Looks interesting
eas
eas's picture
Looks like my order could be here tomorrow. We’ll see if I get what I ordered.
Redlyne22
Redlyne22's picture
Last seen: 4 hours 2 min ago
Wow, I never knew somthing like this existed in a portable flashlight form. I ordered one. Thanks for sharing this.
Sometimes being a newb is the best part of a hobbie
eas
eas's picture
I didn’t get what I ordered. I got a ultrafire z11 thingy, too. I’ve requested a refund.
Update: And the refund was granted, along with a pre-paid shipping label to a US address.
ImA4Wheelr
Did you file a dispute or just PM the seller?  I PM'd the seller and was offered a $1 refund.  Have you actually been refunded yet?
eas
eas's picture
I just did a return request. They issued a mailing label. No refund yet, it looks like they should receive it tomorrow.
I see that the listing has been updated to show the light I received, though the light in the photos is branded esmart, rather than Ultrafire.
ImA4Wheelr
OK, thank you eas. Smile
djozz
djozz's picture
Last seen: 1 hour 6 min ago
The only recoil thrower that I managed to buy in the last few year, although it really was one, had a miserable 15mm diameter reflector instead of one that went all the way to the edge like the original WF-008.
Agro
Agro's picture
Last seen: 1 hour 56 min ago
Another similar but different light on Ali:
https://www.aliexpress.com/item/Recoil-Thrower-Q5-3-mode-LED-Flashlight-Torch-Outdoor-LED-Lamp-18650-Flashlight-Focus-Torchlight-Recoil/32949812921.html
djozz
djozz's picture
It is a gamble, but i bought one. The pictures show a mirror that covers the whole diameter, but last time i bought one, the actual flashlight had a much smaller mirror. Let’s see how this one goes, I do not have high hopes.
Thanks for the heads-on Agro!
LouieAtienza
I believe Pelican manufactures a line of recoil flashlights…
djozz
djozz's picture
Bingo, it is the real deal, cheaply made just like the old Ultrafire, but with the full size mirror of seemingly good quality (although with dust and a bit of dirt.
Always wanted to check one of the new leds in one, let’s see if it can be modded! Smile
Scallywag
Scallywag's picture
Last seen: 52 min 45 sec ago
Cool! What advantages does it offer over a normal reflector? I know cooling will be the big disadvantage.
EDC Rotation: ZL SC62 | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01
"Back-Ups": EagTac D25C Ti | Olight S1 | Klarus Mini One Ti
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Blue S2+ w/ ML Special
In-progress: Supfire M6 3xXHP50.2 | Jaxman Z1 White Flat
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
gchart
gchart's picture
Last seen: 4 hours 19 min ago
Interesting… keep us updated! Now we need some tests/numbers.
Firelight2
Firelight2's picture
Last seen: 57 min 28 sec ago
In theory, it should have much better throw than a conventional reflector of the same width. Supposedly it is possible with a recoil thrower to produce an image of the die like an aspheric light, but with no light loss into the sides of the bezel.
djozz
djozz's picture
The correct question is: what advantages does it offer over a aspheric lens, because optically that is much closer. And the answer is: in this size that is not clear, although it looks like this mirror is optically better than the aspheric lenses commonly used in flashlights.
In larger lights it becomes a major advantage that mirrors are more lightweight than an aspheric lens, and optically superior over a fresnel lens.
But for me it is about the Cool factor, it is a type of flashlight that I have not fiddled with as yet.
djozz
djozz's picture
In this light it does have a lot of light loss at the side btw, it seems to catch less than a 100 degrees cone, not unlike an average aspheric flashlight.
Firelight2
You should compare it side-by-side with an aspheric light with a lens the same diameter as the reflector using same emitter and driver and see which is brighter!
It would be nice if someday, someone made a modernized better quality recoil thrower. I think the key would be to make the LED arm out of solid copper for much better heat transfer.
It would also be nice if it were made with 2 leds on the arm. A high-intensity one facing backwards for throw and a floody one facing fowards for close-range use as a mule.
djozz
djozz's picture
I remember there was indeed a two-led version once, or maybe there was just talk about it perhaps.
Firelight2
You remember correctly. There was recoil thrower years ago that did have 2 LEDs on it, one facing backwards and one forwards.
I forget the model number though. Might have been an Ultrafire.
LouieAtienza
UF-009 had that configuration…
