[Review] Airpro DC7
Thanks for the review and the good video showing the UI. What does it cost and where can you buy it?
edit: found on Amazon https://www.amazon.com/dp/B07MZ2GZYK/ref=cm_sw_r_fa_dp_U_qmbzCbBWNSH3W
Thanks for the review!
Nice review. Just snagged one … :slight_smile:
Many Thanks.
https://www.amazon.com/gp/product/B07MZ2GZYK/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Item(s) Subtotal: $57.99
Shipping & Handling: $0.00
25OPCCHA: -$14.50
Total before tax: $43.49
Estimated tax to be collected: $0.00
Grand Total: $43.49
Any chance you could check whether the manual includes information about how to get the source code? If it’s using Narsil, that’s required to be in there somewhere.
sorry for the late reply, here’s a promo code if you plan to:
I did check, unfortunately it’s not there, however I asked Airpro and they said it is Narsil, however it is different from the Narsil on the BLF-Q8. Maybe a different version perhaps.
Sorry I just read this, if you can cancel, maybe you can still get the promo - Amazon.com Page Not Found
My pleasure, thank you for watching/reading.
Thanks.
It sounds like they’re not following the license, so I should go bother them about it.
Great deal for a Q8 with usb charging! :+1:
Like I don’t have enough Q8s… I hate you guys.
Yeah, I got one, even with evil usb-c instead of micro. :stuck_out_tongue:
I had it in my cart, but didn’t pull the trigger. Already have Q8 and a Mini TN30, and would miss the exercise of pulling the cells and charging the old fashioned way.
I prefer the BLF Q8. It was clear that some knock-offs will hit the market if you see what a sucsessfull light it is. I think the main reason why there are not more knock-offs is, the low price of the Q8.
Not much margin if you want to deliver the same quality.
Not nice if they use Toms/TKs code without mentioning it! The two are so kind to let everybody use their work without getting money for it. So they sure can expect that its mentioned in the description!
I would not buy this IMO.
They aren’t following the GPL, will probably cut corners somewhere at some time, which I do not like.
Hey, where would someone get one of those “key ring holders” for a Sofirn Q8? The Q8 has the same threaded hole. I like that!
I’m pretty sure companies we all know that worked with TK had the same problem before being told how to comply. They might still be crap though…
Yeah I know.
That’s why we are here to straighten them out a bit.
It can be a weird thing for companies to wrap their heads around. It’s a “share and share alike” license but, by default, companies usually seem to want to do the exact opposite of sharing. They often want to set the lock bits too, to prevent “theft of the program”… not realizing that people are supposed to be able to copy it, and anti-theft measures are forbidden by the license which gives them permission to use it.
Anyway, I sent a message… but it’s the weekend so I’m not expecting a response right away.
Here you go :
Thank you very much! People here are so helpful!
