Yea I know but he seems to enjoy my small throwers every time he comes over to visit. And I figured the micro would be a good fit. Just wasn’t sure about the battery choice
A drop or two of blue Loctite, nothing too hard to break open with bare hands
40kCd with a trustfire 14500 @ 3,2A only… might have to invest in some good batteries.
Now, the real good news is : the LED shelf is insulated from the negative side of the battery. This means this light is usable with a Black Flat !
EDIT :
It is a perfect Black Flat host guys !
I reflowed one on the stock copper MCPCB, and simply removed the centering ring to allow the reflector to sit directly on the MCPCB.
3,2A and 105kCd @ 10m !
Hmm, sounds pretty simple. I might have to try this. Do the black flat burn up at 5A? It might be too risky to try a high drain. Unless you’ve got a spare emitter, of course. Lol
Anyone else having trouble with their Micro? Got one in the mail and with the body fully seated it bypasses the driver and runs directly off the battery, loosened very slightly it works correctly
Sounds like someone got a bit overzealous with the solder and it is causing a short someplace. Only way to know for sure is to pull the light apart but that is not super easy.
Got my GT micro two days ago. Love the form factor and that beautiful reflector. It will get a narrower led though, a White Flat (for max throw and wows) or dedomed XP-G2 S4 3D (for much better tint), not decided yet.
I haven’t seen a de-domed Cree emitter that had better tint than the White Flat. Not hot de-domed nor chemical de-domed and certainly not anything that started life in 3D trim. Not even as a result of Vinh’s cherry picking… one of those is sitting on my work bench gathering dust even now, pulled ftom a TK61Vn due to it’s sub-par tint.
Of course, one man’s trash is another man’s treasure…
Got it apart, inspected and everything looks good physically. Even did a factory reset but it is still not working correctly, turns itself on sometimes too
Almost has to be the reflector touching the negative lead OR a split in the negative leads insulation allowing it to ground out. (Look for this where the lead comes through the emitter shelf and bends to reach the pad.)
As an aside, operational instability can easily come from excess pressure by the switch boot on an e-switch.
