nice it arrived, lol be glad u got a black lanyard, i think the purple one i got with gt mini is hideosā¦ and it already quickly destroyed a little the outer wireā¦. black looks more elegant .
I spoke too soon, my switch is also dodgy
oh noā¦. not another one
My GT mini CW is from Banggood. Seems warehouse stocking date was 15th Mar for my unit. Works okey so far. I cleaned contacts before using it. There was some glue on driver contact area and lube on tube contact surfaces. Also top of the driver side spring was really dirty.
I measured tail cap current 5.60A on turbo at 0s with Sony VTC6 having 3.975V before the test.
I wonder what LED bin they are using for cool white version? (flux, tint) (V3 1A was said / guessed somewhere?)
Firmware defaults donāt seem to match the documentation (V5 manual at post #1 in this thread). Strobe modes are available by default. I tried factory reset and those are still available. (double click -> turbo, then double click -> strobe)
Front of the bezel is not straight: When the light is put bezel down on an even surface the light rocks little.
Unless I missed someone, I count 21 people to date who have posted about switch problems. They areā¦.
djozz// Reported RESOLVED -
mortuus// RESOLVED -
teacher// RESOLVED -
RobertB// Reported RESOLVED
ā¦ā¦ā¦ -
gabo// RESOLVED - Cereal_killer /
Jhicks2018// RESOLVED -
P33/ // RESOLVED (āpartial refundā reported) - Coyotehawk
X3/ // RESOLVED (PayPal dispute refund) - illuminos
- Silent_Star /
Juheebus/ // RESOLVED (Replacement head) - mb200k
Pulstar// RESOLVED -
A92AA0B03E/ // RESOLVED (Replacement head) -
komeko// RESOLVED <span class=āāHEREā:https://budgetlightforum.com/t/-/51714/1417+ (+explained refundā¦ & dispute PayPalā> - Th558 /
Icarus/ // RESOLVED (Replacement Head) - alex64 /
- hodor /
Anyone else having any type GT Mini switch problems besides the people I mentioned above??
ā¦ā¦ā¦
List updated / 30 March 2019.
- hodor Added
Yep, it does somewhat. I was one of the 1.9. :+1:
And if Jasons count of around a thousand sold was/is correctā¦ the āreported switch issueā is up slightly now to 2.1%
My light arrived and it works fine. I also did not watch any reviews before buying it and now I am absolutely amazed on how bright it is.
Banggood has sent me a replacement. I hope this one doesnāt have the same problem.
Why donāt gchart or Lexel design us a nice ātailcapā bord for the switch then we can do away with that half-lit switch and get a transparent switch that isnāt finicky
havent heard of a replacement that was just as bad. i think they know long ago the first batch had switch problems on some so i asume they send a newer version as replacements.
Most of the time my switch works just fine. Sometimes when it doesnāt if I ramp up all the way, then it works. I seem to get the best results with a very quick press/release. I am inclined to live with it, as I canāt see myself in a situation where a few extra seconds to turn the light off will have any impact.
In my opinion the best way to test switch functioning is put the light in momentary mode (5 clicks). Then light should shine allways when switch is detected pressed.
Hey
I have this light,but with an OSLON LED modded by Vinhā¦
650 lumen, 300kcdā¦I belicveā¦
What other hot rods are out that can surpass this one , but in this size lightā¦Not a 2x18650ā¦2ā headā¦
something really small like this?
Is there anything ATM?
Thanks
Tony
Absolutely nothing if you stay in this class of light with a 2 inch/5cm head.
Coolā¦maybe I bump up a classā¦
Yes then:
Itās a 21700 light, which is very nice.
64mm head, or 2,5 inch head.
Here are the specs for each version:
Luxeon V Throw = 575m= 82,6kcd
SST-40 Throw = 770m= 148,2kcd
XP-L HI Throw = 250-260kcd+ = 1000m+
So embarrassingā¦ I thought ramping up to maximum is the same as turbo
It varies Spiderlight, sometimes the top of the ramp is maximum, sometimes itās notā¦ depends on the UI and how itās set up.
Well, I am using the default UI and settings. I think it the same as the BLF Q8 uses, and if I am right, I never used turbo on the Q8 either.
I think thatās like my haiklite mt09rā¦?
I had interested parties, but this revision ramps to 50% then double tap to turboā¦ This modded gt mini ramps all the wayā¦
