Only the driver has glue to hold it in place (no retaining ring). I show how to pop it out from above, but it’s not really needed because the boost driver works really well.
It’s easy to pull the led out if you want to change the tint or slice the dome, etc…
Amazon customers love flashlight with battery and charger, since most muggles don’t have these.
muggles bought light alone because it’s cheaper, they thought it SHOULD has battery even though it’s clear NOT included, then a return caused by NOT as described?
I know about that problem very well. Maybe there’s a chance to indicate more clearly what’s NOT part of the content? Some German Amazon customers seemed to return their Sofirn lights just because they were unable to look for the insulation plate between battery and spring. :person_facepalming: Adelina (Sofirn) and I have made something up to help customers understand what to do and of course to reduce the rate of returned flashlights.
Maybe it’s worth to integrate these pictures not only on Amazon DE but also Amazon US and so on.
Some people need an in-person lesson on how to use a shovel, so there’ll always be some 85s who still won’t be able to understand the pictures and huge print and everything.
Probably the same kind of people that try to dry their wet hamster in the microwave oven because the manual doesn’t say to not do that. Those people then file a law suit about their exploded hamster because it was clearly not their fault.
