Fireflies E07 preview
Does any one have a beamshot comparison between XPL Hi V2 5A 4000K and SST20 4000k. I am not interested in the Nichia, they have more quality problems and the blueshift problem is not something I want to risk.
There is a big lumen advantage over the SST20, I also read that the XPL HI have superior thermal performance it means that I would be able to run on turbo for longer periods then the SST20.
Noticed that the banner to the left is now advertising an E07 VII. The website says new version since the beginning of March, but does not say what the changes are? I assume it probably has the cooling fins rounded off on all colors now, but can anyone confirm? Any other changes?
I have one that I’m pretty sure is VII, slightly bevelled fins indeed, undamaged optics and a ledboard that sits flat on its shelf with ample thermal paste. I’m not sure if there’s more changes. I modded it with a few new leds already: What did you mod today? - #7230 by djozz
Version II is also supposed to be 1mm longer so it can accommodate larger batteries.
My 50E is 70.9 mm and my E07 version fits that precisely, you do not want the battery longer.
Perhaps useful for someone somewhere.
I set my (SST-20 4000K, slightly altered by swapping 3 of the leds to SST-20 2700K) E07 at 5 lumen, which is a great brightness for longterm trail-following without tiring the eyes with too little light, and measured 20,13 mA.
That translates to 62 lumen/W system efficiency (pretty good for 98 CRI), and on the Samsung 50E that it houses now (I measured 5200 mAh at 500mA discharge in the Opus) that is a continuous runtime of 10.7 days.
Some flashlights have terrible efficiencies at the lowest modes, but the E07 does well in this aspect. I reckon we have to thank Anduril for that :slight_smile:
Yeah not bad, especially since we are PWMing 3x 7135 to extemely low levels.
I dislike lanyards with rings and clips or that extreme thin piece of cord that must be fumbled in a tiny hole, but the rather deep clip groove of the E07 allows a simple and very strong way of lanyard attachment that I do like.
Ok, here’s a concern for the E07.
It is something that I always check on my flashlights and the E07 is the worst yet: the battery tube where the head-side o-ring groove is, is just 0.3mm thick. This is paper-thin, why did they do that? As this is about halfway the flashlight, as far as I can see this has major influence on the strength of the flashlight, which is built thick and sturdy everywhere else. I would (not :frowning: ) like to know what happens if you drop this light from some height and it lands a bit unlucky.
FTR and FWIW I rebuilt my lightbox with two internal baffle/diffuser panels cut ftom a sheet out of a Samsung 26” monitor. Then I used the Maukka calibration lights to come up with a very different multiplier. With the two diffusion panels there is no hot spot coming though to the meter, not even from a White Flat. My multiplier changed ftom the previous .345 to the new .436.
One of the lights I tested after this is the new black E07 with 6500K XP-L HI emitters that Neal sent in place of my GT Micro lights. With a fresh charged 30T this straight out of box E07 does 6627.2 lumens at start. A little less than the 6900 claimed on the site.
Ham’r shows 20,056, down quite a lot. The extremely throwy XSword on the other hand shows 379.32 , amazingly close to where it was before. Of course, percentages are huge numbers on huge lights.
you’re not getting your Micros?
No idea, haven’t heard another word from Neal since he asked specifics on what actually came. (That was the 17th)
I would like to have one in plain metal. Shiny.
Like the one you show in the pics, but don’t sell.
Easy to identify in rocks or grass. Thank you.
Cheers.
Thanks for the info!
Does anyone with a V2 know if the button LEDs match the blue aux LEDs now? It would be nice if they were updated to match like the ROT66.
Anyone know if the switch has changed?
Very little feed back from the switch, it does click, but not a positve click.
I was not sure if I would have the heart to tell about my dissatisfaction with Fireflies in general or respectively with the E07 model that I have bought at Banggood and received today. In the end, I thought it might be worthwhile to the community to share my impressions.I try to be factual with all my rant about this insolence I have faced today.
The item I bought:
Fireflies E07 XP-L HI V2 5A, 4.000K in gun-metal grey
Date of order: 2019/03/22
Date of receipt: 2019/04/02
On a side note: This E07 was ordered after Banggood's stock was depleted and replenished again, i.e. it is very likely to be from the new, second batch. The cooling fins had no sharp edges.
Table of content according to Banggood:
Now, when I oped the plastic bag, I found the black "gift box" that should contain all of the above mentioned items. Should? Yes, it should. When I opened the box, I found this:
Missin' anything? I guess so! Remember, i.a.w. Banggood I should have found:
  • the flashlight: check
  • the o-rings: nope
  • the stainless steel clip: nope, not in the box, not stuck in the black foam nor attached to the E07
  • the manual: nope...and rest assured, I took out the black foam from the box, too.
  • the gift box: check
Okay, that's bad, there's nothing to argue about it. But I was still in a good mood to have at least the light in my hands. You might expect what's coming next, right?
Let's have a look onto Fireflies' E07 advertisement picture:
Lookin' good, doesn't it?`The bezel looks shiny, clean and....tightened. The color of the anodization looks evenly distributed all over the entire body, i.e. tailcap, tube and head have the same appearance.
Now, let's go back to my E07...those pictures speak for themselves...
The tail cap feels like it is made of plastic and not of aluminum. Unfortunately, I was stupid enough to run this light at full power until it became real hot with the bezel not tightened. I was wondering about the cracking noise it made when it became hot. That caught my attention and oh well...I managed to tighten the bezel as far as I could with my bare hands. The cracking noise is now reduced to a minimum but still existing. I'm not sure if the flashlight (may have) suffered any damage from running it exteme hot with a loose bezel. Any feedback is welcome, guys.
Now comes the moment when I really scratched my head and started to laugh:
I cleaned my glasses twice and rubbed my eyes because I failed to believe that they actually put a stamp on this piece of sh...oot sayin' "QC PASS". Well I say: "So much for quality control at Fireflies!" :FACEPALM:
If anyone of you was wondering about the big blob on the driver spring, causin' serious dents on the positive terminal of your 21700 batteries, this is how my driver spring bypass looks like:
Before closing, I would like to wind up this report with some good news. The flashlight is at least running and all LEDs (though not well-centered!) and AUX-LEDs run as they should. The center LED however has some dirt below the optic but I don't want to sound "OCD".
I have immediately filed a complaint via Banggood's customer service that only contains the worst issues so far. I will supplement anything else I have been missing to report to them in the first place. I was promised to get a reply from After Sales in 24 hours. We will see...
The cracking noise is air underneath the star heating up and expanding. It’s irritating, but harmless.
This problem is fixed on the VII version of the E07. You can eliminate the cracking noise on earlier model E07s by removing the star and adding a lot more thermal grease to fill in the gap and/or beveling the lower edge of the star so there is no longer any air gap.
Also, the tailcap is solid aluminum. It is not plastic no matter what it may feel like to you.
It is well-known at least on BLF that quality-control at the assembly house at least for all version 1 EO7s is rather lax. The quality of the design and parts used is very high, but assembly quality control is quite sloppy.
Hopefully Fireflies has seen the feedback and improved their assembly procedures and quality control for the VII.
So is it worth getting a Version 2?
Over the Version 1 already have?
The verdict is still out. I think most BLFers were early adopters and got V1.
My guess is not many of us will purchase V2 until the copper\ titanium version arrives.
And even when it does arrive I won’t be an early adopter until I see that thier QC has improved.
One thought that struck me when looking at the Manker E14 II, The leds are placed a lot more compact, looking at the E07 the emitters are very far a part and a lot of dead space, does this fill any function ? It feels even though it looks good that the head could be more compact, compared to a lot of quad led flashlights they are a lot more compact head. It will be even more important when the Copper version is released cause it will be very front heavy, so it will be better balance if the whole body have somewhat the same size in diameter.
Yeah so yeah E07 could probably had become more compact.
Another question that struck me is when will flashlight get active cooling, some smartphones today have cooper heatsinks with vapor chambers.
Heat is the biggest problem with flashlight design 2019, so thinking outside the box in terms of cooling should be priority, what good is a 3800 Lumen light if it have to be throttle down to half for 90% of the time becuase of heat problems, I am not talking just about E07, its a general problem I hope we will see flashlights with active cooling of some kind in near future.
In terms of E07 it seem that SST20 have a lot better thermal performance then nichia, so yes even though the Nichia seem to be the most popular choice I think a lot of people choose nichia because of fanboyism and because of the nichia have been pretty much alone as CRI alternative for a long so they have created a lot of fanboys. SST20 runs both cooler and it gets the same lumen but with 4000K instead of 4500K. To get same lumen in 4000k is more demanding then 4500K. But biggest advantage in the case of E07 seem to be thermal performance, I don’t have the exact numbers of the difference but hopefully it will not throttle down as extreme as with the nichia 219B which runs very hot fast.
