TC66C-a powerful Type-C USB tester
Where is the PC software?
The instructions refer you to this location:
But when you go to this location, there is only an .apk file there which is not a Windows executable.
Same thing here.
I’ve also bought the TC66C.
I’m looking forward to testing it.
Ah ok, thank you.
So, do you work at RDTech?
Are there any products being made/in the product pipeline?
they give me a product , then I test it and write an article so that I can get this beta TC66C for free, :laughing: you can just have a look at their eshop,they have their own factory.
https://rdtech.aliexpress.com/store/923042
they said they will upload PC software in two days,you can use it when you get your item. I use beta version :person_facepalming:
What is the “CC drop down” they talk about in the description?
“For CC drop-down:PD stipulate that type-c interface has no output by default. When there is a drop down on the CC line (pin in the Type-c interface), PD charger thinks that the load is connected and then starts the 5V output. Therefore, it is normal for the tester to plug directly into the PD charger and not light. if CC drop down is enabled in the setting of TC66, when you plug TC66, it will automatically brighten the screen after it is set as enabled, but it may affect the normal charging process. If protocol detection and trigger are to be carried out, CC drop down must be enabled, and the back end shall not be connected with any load. If it is set to be off, the charging of PD charger will not brighten the screen, and the charging process will not be affected. Please first plug the tester into the charger and then insert the load.”
this is written in their Introduction :smiley:
Sounds very confusing. So what if you want to trigger a specific protocol and apply load using that specific protocol, for example PD 20 volt?
at first,we should make sure that charger support that protocol, then you set the protocol you need,when finished setting,connect it to your load
Right, but what about CC drop-down in this case? Should it be enabled or disabled?
enable
Function01: independently charged
“we can see there is a Micro-USB port on TC66©, it is used for independently charged so that TC66© will not consume system power,and we can have more accurate measurement calue. On the other side, when TC66© is independently charged,we can measure voltage from 0.005V.”
quoted from post detail of TC66C :innocent:
they update everyday,and you guys can click “follow” at eshop of RD to get coupons(this is an advertisement :money_mouth_face: )
When are they going to start shipping these devices?
For now, they still seem to be testing them. Aliexpress will cancel the order if it’s not shipped out within X number of days.
The TC66C i ordered a few days ago says still processing (processing time 13days). I hope they will shipp it until then. The option to use it bidirectional is really helpfull. It makes checking the charge current (position of the device on the charger ) of my wireless charger much more easy.
I asked them and they told me that thay started shipping but they need time to Pack so many orders :cry:
we can only wait, and they won’t like disputes so they will send your package in time, :face_with_monocle:
"-6digit voltage and current, resolution is 0.0001V(0.1mV)/ 0.00001A(0.01mA)"
What is the accuracy in % for voltage and current readings?
Voltage measurement accuracy:±(0.05%+10digits at 23℃)
Current measurement accuracy: ±(0.1%+20 digits, at 23℃)
written in its Technical Parameters :crown:
My order is shipped. No the long wait beginns.
That means for example, that for 1.000A current your meter has accuracy of 1.000A+-1mA, so what the point of displaying 6-digit value, if you don't actually know last two digits at all?
