MTN Electronics: LEDs - Batteries - Lights - Chargers - Hosts - Drivers - Components - 1-Stop-US Source
8366 posts / 0 new
MascaratumB
MascaratumB's picture
Last seen: 36 min ago
contactcr wrote:
Clip:
https://www.aliexpress.com/item/Programmer-Testing-Clip-SOP8-SOP-SOIC-8-SOIC8-DIP8-DIP-8-Pin-IC-Test-Clamp/32831113149.html
Wires:
https://www.aliexpress.com/item/40pcs-20cm-2-54mm-1p-1p-Pin-Female-to-Fe...
Programmer:
https://www.aliexpress.com/item/1pcs-USBASP-USBISP-AVR-Programmer-USB-ISP-USB-ASP-ATMEGA8-ATMEGA128-Support-Win7-64K/32835212571.html
Using the above equipment I stripped and soldered the leads directly on to the pins because those plastic female connectors are too wide for that clip. If you use more expensive clip you can probably directly plug them in like this:
You can search Pomona 5250 if you want the fancy clip but it’s like $15+ and doesn’t work any better once it’s all wired up
Depending on your version of Windows we can help you find the right drivers too.
If you end up doing it and get all the stuff in feel free to message me i’ll help!
Shall I thank Party you or blame you Cash already? Silly
Thank you very much for pointing these out for me!! I will take a look on them, and enter a new “not” budget zone of B L F Big Smile
I already pass nights modding and few sleep, now will be flashling Facepalm Big Smile
Thanks, I may need some help when I get this! I’ll shoot a PM to you when it is time ! Gotta learn it first Wink Thanks again!!! Beer Beer Beer
[REVIEWS] AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// ACEBEAM: H20 / TK16 /// BLITZWOLF: BW-ET1 /// DQG: AA Slim Ti /// HC-LIGHTS: SS AAA /// XTAR: PB2 Charger /// OLIGHT: M2R Warrior /// WUBEN: TO10R / E05 / T70 / E10 /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// KLARUS: XT1C /// LUMINTOP: Tool AA V2.0 + Tool 25 /// LIVARNOLUX: 314791 /// SKILHUNT: M150
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2 /// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
GIVEAWAY: 1
ToyKeeper
ToyKeeper's picture
Last seen: 7 hours 28 min ago
contactcr wrote:
pre-compiled firmware “ready to go” … pick a light that is most similar to yours (FET+1 for example) and you can also pick Q8 for example if it’s going in a big light or D4 if it’s going in a small hot rod so it will step down differently.
It can be a little tricky though, since these builds were created for specific models and they might not work quite right in other hosts or on other drivers. There are often little details baked in which don’t translate well to other environments. For example, there is often a hardcoded “sane” level to help give the thermal algorithm some hints, and it’s calibrated for the heat-shedding capability of a specific host with specific emitters. Generally, each specific light’s response curves are hardcoded into its build, and the ramp shape won’t look right anywhere else.
For RMM, it’d probably be a pain for him to deal with. There’s a growing collection of build targets, and the code changes regularly, so there’s a lot of updating to do… and each driver would need a few different builds available for common types of hosts. RMM would probably need to maintain his own set of build targets to match his drivers. And it would only account for a small portion of sales, since people don’t buy a lot of e-switch drivers. It seems more common to reflash the driver which came with a light.
I try to make it reasonably easy to configure for arbitrary drivers and hosts, but it’s still not a trivial task.
contactcr
Last seen: 1 hour 8 min ago
Yea I try to pick a light of similar size/power and generally it’s good enough. (Q8 firmware on my C8F 21700’s has always worked fine)
Tom E
Tom E's picture
Last seen: 33 min 45 sec ago
TK brings up a good point on this. For example, every driver I build gets a uniquely voltage and temp calibrated, plus I got many driver configs supported, so it gets insane as far as possible combos. Also the MtnE driver designs are not the same as DEL's design. DEL's design is the basis for all NarsilM/Anduril lights - I mean all: Q8/Sofirn, Emisar, FireFlies, Astrolux, Lumintop, Mateminco, etc.
Will the MtnE drivers work with NarsilM/Anduril? Yes, I guess/suppose so when equipped with a ATTiny85 but I'd much prefer the design DEL came up with. One of the key features is the 4.7 ohm resistor directly off Batt+ before everything else: diode to the MCU. Also R1 and R2 should not be used, can be, but just adds to parasitic drain if present and not used.
Actually never thought or saw this listed before but we got 6 major light manufacturers using our designs now - pretty cool! But, big but, DEL doesn't get the credit he deserves.
DB Custom
DB Custom's picture
Last seen: 1 day 1 hour ago
On The Other Hand… I shove Anduril in lights without regard to their original hardcoded intention and just love how they work. Big Smile
Granted, you have to have an e-switch for Anduril, and it helps if you use like the D4 Anduril if you don’t have a lighted switch vs the Q8 Anduril if you do, but I use the programs with little regard to their intended target and simply love em, from the tiny Thorfire TK05 to my modded monster Q8 Ham’r.
Just sayin…
contactcr
Of all people I wouldn’t expect the two of you to be steering people away from this. Tell us how to use a multimeter and where to modify the code to calibrate voltage. It will be within a few tenths regardless so either way it will be “safe” I think.
As far as ramp tables. I think this is something a google spreadsheet with some formulas could solve right? Lets make it and write a brief post on where to edit that piece of code.
These don’t seem like reasons to discourage savvy modders from attempting this. I’ve not done any of this and my lights work fine.
Tom E
Tom E's picture
Not sure what you are asking... Think Anduril does voltage cal right in the UI, NarsilM doesn't - it should though. Temp cal is debatable whether you need it or not, based on how both version do temp regulation.
Ramp tables? What are asking for exactly? NarsilM has support built-in for a few ramp tables, so does Anduril. Right now, Anduril only supports "production" light configs while NarsilM supports custom drivers as well.
Basically, the driver types are: FET only, FET+1, FET+1+bank, and the tables may depend somewhat on the # of 7135's in the bank. In addition, there is 2 channel support for a buck driver. I think those are the primary variables, but there are others - what I/O pins are assigned to what, etc.
contactcr
Not to my knowledge
Correct, I dont mean this. Both versions are acceptable as is.
Tom E wrote:
and the tables may depend somewhat on the # of 7135’s in the bank
Yes this
A little of this though it hasn’t been an issue thus far
DB Custom
DB Custom's picture
I don’t see a “steering away” at all, just information to help achieve the best result…
Yourrid
Yourrid's picture
Last seen: 4 days 19 hours ago
All these replies and still no big announcement Tired
hank
hank's picture
Last seen: 1 hour 23 min ago
Did that flicker problem ever get solved?
I’ve found a dab ofconductive lubricant after cleaning contact areas often helps.
So does checking and smoothing off the spring contact points, which often are chopped off with some kind of wire nipper leaving a sharp point that can make intermittent contact after it’s scraped a bit and given you a gouged battery with some ridges and hollows.
ToyKeeper
ToyKeeper's picture
The tables can be generated by bin/level_calc.py in the repository. It typically requires some manual tweaking to get everything just right, but most of it is already scripted.
When people build their own versions for their own lights, it typically seems to work out pretty well. They can tweak everything to their liking, with all the options configured to taste. Making a generic version to sell on bare drivers for use in unknown hosts… is more tricky.
For example, take the relatively simple case of a FET+1 driver. We calculate a ramp for a light with one XP-L emitter at ~1500 lm. Then put that driver inside a host and run it. It’ll work well with a single XP-L emitter, but it’ll look weird when paired with something else. Give it a quad or something like an E07, and the ramp won’t look right. The FET portion will ramp up a lot faster than the 7135 portion. Or give it something lower-powered like a single XP-E2, and the ramp will look weird in the opposite way… the FET portion hardly even seems to go up at all:
That’s just one example, and a relatively simple one, but I hope the idea is clear. To get good results, the firmware needs to be configured and compiled for the specific hardware it’s used in.
DB Custom
DB Custom's picture
Sorry, I , uh, may have jumped the gun in my excitement. My Bad.
TK, all that is well and good if you are OCD about everything being smooth and equal. If you don’t mind seeing the power level jump, it really doesn’t matter and can actually be a big kick watching it Roar! Big Smile
Sprinkles
Last seen: 3 weeks 5 days ago
Just to be clear, Anduril is not yet available as an option from Mtn, correct? I’d like to try it in a mod, but wasn’t sure where to find a driver with that FW yet.
JasonWW
JasonWW's picture
Last seen: 4 hours 7 min ago
Simply look at the options on the website.
If you want a driver with Narsil or Anduril you typically need to buy one from Lexel.
Texas Ace Lumen Tube calibrated with Maukka lights
Click this to go to signature links.
ToyKeeper
ToyKeeper's picture
Correct, it’s not an option there. Probably because it’s not that simple. Details about why were discussed a few comments ago.
DB Custom
DB Custom's picture
Your best bet to find out what is available from mtn is to ask mtn…
Pavlo
Last seen: 1 hour 37 min ago
Anybody try the Samsung LH351d 4000k 90cri LEDs from MTN?
How is the tint?
Tom E
Tom E's picture
Yes, I ordered a bunch from MtnE. I like them, but can only speak for myself.
Pavlo
How do they compare to Nichia 219C?
Less green?
BlueSwordM
BlueSwordM's picture
Last seen: 1 hour 9 min ago
Less green, and more floody.
If shipping is too expensive from Mtn Electronics, you can get them in a whole variety of flavors, I mean color temps.
Superstocker
Superstocker's picture
Last seen: 1 hour 13 min ago
I have used several of those Samsung’s and agree with BlueswordM (not that my opinion adds very much to his). I think they are a decent bit less green than the 219C’s and I really like them a lot. I like putting them in S2s with an optic in front.
AlexGT
AlexGT's picture
Last seen: 3 hours 43 min ago
Maybe I missed it, what was the MTN announcement someone said a few posts back?
JasonWW
JasonWW's picture
It never happened.
BlueSwordM
Actually, Richard bought D18s and SST-20s.
JasonWW
JasonWW's picture
So the big news that was never announced was that he’s going to be selling the Emisar D18 and sst20 emitters?
BlueSwordM
I don’t really know, that’s just what Richard told me.
I think DBCustom is hiding something more… significant.
Lightbringer
Lightbringer's picture
Last seen: 2 min 37 sec ago
A talking mule?
contactcr
We can only hope it’s e-switch boost drivers with Narsil/Anduril and if it’s not can I just start this rumor so people ask him about it?
JasonWW
JasonWW's picture
But Richard doesn’t even use those UI’s. It would be nice to see the other sizes of boost drivers available, but that shouldn’t be a surprise.
