“For CC drop-down:PD stipulate that type-c interface has no output by default. When there is a drop down on the CC line (pin in the Type-c interface), PD charger thinks that the load is connected and then starts the 5V output. Therefore, it is normal for the tester to plug directly into the PD charger and not light. if CC drop down is enabled in the setting of TC66, when you plug TC66, it will automatically brighten the screen after it is set as enabled, but it may affect the normal charging process. If protocol detection and trigger are to be carried out, CC drop down must be enabled, and the back end shall not be connected with any load. If it is set to be off, the charging of PD charger will not brighten the screen, and the charging process will not be affected. Please first plug the tester into the charger and then insert the load.”
this is written in their Introduction
The TC66C i ordered a few days ago says still processing (processing time 13days). I hope they will shipp it until then. The option to use it bidirectional is really helpfull. It makes checking the charge current (position of the device on the charger ) of my wireless charger much more easy.
That means for example, that for 1.000A current your meter has accuracy of 1.000A+-1mA, so what the point of displaying 6-digit value, if you don't actually know last two digits at all?
Thats a very good point! Why adding digits if the accuracy is not there?
I still ordered one because of the bidirectional USB C connectivity.
And the accuracy is good enough for me (for the things i plan to use it for).
It looks like a nice device, but this 6-digit "feature" is nothing but marketing BS with goal to increase sale, because, you know, other similar devices have only 4-digit "accuracy".
The point is your TC66(C) device has useless extra two digits for voltage, current, and power, so why display it if those last two digits are basically noise and contain absolutely no useful information?
