It seems not strange. The curves of equal tint have negative second derivative(in uv coordinate). The tint of mix located at the line betwin tints of separated LEDs of mix(as I understand procidure of calculating UV is linear). The more difference betwin CCT of LEDs in mix the more negative Duv.
Yup, correct. That’s why with full range of available, we can custom engineer by mixing those E21A. No longer dependent to 219B sw45k.
I’m taking another beamshots now, stay tuned….
I don’t know of any suitable dual-channel driver yet for a flashlight. Something like 3 or 4 x 7135 on each channel would do it, and then it could be paired with a quadtrix in an S2+ or Skilhunt H03 behind a frosted optic, or perhaps as alternative, in a D4 body. I wouldn’t mind trading the D4’s high output for a tint-shifting option.
I would be more than happy to have nonmixing dual channel programmable driver. One channel for a daylight led the other one for night time led. But this can be achieved by using 2 regular drivers in one light
I will send some 3000K and 5000K (both D340 R70) to you and hopefully you can forward few fresh 219Fs to Koeff. They have been sitting in my box for almost a month. Have no time to test them.
To those placing order approximately last week, please be patient. Last week I broke my pinky toe. It was hard for me to moving around since I had to keep it slightly level with my heart all the time. Otherwise it will bleed and creates pain. I’m much better now and should be able to work normally in one or two days.
