Kiriba-ru, I would potentially be interested in some of those mag heatsinks with a larger pill. I was very happy with your other ones.
I dont plan making more mag parts. They are not popular.
Last 4pcs with soldered XHP50 are in stock.
Also, I have 3pcs of empty aluminium drop-in cases. They have threads inside so lower part of pill will be still 16mm, but it is possible to make the pcb shelf bigger (for different reflector or optics). If you are interested in this option, please choose what pcb and optics you are going to use.
Oh I see. Sorry for the confusion.
Received my order! Crazy fast shipping and great machine work. Will buy from again.
What type Maglite D Does the dropin fit? The older incandesent bulbs or led? I have a couple older D Maglites I want to upgrade.
I never had Mag D in my hands, but I suppose my drop-ins can fit any version if its bore is not smaller than drop-in size (34.25mm).
Received my order super quick! This was my 3rd order and each time it’s been efficient and exactly what I was expecting. I highly recommend!
Thanks Kirill!
Hi! Do you have any spacers for the Convoy M2 for a quad?
I will think about making some of them.
I would like one as well, prefer aluminum if given the choice.
Hi kiriba-ru, do you still had some of the maglite heatsink with XHP50 available?
Yes, few sets in stock.
What about a short tube for the Skilhunt H03?
No abilities to produce them right way.
I would like aluminium as well. My intended build won’t be high output and I don’t want to have to worry about galvanic corrosion between copper and aluminium.
My order arrived nice and safe over the weekend. It gets installed today, but I already opened it and the retaining ring threads into the pill like butter.
If anyone's wondering, it was packaged nicely and took 20 days to reach the continental US, with tracked shipping. As expected, and I'm quite pleased.
Mag D sets are sold out, but I still have 3 empty drop-ins.
Still have few empty (no pill inside) Mag D drop-ins. If anyone interested, I could try to make some bigger pill for different application (probably multi-led).
If nobody is interested in custom pill for bigger pcb or custom optics or etc., I will make same 16mm pills as were provided with my sets and sell them as is.
Would it be possible for you to make this spacer for the Convoy S11 host in copper?
It was designed by a Reddit user named DE-173 in this post. and they were kind enough to share their design for the spacer.
I have host on hands and can do a sample if you need.
Lets make it happen
