13576 posts / 0 new
Tally-ho
Tally-ho's picture
Last seen: 6 days 11 hours ago
One more reason with flashlights in moonlight mode : Purkinje effect
Even if an ideal flashlight has zero tint shift over its different modes, you are going to perceive a tint shift with a particularly low moonlight mode.
iamlucky13
Last seen: 41 min 29 sec ago
Tech25 wrote:
Interesting that I don’t see green in my Sofirn C01s on low or high. Green usually irks me like crazy- maybe the optic in this light helps?
Yes, the TIR in the CO1s will likely mix the beam differently than the reflector in the S2+.
Many LED’s, especially in reflectors, have a significant tint difference between the hotspot and the spill, and my experience is this difference gives you a more obvious means of comparison to notice bad tint in part of the beam.
I’d bet if the beam in the S2+ was diffused, the green would be less noticeable even on moonlight.
maukka
maukka's picture
Last seen: 2 hours 55 min ago
djozz wrote:
*light above the BBL looks uglier in low CRI than in high CRI
My experience is the opposite with the 219C. The original 5000K CRI80 is much nicer at similar slightly greenish duvs (~0.0030-0.0040) than the newer CRI90 variants. On a white wall at least.
saypat
saypat's picture
Last seen: 2 days 17 hours ago
These are ‘my impressions of this particular SST20 4000K 95+ CRI, yours may vary.[/quote]
Hi Teacher. I read that the lumen output with the specs your light has is about 600 lumens on high.. Do you think that is about right?
thank you.
patrick
BurningPlayd0h
BurningPlayd0h's picture
Last seen: 11 hours 20 min ago
thank you.
patrick
Here are the numbers Maukka got for that emitter
teacher
teacher's picture
thank you.
patrick
Hi saypat… I would say it is ‘at least’ 600 lumens or a bit better on High.
I see BurningPlayd0h posted some test results & that seems to be about right according to his posted chart.
I can’t get to my ‘Lumen Tube’ at the moment because of some remodeling…. but when I can I’ll measure it & see what I come up with. Thumbs Up
ToyKeeper
ToyKeeper's picture
Last seen: 1 day 10 hours ago
Yeah, the 219C 5000K CRI80 I have is actually pretty okay. It tends to make things look a bit lifeless, but overall it’s reasonably good compared to most LEDs I’ve tried. It doesn’t really look not-white during use, even though a camera tells me it’s greenish.
pirate joe 22
Last seen: 9 months 2 weeks ago
i hope this light is not too green at low lumens
spaceminions
If it is, the $1 swatchbook has minus green filter material, but really, the xpl version will just be poor cri with no particular greenness, and the sst20 or lh351d versions are going to be between yellow and green when you go hunting white walls and pretty okay otherwise. It should be fine.
Card Carrying CRI baby https://b.thumbs.redditmedia.com/laMC7BGhREfYTRQjYe2I5FMjTF1IjrmM6bPLK9SKEXU.png
amplificus
amplificus's picture
Last seen: 2 weeks 2 days ago
Decided to drop in on the progress of these lights, anyone care to give a synopsis on how the evaluation samples are coming?
ToyKeeper
ToyKeeper's picture
This is pretty off-topic, but anyone have any ideas how to make a strip of RGB LEDs work? There’s someone trying to make a fancy flow wand which draws things in the air while it moves, and I haven’t really tried to do anything like that:
http://budgetlightforum.com/node/66616
About more on-topic stuff though…
If I understand correctly, the optics might be in now… and then Neal is planning to send some lights for sanity testing to make sure nothing is broken. I haven’t heard any details yet though. Hopefully soon?
BurningPlayd0h wrote:
Shaved LH351Ds are quickly becoming my favorite emitter, for single emitter lights at least.
That’s something I still need to try. It sounds really promising. At least, it’s a good way to make use of those dog farts. Smile
amplificus
You mean like a neopixel strip or ws2812? 3 wires and all are individually addressable, lots of Arduino libraries out there for POV
Weidercs
Last seen: 1 month 1 week ago
+1 interested
Eraursls1984
Last seen: 1 week 3 days ago
Quote:
… and the sst20 or lh351d versions are going to be between yellow and green when you go hunting white walls and pretty okay otherwise. It should be fine.
This gets quite tiresome. No, it is green in use as well. Tint with yellow, or green are, for me, not noticeable outside in foliage. However, it is very noticeable in use indoors, or outdoors in a more urban area. So unless you’re in the woods, it is absolutely noticeable.
teacher
teacher's picture
/\ .. Yep. Thumbs Up
tatasal
Last seen: 3 hours 35 min ago
Mass production will commence after the QingMing Festival ( literally a day for tomb sweeping; but significantly a day for remembering past ancestors)
Leds to be used are the XP-L HI 3D .(~4875K)..as for the other led version(s), no definite news about them still.
MascaratumB
MascaratumB's picture
Last seen: 1 hour 1 min ago
Leds to be used are the XP-L HI 3D…as for the other led version(s), no definite news about them still.
Time to start putting some money aside! Cash
And to remember that I am running a GAW for a FW3A here Beer
Thanks for the update tatasal !!
[REVIEWS] ACEBEAM: H20 / TK16 /// AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// BLITZWOLF: BW-ET1 /// BRINYTE: T28 /// DQG: AA Slim Ti /// FIREFLIES: ROT66 GEN II /// HC-LIGHTS: SS AAA /// KLARUS: XT1C /// LIVARNOLUX: 314791 /// LUMINTOP: Tool AA V2.0 + Tool 25 /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// OLIGHT: M2R Warrior /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// SKILHUNT: M150 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 /// XTAR: PB2 Charger ///
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2/// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
OL Contest 2019
GIVEAWAY: 1 / 2
-X3-
-X3-'s picture
Last seen: 1 day 19 hours ago
Whatever, I’ll swap the LEDs anyway…
But I don’t see how the price would be the same between XP-L HI and SST20…
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
teacher
teacher's picture
Thanks for the update tatasal… Thumbs Up
QingMing Festival this year is 5 April 2019 by the way. Wink
teacher
teacher's picture
I ‘thought’ the XP-L HI was gonna be around $6 more per light. Question
raccoon city
raccoon city's picture
Last seen: 28 sec ago
From the OP:
emitter
-X3-
-X3-'s picture
Sorry guys…
Well, it’s a clever move from Lumintop.
Begin to produce the long awaited FW3A with XP-L HI, sell it for 36$ to evryone would can’t wait anymore after all this time…then you eventually put some SST20 in the production and sell more for 30$…
teacher
teacher's picture
I don’t think Lumintop is trying to do anything “clever”. It has been known for a very long time the XP-L HI was going to possibly cost around $6 more per light. It has also been known the other LED options have been, for whatever reason; hard to source.
ActiveAl
ActiveAl's picture
Last seen: 19 hours 17 min ago
tatasal wrote:
Mass production will commence after the QingMing Festival ( literally a day for tomb sweeping; but significantly a day for remembering past ancestors) Leds to be used are the XP-L HI 3D .(~4875K)..as for the other led version(s), no definite news about them still.
FWIW, the QingMing festival is on Friday, Apr 5 in 2019.
-X3-
-X3-'s picture
I wish I was as naive as you are, the world would seem like a better place.
Anyway, at least it move forward
Marc E
Last seen: 1 day 6 hours ago
teacher wrote:
The “Convoy S2+ SST20 4000K 95CRI” finally came in today.
Nice! I got mine too Big Smile
Not for me, i’ve been using a 4000K SST-20 for the last week or so on the low modes of a biscotti 1400ma driver and while it is immediately a bit green my eyes adjust within a few seconds of use (even with sunlight through windows as background lighting) at which point it just becomes a joy to use, sublime even (see what i did there :D), with no noticable tint just very useable light with great colours and depth perception (because of the green i think) which is exactly what i want.
In fact it’s (at least temporarily) put me off rosy tints, but that’s for another thread.
For this thread – i’ll be choosing the SST-20 4000K version Smile
Edit: Although from above it seems this is not confirmed as an option yet :S
x-ray
Last seen: 18 hours 14 min ago
Not wanting to delay any further but I was under the impression production samples were to be sent to a number of membrs for a final check over prior to full production commencing.
zak.wilson
Last seen: 9 hours 4 min ago
I wouldn’t put it past any manufacturer to structure availability to maximize profits, but that’s not what’s going on here. Looking at prices on Arrow, the cheapest XP-L HI is $3.50 in bulk quantities. LH351Ds are as low as $0.70, and single quantities of the popular 5000K, 90 CRI version are cheaper than bulk XP-L HIs. A search on Octopart finds the SST-20 in 4000K, 95 CRI is cheaper still, both in single and bulk quantities.
It wouldn’t surprise me if Lumintop’s per-unit profit is actually higher on the lower-priced high-CRI version, whichever emitter it ends up with.
Ceilingbounce – flashlight testing and runtime graphs for Android
Barry0892
Barry0892's picture
Last seen: 4 hours 7 min ago
It is a great light! really small but powerful as a 18650 light!
I didn’t read through the thread, how is the heat sink?
WhatsApp: +8615773183209
Facebook: https://www.facebook.com/barry.lee.984991 (my account is disabled cry)
ToyKeeper
ToyKeeper's picture
Something like that. But the discussion is over there, not here. Smile
I think it’s interesting, and I’m watching to learn from the thread, but it’s not really for my benefit. I just figure someone on BLF probably has the answers this person needs to make a cool shiny thing.
