Osram Ostar Projection PC-green tested, KP CSLNM1 F1
there is the KR CSLNM1.23
datasheet: https://dammedia.osram.info/media/resource/hires/osram-dam-5961110/KR%20CSLNM1.23_EN.pdf
617nm, up to 2500 mA and then just over 300 lumen. Probably an upgrade over the red XP-E2 but it is not a phosfor-converted red but a classic single wavelength led. I expect it can not be overdriven like blue leds can.
Wow, this is pretty interesting... Would be interested in getting a couple of these when available.
Looking at datasheets, two graphs (output vs current and output vs temp) also show that green flat looses output slower than white flat at higher currents and higher temperatures, which is in agreement with djozz' measurements(left white flat, right green flat):
One interesting thing is green flat output reaches max. at ~40-50C, but it's only 1-2% higher compared to 20C.
The relative flux looks almost identical to me (2.4times at 3A for both) ?
Green flat is a little bit closer to 2.5 than white flat, difference is small, temperature has much more visible effect, at 100C white flat is at ~89%, green flat at ~94%.
Thanks for this very interesting test!
So the luminance is around 400cd/mm^2 or even above that!
Unfortunately it has a green tint :person_facepalming:
Interesting to see the future results and parsing out the efficiency differences at high currents.
A Boost HX at 5000k is something to dream aboutā€¦
No one likes green, hhmmmm. But if there's a lot of green, that's good!
Djozz, could you please edit the opening post and fix the full of tracking sh1t datasheet link provided? Replace with the following:
https://www.osram.com/media/resource/hires/osram-dam-2494973/KP%2520CSLNM1.F1.pdf
Due to being long like a longaniza it breaks the page layout for small screen devices. Thanks.
P.S.: anything beyond a question mark or ampersand in a link usually is best removed.
I just put the second led that I got in my GT micro. I know, this nice flashlight deserves better than green, but I could not resist. The steps I took:
*Unsoldered the ledboard, unsoldered the XP-L Hi, added a little solder paste, soldered the Green Flat on the stock board
*had to use a new centerpiece with square cutout to center the led. Sanded it the same thickness as the stock centerpiece, made the cutouts with a scalpel to fit the Green Flat 45 degrees rotated.
*Reamed the reflector hole to fit the new slightly larger centerpiece. Canā€™t go back now to stock :person_facepalming:
*Closed the head and test: perfect focus on first try :nerd_face: , also tells that Lumintop did a good focussing job
*did a spring bypass on the tail (with tailboard in place).
Wow, that is a bright green spot. I carefully measured it (purple Efest battery, 30 seconds) at 7 meter with my best luxmeter: 177 kcd. I measured a few known lights to check the luxmeter (it reads high with an almost depleted battery), and it reads correct. The output (purple Efest, 30 seconds) I measured at 930 lumen, good enough, that would be between 3.5 and 4 A.
It does well outdoors as well, spot aimed at about 70 meter. :open_mouth:
So now I scratch my head what to use it for. Showing off to my son I guess :party:
Sorry about that, done :slight_smile:
waw thats cool i hope there come one deep red like that.
177 kcd in green, housed in a Micro... Wow! I want one for my 1504 - cant' imagine what it would do 500-600K?
Now I ave to get a couple more Micros. Are we seeing way better #'s than in a D1? I oculd only get in the 40's out of a D1, but didn't try any of the flats in one. Sliced SST-40 got in the 40's for me.
https://nl.rs-online.com/web/p/visible-leds/1814360/ i see they can buy at two leds?
The microā€™s reflector is more deep, but yeah itā€™s a damn good one for sure !
I managed to get 105kCd out of a Black Flat with only 3,2A at the tailā€¦ canā€™t wait to test with a better battery.
OTHO the better throw was about 60kCd in my D1 with the same LEDā€¦ and the better Iā€™ve read seems to be around 80kCd
Now whatā€™s the real world use for such an emitter ?
Something with hunters, they seem to like colours. But here in the city it is just for showing off. I can report that although you get your light a long way, the contrast of what you are illuminating is low (like in those IR-camera images). That is in theory so, but in practice very noticable too. A white led with less brightness is probably more useful. And taking this a bit further even: high CRI in your thrower would really help too for distuinguishing contrasts.
That colors are good for spot annimals to, not alone hunting.
If you see a fox on dark with normal colors it gone fast away.
with deep red i can let come a fox to me @ closer than 100 feet.
Unfortunately these projector leds do not come in deep red, so you have to make do with the horticulure leds that are not specifically designed for maximum luminance. On the bright side, Cree recently announced improved 660nm and 720nm XP-E leds.
I would love to see a PC-Amber version of this. This led looks like it would be fun to put in a Convoy L2 or some kind of recoil thrower though. The beam would look like a fat green laser beam.
