[♛ FreemeGB] Fireflies E07 7* Nichia/ SST20/ XP-L HI Emitters 21700 Flashlight Group Buy -【 New Copper+Titanium 】
616 posts / 0 new
BlueSwordM
BlueSwordM's picture
Last seen: 1 week 4 hours ago
Of course it will be floody.
Just a more usable beam since the SST-20 has 30% more throw than the XP-L HI, which helps offset the lower output somewhat.
Ekstasis
I just dont know the difference between 20kcd. and 41kcd. All i know the number is more then twice
djozz
djozz's picture
Last seen: 53 min 57 sec ago
20 kcd for an indoor light is very bright, 40 kcd is very very bright. I will not use the E07 indoors at max at all.
noboneshotdog
Last seen: 4 days 18 hours ago
Does anyone know the changed that have been made between the first version and now the newly advertised version two of this light. I don’t see any updated info on the Fireflies website.
Thier ain’t no bones in a hot dog. F. York
Tally-ho
Tally-ho's picture
Last seen: 1 hour 24 min ago
@noboneshotdog :
ichoderso wrote:
got an answer per mail from Jack today:
Improved a few things.
1. Round fins edge
2. longer body, 1mm longer to fit battery better
And they probably fixed the MCPCB issue.
noboneshotdog
Tally-ho wrote:
@noboneshotdog :
1. Round fins edge
Thumbs Up
DB Custom
DB Custom's picture
Last seen: 1 month 1 week ago
Kcd is broken down as thousand candela, so 20Kcd is 20,000 candela and 40Kcd is 40,000 candela. To figure throw based on candela you multiply x4 then take the square root of that answer to get a calculated throw in meters with a target of the light equivalent of a full moon, or approx 1/4 lux,
So 20Kcd is good for 282.84M throw and 40Kcd is good for 400m in throw. Not twice as far, just iver 1/3 as far. This lets you see that it isn’t linear. This is because it takes 4 times more light to reach twice as far and the candela reading is a measure of intensity, not quantity.
BlueSwordM
Guys, I used the Emisar D4S as an example for the throw difference between the 219C and SST-20.
I do not know about the real throw of the SST-29 at all.
DB Custom
DB Custom's picture
Optics make the differrnce less noticeable. I got my first SST-20’s in an E07, while the beam profile was pleasant tint shift had me pull that emitter quite fast…
Ekstasis
Have any one done a video that shows the difference in beam between the two ?
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 2 min 17 sec ago
I have experienced severe issues with my order from Banggood, especially about missing accessories and poor quality, see here:
http://budgetlightforum.com/comment/1483031#comment-1483031
Now, it already felt happy to read that BG customer service told me they would resend the item to me. Apart from that I understood they were offering me 1000 BG points as a token for the inconvenience caused. So, I replied back to them I would be happy to accept both resending the item and the 1000 BG points.
Now, I got another e-mail that sounds a bit different. Now, they are talking about "the spare part item". Any ideas how to read this? Will they be sending me a complete new flashlight with accessories or just the missing accessories ("the spart part item" does not sound like multiple accessory items)?
Luminous and wired, we'll be glowing in the dark.
mortuus
mortuus's picture
Last seen: 20 hours 50 min ago
it sounds so like they can send the extra stuff that was missing ? they must be able since u are supposed to get all that in the box and u didnt.
...where Frugal meets with Flashlight!
              つ ◕_◕ ༽つ
Lux-Perpetua
Well, if this was the outcome of my complaint they would still ignore the poor quality of my item. I was already surprised when they offered me a new item in the first place as usually I’m used to debate and fight for a little bit of compensation.
Lux-Perpetua
What a joke…after promising to resend the E07 (see e-mails above) Banggood now changed their mind and decided to only send me the clip and the o-ring…that’s all. Facepalm
iamlucky13
Last seen: 3 min 1 sec ago
Newlumen wrote:
iamlucky13 wrote:
Newlumen wrote:
Can someone tell me how to set thermal temp limit.. i want to make it higher. I dont like to read manual.
The manual really is pretty well laid out, and a good supplement to the graphic:
https://bazaar.launchpad.net/~toykeeper/flashlight-firmware/fsm/view/hea...
Thermal config is under blinky modes, starting at line 74. It might seem complex, but each step is very simple.
From off:
  • Triple click to enter blinky modes (starts at battery check)
  • Double-click to sunset mode
  • Double-click to beacon mode
  • Double-click to temp-check mode (will blink out the current temperature)
  • Click 4 times rapidly to enter thermal config
Light will blink once, signaling temperature calibration, then start “buzzing” or blinking rapidly. If you want to set the ambient room temperature (do this when the light is cool), while it is “buzzing,” click the number in degrees Celsius (eg – 21 degrees C or 70 degrees F, click 21 times).
When done, or if you want to skip temperature calibration, wait for the “buzz” to stop. Light will blink twice, signaling temperature limit, then start “buzzing” again. Click N times to set the maximum temperature as N + 30 degrees C, then wait for the “buzzing” to stop. So if you want 55 C, click 25 times.
Its little complicated. I think i got it by watching matt video.
3 clicks, 2 clicks, 2 clicks, 2 clicks, 4 clicks.
14 clicks. My room temp is 58 fahrenheit.
25 clicks.
Right ? It doesnt step down like it used to be.
Sorry for the slow follow up. That is correct. You should be good to go with a calibrated thermal sensor and a 55 Celsius limit. It should still step down, but more slowly, and not as far, and the body will get hotter.
mortuus
mortuus's picture
wow sigh… that is not ok….. the manufacturer should take responsibility for missing items.
              つ ◕_◕ ༽つ
DB Custom
DB Custom's picture
Taking responsibility is not a 2019 thing.
Agro
Agro's picture
Last seen: 2 min 38 sec ago
Oh, it is. Some just take the word “responsibility” out of it. Smile
Though really – that’s not specific to 2019.
DB Custom
DB Custom's picture
I have what appears to be a nice black version two E07, XP-L HI emitters in the high power option 6500K tint with blue auxillary LED’s. Full package, adapter, o-rings, manual, clip and even Samsung 40T. Most would think SWEET, but the problem is I actually paid for two GT Micro’s which I do NOT have.
So I have $90 tied up in the E07 package sitting there unusable to me. (I have to consider it not mine as it isn’t what I ordered) My buddy, the guy one of the GT Micro’s was ordered for, anxiously awaits his White Flat GT Micro and I have no idea when or if it’s gonna happen. (Right, I was gonna mod it, both actually)
And so it goes… responsibility, the hidden gem of the new world.
mortuus
mortuus's picture
wow so bizzare…. but who got the other package wrong then, must be someone here on BLF maybe ? i dont get it… tell them u dont want the lights u didnt order and they must fix this somehow.. hahah
              つ ◕_◕ ༽つ
DB Custom
DB Custom's picture
Neal’s Deals, he knows, is supposedly figuring out who didn’t get the E07 they paid for… haven’t heard anything for some three weeks now.
BurningPlayd0h
BurningPlayd0h's picture
Last seen: 24 min ago
Here’s a comparison of the X-PL HI and SST-20 in a D4S. Both are around similar output/lumens here, the high CRI 4000K SST-20 will have slightly lower output.
saypat
saypat's picture
Last seen: 49 min 18 sec ago
Eve and Adam pre 2019
aginthelaw
aginthelaw's picture
Last seen: 6 hours 32 min ago
saypat wrote:
• • • Eve and Adam pre 2019
are you referring to the adult toy store?
never fear shadows…it means a light shines nearby
mattadores
mattadores's picture
Can anyone help with this issue?
I received my Fireflies E07 Friday of last week and it has a strange issue that my Fireflies PL47 has never had:
I will take a video to show you what’s happening but when I ramp up to the top of the ramp (not turbo) the light flickers very heavily and rapidly once it reaches the top of the ramp. This happens if I keep holding the button or if I release the button as soon as it reaches the top of the ramp. The flickering happens most of the time and can last anywhere from 2 – 10 seconds.
It also happens if I save the top of the ramp setting as the memory setting and turn the light off then on again.
Like I said, my PL47 doesn’t have this issue and is totally stable once it reaches the top of the ramp
AnhTran
Hi friend, what is the coupon code for buying directly from fireflies?
Lux-Perpetua
mattadores wrote:
[…]when I ramp up to the top of the ramp (not turbo) the light flickers very heavily and rapidly once it reaches the top of the ramp. […]
To me this sounds like there’s a lot of contact resistance, probably caused by grease/dirt on conductive areas. Please try following:
- unscrew the battery tube and the tailcap
- get some IPA (isopropanol) or contact cleaner and q-tips
- clean the non-anodized front face side and end face side of the battery tube
- clean the springs on the driver side and on the tailcap
- clean the outer rim on the inner side of the taicap (that area where the battery tube end side makes contact with the tail cap)
- clean the terminals on your battery (positive and negative side)
- screw down everything again and try again to see if there’s still flickering
Nite Shadow
Nite Shadow's picture
Last seen: 14 hours 16 min ago
Also, a copper washer in the tail cap may also help.
These are the ones I use:
“Unique Bargains 10PCS 24mm OD 16mm ID 2mm Thick Copper Washer Flat Ring Oil Brake Line Seal” found on Wally World site.
They are a bit thick but the thinner ones I got are slightly warped and I don’t like them as much.
YMMV
mortuus
mortuus's picture
code is in the first post.
              つ ◕_◕ ༽つ
jojosupir
jojosupir's picture
Last seen: 5 days 20 hours ago
Any news about cu+ti e07 edition?When will they open for sale?
