(prototype) the GT Mini
It varies Spiderlight, sometimes the top of the ramp is maximum, sometimes it’s not… depends on the UI and how it’s set up.
Well, I am using the default UI and settings. I think it the same as the BLF Q8 uses, and if I am right, I never used turbo on the Q8 either.
I think that’s like my haiklite mt09r…?
I had interested parties, but this revision ramps to 50% then double tap to turbo… This modded gt mini ramps all the way…
Anduril does the double tap to Turbo, unless you change the settings. I think Narsil just goes straight up to the top by default but I haven’t played with a Narsil driver in a while…
Q8 uses NarsilM v1.0. It ramps all the way to the top.
GT Mini is using NarsilM v1.3. It was coded on this light to stop just short of Turbo.
Thank you.
But the momentary mode 5x click is instant turbo, right?
Yes, that’s one of the new features the Q8 doesn’t have.
mmalive: Are you still interested? Your mailbox is blocked.
Received the replacement from Banggood (complete flashlight) and this works excellent. I tried more than 60 clicks and did not miss any. Good customer service of Banggood.
Good for you :+1: They’re still giving me the run around :rage:
Is there still a Banggood rep on here?
there is but they only post the usual codes etc to get more money… just keep push them in mails that u got a defective light and uwant a replacement head or full refund if they dont want send out replacement.
Oh I’m trying! Is online chat any easier/better?
yeah it cant hurt to try.
Must be nice. I gave up on getting them to send me a NW instead of the CW they sent. Their attitude was basically “the flashlight works, what is the problem?”
I’m getting fed up with them as well, please tell us know how you worked your magic.
Hi, I got a GT Mini as BD present from a commercial source. Love the light, it’s smart, bright and tiny, but it seems button issues went to production. It requires quite a pressure and this force needs to be applied through a thick rubber. Something like bicycling in deep sand. Even if it clicked it’s not sure it got the command. With randomized sensitivity to button clicks modes part settings and use is more than challange. I’m not complaining, I’m amazed by the efforts and results in community flashlight world, this is just a respectful feedback.
Is your rubber switch cover aligned properly or crooked?
The smiley head is slightly tilted right and the bunny on the tube is not fully aligned with the button. Approx five degrees. Does it make a difference?
The bunny on the tube makes no difference.
The switch might… although it it not that far off.
Try pinching the rubber boot & pulling up on it a bit… then let go & see if that helps.
I can’t see your pic, but it should look like this.
(By Lock)
Some people report a mushy feel if it’s slightly rotated.
