For those who use the original MT09R driver (not the TA or Lexel driver), it is highly recommended to exchange the SIR800 MOSFET by a better one that can be driven up to 100A (e.g. Infineon) if you plan to bypass your springs.
You don’t mean the “original” driver (that one was rubish), your talking about the current, stock driver designed by TA. That’s the one that has the weak FET.
There’s 4 drivers for the 70.2 version and it can be hard to keep track.
So now I can also confirm it MCU and FET on the HL drivers for this light are faked from some chineese manufactory
MCU has not even unusual markings it has even a spelling error missing an S in the type
“ATMEL20U”
“TINY85”
“7 digit batch number” while the original Atmel has
“ATMEL 4 digit batch”
“TINY 85”
“20SU”
“triangle”
and 3 rows batch data on the back side where the fake has nothing
I have measured the FET used on the red MT09R driver
its labeled like the original Vishay cant tell any difference Original@10A and 4.7V Gate https://eu.mouser.com/datasheet/2/427/sir800dp-93246.pdf
SIR800 —> 2.6mOhm —> 26mV —> 0.26W
the SIR800 has pretty stable resistance down to 2.5V Gate voltage so its a good FET for 1S lights as well
Fake @4.7V Gate like the MCU delivers to the FET
I got 38.3mV 10A —>3.8mOhm resistance
@3V Gate
I got 165mV 10A —> 16.5mOhm
@2.5V which the original should have around 2.8mOhm as its gate voltage gets very deep till 2V pretty stable
I get only 2A with reasonable input volatge and the stunning drop on the FET of 1.1V
so here the FET has 0.55Ohm
Conclusion
the FET HL use is definately some sort of fake which wont work on any 1S driver well
with 4.7V on gate it has a usable resistance but still this FET is like the MCU fake
So i just completed bypassing all my carrier springs with 20AWG, using x4 VTC5A flat tops, did a 35s run on max output and my stock FET is still working! 20AWG in driver spring and all carrier springs
i recently got a set of the Murata version of the VTC5As, strangely i measured 2,000 lumens gain over my regular VTC5As in my MT09R all springs bypassed, I’m not sure if my regular VTC5As are fake or genuine but aged cells?
Sigh… Haikelite has good product lines, but the brand is cheap to its management as they don’t mind using fake components and caused so much trouble to customers. Mine MT03 TA had faint leaking light during off and after spending month negotiations with CS to get a new driver from Haikelite and I paid for shipping, the new driver was having same issue. Desoldered and measured both fake SIR800 to be having around 50Mohm of resistance with 0Vgs, they are not completely open.
I replaced the FET with real SIRA60 and it works fine. Also replaced the FET of another driver with BSC009 and put it into old MT03 II, it works fine too. Now these two MT03 are always in momentary mode with 5clicks, have had blasting them side by side for 1+ hour in accumulation, almost burn my hands as they are really hot.
Good thing was Haikelite forced me to learn how to use hotair gun. After watching some YouTube video, i managed to solve it to good ending.
