What did you mod today?
9503 posts / 0 new
contactcr
Last seen: 2 hours 34 min ago
The previous one was turbo using a Samsung 50E
This is 3×7135 default mode when you screw on cap. I had anywhere from .0014 to .0019 in this mode
The tint shift from SST-20’s really bothers me so this is a nice result in my opinion. Essentially the same results across the entire output range. The hot spot is much wider now so no more “pointing” with the light. Gotta adjust your use case I suppose. The light heats up the body nicely now so the MCPCB was a success as well.
bilakos10
bilakos10's picture
Last seen: 2 days 10 hours ago
I legoed my S43 (modded with LHD351D) with an SS bezel and body from an S42S and I think it came out pretty dope.
I also sanded the bezel in order to remove the old S42 logo.
djozz
djozz's picture
Last seen: 8 hours 47 min ago
I’m not fond of the S43, but I must admit that you make it look much better!
djozz
djozz's picture
A colourful lighted tail for my Supfire S1 EDC with 4000K LuxeonV led and BLF-A6 driver. Looks better in reality, the camera does not capture 470nm, 500nm and 660nm even close to correct.
470 Ohm bleeder on the driver
470 nm led + 22K resistor
500 nm led + 33K resistor
600 nm led + 6.8K resistor
625 nm led + 12K resistor
660 nm led + 6.8K resistor
PCpink led + 22K resistor
The tail draws 0.86 mA current, a 700mAh 16340 battery will be drained in about a month. Because I carry and use it every day, the battery is recharged way sooner than that.
MtnDon
MtnDon's picture
Last seen: 2 hours 57 min ago
The picture overfloweth…
…that can be rectified
BlueSwordM
BlueSwordM's picture
Last seen: 1 week 1 day ago
Thank you. I usually resize images, but didn’t do it this time.
Some flash copper solution that I managed to make myself, a zincate solution.
I’m now ready to copper plate lights Smile
Firelight2
Firelight2's picture
Last seen: 1 hour 42 min ago
Swapped the Oslon white flat I had in my Jetbeam RRT-01 2019 for an XPL HI 5000k. The beam isn’t as throwy, but I like the better tint, extra lumens, and spill.
Also swapped the LEDs in my Jetbeam TCR-01 triple for 3 Oslon flat whites. GAAAAAH….. what an ugly beam!!! Sick
Oslon flats are nice emitters for max throw at low current, but clearly they don’t belong in a small triple.
CRX
CRX's picture
Last seen: 19 hours 15 min ago
What optic?
I just put a Nichia 219B in a TC-R1.
Geuzzz
Geuzzz's picture
Last seen: 49 min 48 sec ago
CRX wrote:
What optic? I just put a Nichia 219B in a TC-R1. !{width:99%}https://i.imgur.com/4z2uztj.jpg!
Super nice light, looks much better than the newer jetbeam imo.
DB Custom
DB Custom's picture
Last seen: 1 month 3 hours ago
All it needs now is an accompanying beam shot… Wink
DB Custom
DB Custom's picture
Firelight, I was thinking about putting 7 White Flats in an E07, bad idea?
oweban
oweban's picture
Last seen: 28 min 41 sec ago
Killed a Wowtac A2S (dogfarts edition) today. Was getting flickering on turbo so went to re-soled wires with something thicker, but it’s just too damn fiddly and I don’t have silicone coated wire. And now I’ve lifted a trace from the driver board. Still works when put together outside the case, but is a nightmare to get back in and running,
Wonder if Wowtac will sell a driver board, or if I’m SOL :/
contactcr
Pre-tin new wires and use a tiny amount of flux paste on the driver and wire end. I don’t always do this but anytime I feel like the wire might not want to cooperate or i have a small spot to work with this seems to get the job done twice as fast without overheating any tiny components.
DB Custom
DB Custom's picture
The center SST-40 died once more, so I rebuilt Ham’r once again. This time some things have changed… we now have a 3V 50.2 to play with! Big Smile
So, essentially the center emitter is a quad in it’s own right now and that means there are 20 dies in Ham’rs somewhat quirky head. And now, with my meter calibrated and my lumens numbers somewhat lower than they used to be, it reads 21,200 lumens in Turbo and 17,000 lumens at the top of the ramp. Turning it on after a cell change it does 7000 lumens at the full 7135 chip setting. Can’t complain about that!
oweban
oweban's picture
Cheers, I’ve never been good at remembering flux. Getting the iron in the opening is a nightmare, so I’m almost on the “well there goes $60” train. I might try and contact Wowtac and hope for the best though. Although not like doing the same with Olight got me anywhere, sigh.
KawiBoy1428
KawiBoy1428's picture
Last seen: 7 hours 42 min ago
You could also try Thrunite, it’s the same driver. Thrunite has always been good to me. Wink
KB1428 “Live Life WOT
Firelight2
CRX wrote:
What optic?
My TCR-01 is currently sporting a Noctigon triple star and a Carclo 10507 optic.
The reflector compartment in the TCR-01 has a handy ledge in it just big enough for a slightly filed down 20mm triple Noctigon. And it’s just at the right height for a standard Carclo star without lens. Slather on some Arctic Silver 5 on the sides of the compartment around the ledge, insert star and you’re good too go as a triple. Might need to lengthen the driver wires slightly I think.
That said, I’m thinking of converting this back to a single-emitter light. It was really cool when I made this light a triple several years ago. But now that I’ve experienced high-power FET driven triples and quads, the low-power driver in the Jetbeam just isn’t ideal for a triple.
Based on what I saw with my triple TCR-01 I suspect 7 White Flats in an E07 won’t produce a very attractive beam. In my TCR-01, I get a narrow hotspot as expected, but it also has less throw and spill than a single-emitter XPL HI in the same light. And the beam with the White Flats is cool tint and very ringy.
Also, I tried a white flat in a 1×14500 zoomie with FET driver and the beam turned blue and dimmed almost instantly. Granted this was with an unusual star where I have the LED mounted on a narrow pillar the same width as the LED made of 4 strips of copper and arctic alumina. The LED sits on the pillar and the pillar sits on the Noctigon.
This setup isn’t as good at removing heat as sitting the emitter directly on the Noctigon, but I wasn’t encouraged by seeing the beam turn blue in a fairly low-powered setup, especially when other LEDS like XPL HI and SST20 worked fine in the same setup. I’m not sure 7 white flats in an E07 will even work at full FET.
Best use for the White Flat seems to be when you want max throw and are willing to sacrifice beam pattern, tint, lumens and CRI to get it. It actually worked pretty well in the new 2019 RRT-01. The low-powered driver wasn’t enough to damage the emitter, and it produced good throw with the small smooth reflector (Vinh measured a similar RRT-01 at 400 lumens and 30k lux).
One tip for anyone working with White Flat: the pads at the bottom don’t quite line up exactly right with a Noctigon XP star. You may have to move the emitters back and forth a few times during reflow to confirm that neither positive or negative is accidentally connected to the central heatsink bondpad. With White Flat, I recommend using a multimeter to check your star prior after reflow prior to installing it in your light.
Agreed. The old RRT-01 and TCR-01 look better than the new 2019 RRT-01 in my opinion.
The older models also feature better feeling rings, are lighter weight which is better for pocket EDC, and have a more cylindrical shape which feels better in the pocket.
I think the new version’s driver may be slightly higher powered though. I wonder if the drivers are identical in shape. Maybe I should pull the driver out of my 2019 RRT-01 and install it in my TCR01.
DB Custom
DB Custom's picture
I got an interesting light today, it’s from Ludicrous Lumens in Great Britain. The Night Saber Alpha with 67mm aspheric and a pistol grip that houses 2S 18650’s. This came with an XM-L2 but is only on/off, no modes. Didn’t take me long to get a White Flat in it with an LD-4A 6A driver. Smile 345Kcd using a Samsung 30Q and a dummy cell. Pretty neat, physical build is decent enough but the electronics and lack of o-rings is depressing.
Nice enough once it gets some new quality hardware, not really worth the price as shipped though, in my opinion.
oweban
oweban's picture
Thanks so much – although I’m looking at their website and their right-angle headlamps appear to be XHP70.2 and XHP35 HI, is it the TH20 driver? Feeling pretty dumb right about now.
contactcr
It doesn’t look like it’s completely focused like maybe the head needs to be further out? I think there’s probably more room for gains cause the Z1 does a bit more. I see they have several other 67mm lights with different configs and this pill system.
DB Custom
DB Custom's picture
The picture from my phone doesn’t show the tight hot spot. I modded it further with a White Flat that does some 345Kcd on an LD-4A at 5.5A. They offer the brass pill with other emitter choices, well a few, mainly XP-G2, for like $15 apiece. Should have gotten some, the pill is left hand thread…
Trees in the beam are at about 535 yards distance…
Dougiestyle
Dougiestyle's picture
Last seen: 1 month 1 week ago
Newbie’s second mod… Put a XHP 50.2b 5700 (3V) from Cutter into a S2+ with FT medium spot TIR and swapped A17-DD. Hella hawt on turbo!!
MascaratumB
MascaratumB's picture
Last seen: 4 hours 34 min ago
Does it have an aespheric lens or reflector, Dale?
Seems a nice “thrower”!
[REVIEWS] ACEBEAM: H20 / TK16 // AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 // BLITZWOLF: BW-ET1 // BRINYTE: T28 / PT18pro / PT28 // DQG: AA Slim Ti // FIREFLIES: ROT66 GEN II // HC-LIGHTS: SS AAA // KLARUS: XT1C // LIVARNOLUX: 314791 // LUMINTOP: Tool AA V2.0 + Tool 25 // NITEFOX: UT20 / ES10K / K3 // ODEPRO: KL52 / B108 // OLIGHT: M2R Warrior / OW Mini // ON THE ROAD: M1 / i3 / M3 Pro / 311 / Z821 / i5 // ROVYVON: A2 + A5R / E300S / A8 / A23 / E200u // SKILHUNT: M150 / M200 // SOFIRN: SF14 + SP10A / SP32A / SP10B // WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 / E12R / E61 // XTAR: PB2 Charger // Mods: 1 / 2 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Collection /// My Review’s Blog (PT) /// OL Contest 2019 /// GIVEAWAY: 1 / 2
DB Custom
DB Custom's picture
It’s a fairly large aspheric. Looks pretty clear and free of bubbles or warps. Not AR coated like the Z1 glass though.
MascaratumB
Thanks for the explanation and photos Dale!
Seems a nice light to mod as you did Wink
If it had a push-pull “zooming” function (B158 style) would be even nicer for some flood here and there!
Any possibility to post the link of purchase, in case I wanna give it a try, please? Thanks again Wink
DB Custom
DB Custom's picture
It has fast threads to screw out the head for zoom. Wink
Ludicrous Lumens in Great Britain is where I got it. It’s apparently an Alpha and the model is Night Saber in 67mm, they have a 50mm as well.
MascaratumB
Thanks so much Wink Will give a look at it!!
Firelight2
De-tripled my Jetbeam TCR-01 last night. Previously it had 3x Olson Flat White with Carclo 10507 optic. Now it has 1x XPL HI 4000K 5A2 with orange peel reflector.
The new setup produces a more pleasing beam. However the light doesn’t look as unique aesthetically.
First time I’ve de-tripled a light.
Nachtfeuerzeug
Nachtfeuerzeug's picture
Last seen: 2 hours 20 min ago
I've been taking my long, sweet time for this one but when I saw the Luminus SST-40, I knew it would be going into this large plastic,  OP/SMO reflector, Utilitech thrower:
https://1drv.ms/f/s!AqeZmZFhBiGK3EGnMCKsGQwQWWBl
I had to file down the star a bit and tapped screws to ensure heat went into the body in the hope it wouldn't get too hot and destroy the reflector.
I'm trying the linear driver first and perhaps, I'll bump up output with a FET driver.
EDC
FW3A, SST20 4000K || S21A, Crescendo Mtn20DD, LH351D 4000K || SP32A, SST40 5000K
Recent/ongoing Mods:
S2+, TexAven 17mm, LH351D | S21A, Crescendo 20mm, LH351D 4000K | L2 w/Mtn17DD Zener Guppydrv, XHP-50 | C8+ OP, DD XHP-50
SP32A w/SST40 5000K | SK Zoomie Nichia 5000k, C2 driver | EagleTac clip | Ultrafire C2 w/5A 17mm & XM-L2 | Nichia 219C 2700K with gray S6 |
Reviews:
Sofirn SP31 v2.0 Tactical Flashlight (Cree XPL HI) || Sofirn SD05 Scuba Diving Flashlight || Sofirn SC31 USB Rechargeable (XP-G3)
contactcr
Nice battery spacer.
