13583 posts / 0 new
nqcken
Last seen: 1 week 2 days ago
please add my name to the list for two. tx
teacher
teacher's picture
Last seen: 7 months 4 weeks ago
Pocket clip color change??
  • 1. I don’t see a change, what is it?
  • 2. Who cares anyway, as long as it isn’t pink.
Tally-ho
Tally-ho's picture
Last seen: 1 week 1 day ago
The new pocket clip seems to be black. Wink
Compared to the previous prototypes :
FW3A Team wrote:
zak.wilson
Last seen: 19 hours 2 min ago
While I generally like black, painted clips chip over time and look bad. I’ll come out against this, but buy the same number regardless of the finish on the clip.
Ceilingbounce – flashlight testing and runtime graphs for Android
MokrySedeS
Last seen: 1 hour 5 min ago
Yeah, I don’t like the black clip either, but I don’t care as long as I can get rid of the paint with some acetone.
mortuus
mortuus's picture
Last seen: 57 min 35 sec ago
is there more angles of the latest prototype ? hard to see the clips color in that angle really.
...where Frugal meets with Flashlight!
korkfoto
Last seen: 23 min 59 sec ago
Rusty black, to be more precise.
FIAT LUX!
EnlightenMe
As long as it’s durable, I don’t care at all about its color. Adding/removing paint is pretty dang easy.
iamlucky13
Last seen: 3 hours 48 min ago
I can’t tell from the photo if it’s painted or some kind of conversion coating like black oxide or parkerizing.
Or perhaps its light playing tricks on the photo.
Personally, I don’t have a strong preference one way or the other. I just hope the community doesn’t make collectively as big of deal about the clip color as we went through about the body color.
zak.wilson
The community has collectively made a big deal out of
  • The body color
  • The body shape
  • The surface finish
  • The emitter options
  • The color rendering index
  • The color temperature
  • The tint bins
  • The battery compatibility
  • The optics
What gives you the idea there’s any chance the clip color/finish will be different? But I’ll buy just as many regardless.
teacher
teacher's picture
Hmmmm, ‘personally’ I do not see black; just lighting anomalies. But that & any other speculation is counterproductive at this point. It is useless. Time will tell.
cabfrank
Last seen: 2 hours 2 min ago
The good news is new prototypes are being sent out, so hopefully we will have info soon. Also that “should” mean we are close to production. Maybe.
cabfrank
Actually, it says samples are being sent, not prototypes, which may be even better news. Maybe.
mortuus
mortuus's picture
closer production then this it cant be since they are releasing those lights if it gets ok from those people they will start production so that sounds positive to me.
Tally-ho
Tally-ho's picture
Sorry, we didn’t say that the production version will have a black pocket clip but this is definitely black and it is not due to a lightning anomaly.
The problem is to know if they are going to adopt this black clip for the production version or if it was just a color test that they finally rejected.
It is not the first and unexpected “drift” from the initial prototype, so we would like to know for sure what the production version will definitely looks like.
- “Maybe a black painted button to match the pocket clip ?”
ToyKeeper
ToyKeeper's picture
Last seen: 24 min 3 sec ago
I liked the silver clip, and I liked that the tip section was smooth. It has a good texture for thumb fidgeting.
Not really excited about a black clip, or having an extra hole in the end. Color will probably scrape off, and it already has a better place to attach a lanyard.
Would be nice if the only change was to fix the driver fit issue.
cabfrank
Yes, that would be nice. I don’t care about the clip at all, but I see no reason for making silly changes at this stage of this very long saga.
Firelight2
Firelight2's picture
Last seen: 2 hours 21 min ago
While the bare clip might be slightly nicer, I don’t think Lumintop’s decision to go with a black clip is enough to punt it back and hold up production.
As long as the light works and the driver fit issue was corrected, it might as well go into production as-is.
teacher
teacher's picture
Tally-ho wrote:
teacher wrote:
Hmmmm, ‘personally’ I do not see black; just lighting anomalies. …. (snip)…..
(snip) …. but this is definitely black and it is not due to a lightning anomaly.
….. (snip) …….
‘Maybe’ your right and it is painted Black. I am still going with a lighting anomaly.
But I will say this, if it is paint; it appears to be a very poorly done job. There is still a lot of silver visible.
You can start with either side of your ‘red arrow point’ & then go right on to the edge of the clip to see silver.
If whoever orginally posted this picture would chime in, the mystery could be certainly solved……
Either way, it is what it is…… Beer
Firelight2
I think that’s just a lighting anomaly. The white on the clip in that reflection looks to me to just be reflections off a shiny black clip.
teacher
teacher's picture
Time will tell…… Thumbs Up
ToyKeeper
ToyKeeper's picture
In general, white and black are just the same color at different brightness levels. A white reflection on a black clip doesn’t mean there’s silver showing through.
The pic makes it look like the clip is painted black, but the pic was also taken by a potato cam. We might not know for sure until items arrive for testing.
koziy
Put me on the list for whichever version comes out first, if that’s SST-20 or what.
treth
in for 2 thx
RZRNUT
Last seen: 11 months 4 days ago
I would like one!
Helios azimuth
Last seen: 5 hours 49 min ago
Please sign me up for one.
Tally-ho
Tally-ho's picture
I hope you are right.
This clip with the extra hole is from the first prototype.
Maybe they add a black o-ring underneath to avoid this clip version to spin and wobble on the production sample, because they were short of the latest clip.
I won’t speculate more, time will tell. Sorry for the disruption.
Cody_carries_stuff
Last seen: 12 months 13 hours ago
I would like two (2) lights.
teacher
teacher's picture
Maybe they add a black o-ring to avoid this clip version to spin and wobble on the production sample, because they were short of the latest clip.
I won’t speculate more, time will tell. Sorry for the interruption.
Honestly, I ‘hope’ I’m right to. “Hope” being the key word. Smile
For the life of me I just cannot understand why they would suddenly change to a painted clip. Facepalm
But, I do realize; stranger things have happened. Big Smile
Take care Tally-ho… I guess we will find out before long. Beer
funkychateau
funkychateau's picture
adnj wrote:
The FW3A team is doing a good job at keeping everyone informed. Thanks!
tatasal wrote:
April 8th, 3:41pm FW3A update:
Barring any unforeseen circumstance, this week, 2 samples will be sent to 2 members here in BLF and one sample to a member in TLF.
The final approval from the three persons will pave the way for the light’s mass-production.
As usual, in the meantime, Beer
A photo of the version of the sample light to be sent to the 3 members:
(Isn’t it a thing of beauty?) Cool
!{width:70%}[img]https://i.imgur.com/p55dXJE.jpg[/img]!
Reviewers, please check fit of button-top cells. Thanks!
