There will be those that will argue it’s not harmful to the cells, although I disagree. To each his/her own, I paid for all mine so I get to say how they are cared for or abused.
Let it be said that with 230+ lights on hand, and cells in every one with a good collection of reserve cells on standby… I have over 300 cells of various sizes and branding. Seriously. And I have only recently started having cells die off on me, old cells that have been used pretty harshly. I’m taking the safe route, usually. . . .
The closest thing I can think of is the way that certain Boost drivers work. They can draw a certain number of amps on Turbo with a fully charged battery and as the battery voltage drops, the current will start to go up, but only up to a certain point. If the battery voltage drops too much and requires too much current it will simply not activate that Turbo mode. Instead it’s highest mode will be less than Turbo so as to keep the battery amp draw at a reasonable level.
Or maybe you mean like a Boost driver on Low mode that draws something like 1 amp continuously all the way down to the point it activates its low voltage protection?
I know a little bit about how Boost, Buck and FET drivers work, but maybe your talking about some other design?
Thank you TK for you detailed and informative review!
Double thank you for creating an amazing tint-mixing design that looks incredible!
I’ve just created a thread because I talked to Hank and he’s confirmed that he’s willing to build custom tint-mixed versions of the D18 for anyone for an additional $15!!
During my voltage testing, the M43 usually decreased in brightness when I turned down the voltage. However, a couple times, it didn’t. I don’t know what changed, but once in a while it would maintain approximately the same brightness regardless of voltage.
So I’m not sure what happened, but I have a guess. It looks like the current regulation might be controlled directly by the MCU, and it looks like the firmware might have a bug in its current regulation code. Most of the time it didn’t appear to work correctly, but once in a while, it worked fine. The behavior was very strange and unpredictable.
I tested at other levels too, not just 120 lm. I saw similar voltage-related sag at all levels… except once in a while when it didn’t happen.
As for the D18, I tested some other levels on FET+N+1 drivers too. As expected, the FET levels sag with voltage. The +1 levels are almost completely stable. But I saw something weird in the N+1 levels — they sagged too. And I’m not sure why. Maybe my PSU was having difficulty, or maybe there’s actually something not working right in the driver. At some point, I’ll have to do some battery-powered runtime graphs at like 3x7135 or so, to find out if it stays stable during actual use or if it sags.
What confuses me is that you tested a Nx7135 level on the ROT66, and found it almost completely flat. So it should work, but when I tried it, it didn’t. I guess I have a mystery to investigate.
The M43 has a typical Carclo 10507 beam pattern, which is basically a big wide hotspot with almost no spill. There’s a faint glow around the hotspot, but it’s very dim. Almost all the light is in the hotspot, and it’s pretty wide so I describe it as a wall of light. During use, I find that the hotspot is so wide that the edges of the hotspot light up nearby objects and this near-field illumination can make it difficult to see things in the distance.
The D4S beam looks more like a traditional reflector. It has a small and bright hotspot, and around it is a much dimmer but still usable spill area. The brightness looks like a flat round plate with a can of soup stacked on top, right in the middle. It’s basically two levels, like a - shape.
The D18’s beam looks similar to the D4S, except it also has a corona around the hotspot. So more of the light falls in the spill area, which gives it a lower cd/lm value. The brightness looks like that same “plate with a soup can in the middle”, except the soup can is surrounded by a hill of mashed potatoes. I guess it’s more of a .-. shape. Or, another way to picture it is an upside-down cup on top of a small hill. Or, now that I think about it, it’s shaped like a boob in cold weather. The D18’s brightness chart looks like a boob.
Perhaps I can get a beam shot with all three, but the tints are all different so it’ll look weird. They also each have pretty large beams so I’ll have to put them fairly close to a wall in order to fit them all in one frame.
For now, I’ll just make a diagram to describe approximately how the light is distributed within the beams:
Yes. The D4’s moon mode was relatively bright, because of the firmware used. The D4S’s moon mode was relatively bright because it had three 7135 chips on that channel instead of just one. The emitters used probably also play into things here, and some variation between individual lights. But I’ve found the D18’s moon mode is lower than either the D4 or D4S.
I love me some large and full hotspots, with smooth transitions to minimal spill. It’s all the light where I want it, very little where I don’t want it.
If you’re looking at a wide area which is all roughly the same distance away, the M43 works really well. For example, standing at the edge of a forest, looking at the tree line. Or looking at the nearest side of a building. It’ll provide a very evenly-illuminated view of something like that.
If you’re walking down a sidewalk or a road and want to illuminate the entire path going forward, the D18 beam works well. It gets more intense as it gets closer to the center, so if it’s aimed into the distance it illuminates the path to roughly the same brightness regardless of distance. This is my favorite beam type, overall.
If you want to look only at something in the distance, the D4S beam is a bit better. It won’t illuminate the near field as much. But it’s not what I’d call a thrower. It’s just toward the throwy end of EDC-style beams. It can still be used to illuminate a path going forward, but the hotspot has a sharp enough edge that the brightness of the path varies.
For really seeing something in the distance, none of these are throwy enough. I’d suggest a D1 or D1S for that.
The reach of the hotspot isn’t necessarily flat, it does still have some taper to it. Here is Maukka’s actual measurement of the YLP Gryphon 180’s beam profile (beam pattern very akin to the likes of M43, ROT66, MF01). Note that it is using XPG2 emitters in this particular case, so it is a bit throwier/the taper of the hotspot is a little more dramatic, than something with say, XPLs or 219B/Cs.
Here is Maukka’s measured graph of the ROT66’s beam pattern with 219B emitters. Similar or same style of optics, but less throwy LEDs. I expect that the ROT66 with SST20s is a little more like the XPG2 graph above.
It’s interesting that Q8 tube seems merely 7% thicker. Considering tube width alone, 16% larger volume and 33% more cells. This suggests that the tube of D18 is very thick, especially since the Q8 one is not particularly thin already.
I think no one will buy M43 or D18 to use it during months in moon light or years in standby)
correct, I agree with first but not with second
But I buy this type of light for many lumens. So I interesting in stabilisation at hi level. Graph for 4A(max using 30А 18650) and 8A(turbo using 18650GA) modes with cooling.
This means that I not need to use fully charged 18650 after each 20s of work to get rated lm.
not correct. M43 can work using 18650GA at full output.
I even say in different output range.
But no one want to use abacus instead computer. or mail instead email, isnt it?). The more complicated devise the better, but the more easy operation the better.
… is throwier. You can change(or ask Hank) leds and optics in both D18 and M43
… has a wider output range, going both much lower and much higher. Much lower - yes, much higher - 9klm vs 14klm it is not much.)
… is less likely to activate by accident. Is electronic lock and unscrewing not enough?
… is easier to use. subjectively
… has a bunch of extra modes and firmware functions. Most of them are funny but not usefull. but yes Anduril is great UI
TK, my M43 takes 18 micro amps in standby mode. So, according to your measurements, it is quite the opposite, M43 will last longer on standby.
My copy of M43 with XP-G2 (7291 Lumen):
