6. Batch "TA" 1S or 2S Bistro HD OTSM/NarsilM drivers 15-47.5mm size fit, S2+, C8, H03, MF01, MT03, Q8 Clicky or E-switch
hello, am i able to order a 30mm driver for an Convoy L6?
Yes, Lexel will send you a personal message asking you what options you want.
Is there a possibility to tactically use the tail button in the Convoy L6 with Narsil or Andúril as in the Sofirn C8F 21700?
Yes
For the initial power on option you can choose two blinks, turbo or nothing.
this is for NarsilM Anduril I dont know how to change that start up
L6 30mm diameter driver, NarsilM 2S either Blink at the tail cap or Turbo at the tail cap?
I’m in for 1. Already PMed you Lexel.
OK.
Thanks.
Interested in one L6 NarsilM, PO=turbo.
I have also made a crowdfunding campaign for the new reflow oven as I will not make the drivers more expensive
Hi Lexel, I’d need a 30mm 1S driver for a tail-clicky host (Olight M22).
Bistro UI would be cool
sure there is the 24-30mm Bistro 1S possible to build
Can I get a quote by private message please?
I would like to buy (2) 20mm drivers for the Convoy M21A & Convoy S21A
I’m fairly comfortable with a soldering iron but have never “modded” a flashlight. What would I need to add Narsil to my Astrolux MF01?
First, you would need to swap in a new driver that was already setup with NarsilM. That’s pretty easy. The potential hard parts with the MF01 is if it’s not an early unit, it will probably be glued shut and very difficult to open. Secondly, the emitters will probably be set up at the wrong voltage requiring you to cut traces on the led board (mcpcb) and add jumper wires.
I would start by seeing if you can get the front bezel off your light.
You don’t list your location, but if your in Europe you might be able to ship it to Lexel for a conversion. Outside of Europe the shipping costs go way up.
BTW, do you know about the new MF01S It would be way cheaper to sell your current one and buy the new one since it already comes with many improvements. No NarsilM, but Anduril is based from it with nice ramping and user adjustable features.
Ooh the MF01S looks interesting! When is it supposed to ship? I just put my name on the interest list.
Hi. I am new here and dont understand much about these custom drivers.
Probably this is right place to get new driver for my Convoy C8+. I need driver capable of moon mode, some regulated modes and turbo. Was thinking about BLF A6 driver, but there are only two mode groups which doesnt suit me much. I need something like this - moon, 1x7135, 8x7138, turbo. Or 1x7135, 8x7135, turbo. All without memory. Can it be done an how does it will cost to ship to EU? Need it to be plug and play, so I can solder only two wires. Thanks.
To make an order simply PM me
Bistro drivers like C8 can be user programmed for different mode groups, no memory like you want
Spring and wires can be added for some extra fee
I ship from Germany
I also made an update on new driver wiring
Shipping has to go up as today the post increased the costs
Germany +0.1€
International +0.2€
tracking +1€ international
Just installed the Q8 driver running Anduril… It’s amazing! Thanks a lot Lexel!
