TK's Emisar D18 review -- 3x18650 photon grenade
I’m really not sure what you mean by this.
The closest thing I can think of is the way that certain Boost drivers work. They can draw a certain number of amps on Turbo with a fully charged battery and as the battery voltage drops, the current will start to go up, but only up to a certain point. If the battery voltage drops too much and requires too much current it will simply not activate that Turbo mode. Instead it’s highest mode will be less than Turbo so as to keep the battery amp draw at a reasonable level.
Or maybe you mean like a Boost driver on Low mode that draws something like 1 amp continuously all the way down to the point it activates its low voltage protection?
I know a little bit about how Boost, Buck and FET drivers work, but maybe your talking about some other design?
Thank you TK for you detailed and informative review!
Double thank you for creating an amazing tint-mixing design that looks incredible!
I’ve just created a thread because I talked to Hank and he’s confirmed that he’s willing to build custom tint-mixed versions of the D18 for anyone for an additional $15!!
CUSTOM Emisar D18 builds are AVAILABLE!
Here’s one:
FWIW, I updated comment #2 with info about tint mixing. Before now, it just said “reserved”.
During my voltage testing, the M43 usually decreased in brightness when I turned down the voltage. However, a couple times, it didn’t. I don’t know what changed, but once in a while it would maintain approximately the same brightness regardless of voltage.
So I’m not sure what happened, but I have a guess. It looks like the current regulation might be controlled directly by the MCU, and it looks like the firmware might have a bug in its current regulation code. Most of the time it didn’t appear to work correctly, but once in a while, it worked fine. The behavior was very strange and unpredictable.
I tested at other levels too, not just 120 lm. I saw similar voltage-related sag at all levels… except once in a while when it didn’t happen.
As for the D18, I tested some other levels on FET+N+1 drivers too. As expected, the FET levels sag with voltage. The +1 levels are almost completely stable. But I saw something weird in the N+1 levels — they sagged too. And I’m not sure why. Maybe my PSU was having difficulty, or maybe there’s actually something not working right in the driver. At some point, I’ll have to do some battery-powered runtime graphs at like 3x7135 or so, to find out if it stays stable during actual use or if it sags.
What confuses me is that you tested a Nx7135 level on the ROT66, and found it almost completely flat. So it should work, but when I tried it, it didn’t. I guess I have a mystery to investigate.
The M43 has a typical Carclo 10507 beam pattern, which is basically a big wide hotspot with almost no spill. There’s a faint glow around the hotspot, but it’s very dim. Almost all the light is in the hotspot, and it’s pretty wide so I describe it as a wall of light. During use, I find that the hotspot is so wide that the edges of the hotspot light up nearby objects and this near-field illumination can make it difficult to see things in the distance.
The D4S beam looks more like a traditional reflector. It has a small and bright hotspot, and around it is a much dimmer but still usable spill area. The brightness looks like a flat round plate with a can of soup stacked on top, right in the middle. It’s basically two levels, like a - shape.
The D18’s beam looks similar to the D4S, except it also has a corona around the hotspot. So more of the light falls in the spill area, which gives it a lower cd/lm value. The brightness looks like that same “plate with a soup can in the middle”, except the soup can is surrounded by a hill of mashed potatoes. I guess it’s more of a .-. shape. Or, another way to picture it is an upside-down cup on top of a small hill. Or, now that I think about it, it’s shaped like a boob in cold weather. The D18’s brightness chart looks like a boob.
Perhaps I can get a beam shot with all three, but the tints are all different so it’ll look weird. They also each have pretty large beams so I’ll have to put them fairly close to a wall in order to fit them all in one frame.
For now, I’ll just make a diagram to describe approximately how the light is distributed within the beams:
ish
Yes. The D4’s moon mode was relatively bright, because of the firmware used. The D4S’s moon mode was relatively bright because it had three 7135 chips on that channel instead of just one. The emitters used probably also play into things here, and some variation between individual lights. But I’ve found the D18’s moon mode is lower than either the D4 or D4S.
I love me some large and full hotspots, with smooth transitions to minimal spill. It’s all the light where I want it, very little where I don’t want it.
D18’s beam profile doesn’t sound too tempting.
Thank you TK for the additional picture I asked for and for your thoughts between M43 and D18. :+1:
Yeah, it really depends on what you’re doing.
If you’re looking at a wide area which is all roughly the same distance away, the M43 works really well. For example, standing at the edge of a forest, looking at the tree line. Or looking at the nearest side of a building. It’ll provide a very evenly-illuminated view of something like that.
If you’re walking down a sidewalk or a road and want to illuminate the entire path going forward, the D18 beam works well. It gets more intense as it gets closer to the center, so if it’s aimed into the distance it illuminates the path to roughly the same brightness regardless of distance. This is my favorite beam type, overall.
If you want to look only at something in the distance, the D4S beam is a bit better. It won’t illuminate the near field as much. But it’s not what I’d call a thrower. It’s just toward the throwy end of EDC-style beams. It can still be used to illuminate a path going forward, but the hotspot has a sharp enough edge that the brightness of the path varies.
For really seeing something in the distance, none of these are throwy enough. I’d suggest a D1 or D1S for that.
Out of the D4S & D18, is the D18 closer to the Convoy L6 in terms of beam pattern?
No clue, sorry. I haven’t seen a Convoy L6.
Since the L6 uses a traditional reflector though, and a fairly large one, I’m going to guess that its beam is probably similar to the D4S or D1.
I’ll just look up some data…
Okay, it looks like the L6 gets about 18 cd/lm.
The D4S gets about 6 to 14 cd/lm (depending on emitter type), and the D1 gets about 33 cd/lm. So the L6 at 18 cd/lm should be halfway between the two.
The reach of the hotspot isn’t necessarily flat, it does still have some taper to it. Here is Maukka’s actual measurement of the YLP Gryphon 180’s beam profile (beam pattern very akin to the likes of M43, ROT66, MF01). Note that it is using XPG2 emitters in this particular case, so it is a bit throwier/the taper of the hotspot is a little more dramatic, than something with say, XPLs or 219B/Cs.
Here is Maukka’s measured graph of the ROT66’s beam pattern with 219B emitters. Similar or same style of optics, but less throwy LEDs. I expect that the ROT66 with SST20s is a little more like the XPG2 graph above.
It’s interesting that Q8 tube seems merely 7% thicker. Considering tube width alone, 16% larger volume and 33% more cells. This suggests that the tube of D18 is very thick, especially since the Q8 one is not particularly thin already.
If you look at volume I agree.
I think no one will buy M43 or D18 to use it during months in moon light or years in standby)
correct, I agree with first but not with second
But I buy this type of light for many lumens. So I interesting in stabilisation at hi level. Graph for 4A(max using 30А 18650) and 8A(turbo using 18650GA) modes with cooling.
This means that I not need to use fully charged 18650 after each 20s of work to get rated lm.
not correct. M43 can work using 18650GA at full output.
I even say in different output range.
But no one want to use abacus instead computer. or mail instead email, isnt it?). The more complicated devise the better, but the more easy operation the better.
  • … is throwier. You can change(or ask Hank) leds and optics in both D18 and M43
  • … has a wider output range, going both much lower and much higher. Much lower - yes, much higher - 9klm vs 14klm it is not much.)
  • … is less likely to activate by accident. Is electronic lock and unscrewing not enough?
  • … is easier to use. subjectively
  • … has a bunch of extra modes and firmware functions. Most of them are funny but not usefull. but yes Anduril is great UI
I already told you about you M43. Contacts should be cleaned.
“Measurements”: http://forum.fonarevka.ru/attachment.php?attachmentid=155792&d=1450446799 of M43 xpg2 S3 via 50k$ integrating sphere 7620lm at 30s.
just no one tried here)
He was asked by YLP (or yarkiy luch) so soon it will be in series flashlight.
TK, my M43 takes 18 micro amps in standby mode. So, according to your measurements, it is quite the opposite, M43 will last longer on standby.
My copy of M43 with XP-G2 (7291 Lumen):
All four M43 lights of mine have a parasitic drain value of ~20 μA.
Thanks ToyKeeper for sharing your expertise with all of us you do great work.
I was gonna buy one until I started reading this thread. Now I think I’ll buy one in every flavor. Most informative thread on a Flashlight and it was all done in less than 100 posts. Thanks guys, especially you TK. your info was articulate explicit as well as entertaining
Perhaps I just got a bad M43. It doesn’t perform how other people say theirs perform. This is how mine behaved in a water-cooled runtime test at full power. The brightest it got was about 5000 lm.
I measured standby current on mine too. At boot time, without pressing anything, standby drain was about 96 uA. But if I press the button to turn the light on and off, the button changes from red to green, and then it uses about 67 uA.
On a D18, standby current measured at 30 uA. It could be lower by not enabling BOD, but then it would be hard to get out of momentary mode. It needs at least some parasitic drain to make it possible to reboot the MCU by loosening the battery tube.
For a FET driver, it’s normal advice to clean the contacts, bypass the springs, make sure the batteries are full, use new high-amp cells, etc. So I do. But it seems like strange advice for a boost driver. Isn’t a boost driver designed to deliver consistent output even without these things? It is meant to perform the same even if the cells aren’t quite full or even if the contacts aren’t completely clean.
That’s why I use a ZebraLight as a calibration reference light — it emits the same amount of light regardless of what battery it has or how recently I cleaned it. But I don’t use a Meteor for this purpose, because its output is highly variable and chaotic. I never know how much light it’s going to make.
:person_facepalming:
I think you’re conflating concepts in order to make a point which isn’t strong enough to make otherwise. If complicated was truly better, we would be living in a steampunk world full of Rube-Goldberg machines.
I recognize that it is common to think of “simple” as primitive, basic, dumb, or unable to do much… and to think of “complicated” as powerful, advanced, and capable. But that doesn’t accurately represent how things work out in practice. Simple things are often more useful, while more complicated designs generally have more problems.
A lot of tech follows the same pattern as it becomes more mature:
  • Phase 1: primitive (simple + basic)
  • Phase 2: developing (complicated + basic)
  • Phase 3: fancy (complicated + advanced)
  • Phase 4: mature (simple + advanced)
It can be tempting to view phase 3 as the end of this process. That’s where things look the most impressive, with all sorts of fiddly bits to make it look sophisticated. It’s the steampunk aesthetic. And I like steampunk… I decorated my living room that way. It’s fun.
But although phase 3 is powerful, it often solves the wrong problems. Complicated things may be easy to do, but people don’t actually need to do those things very often. The things people need are often inconvenient in a phase-3 product. For example, ever hand someone a ZebraLight and then they ask “how do I make it a little bit brighter?” It’s weirdly complicated to do that simple task on a ZebraLight. It can take like 20 clicks to go up one level.
