I too remember somewhere around the $40 mark early on in the development of this lantern. That was just for a basic no frills lantern.
But what this has evolved into is far from a “basic no frills” lantern.
And the “estimated” price of $50, as stated in post #3759; is an absolute bargain!! <span class=“time”@ this at unit per $50 around be to cost the estimating is manufacturer “the #3759… post from @quote”>
Remember folks, $50 is the estimate at this time.
Key Words
$50
estimate
at this time
DSBAR, I think you have done & are doing a stellar job with this project!! Thank you….
And as been mentioned before, thank you for NOT going the cheap route just to meet some mythical unrealistic idea of a budget lantern price.
This lantern is gonna be a game changer I think!!
estimate
an approximate calculation
approximate
close to the actual, but not completely accurate or exact
Additions since 3/31. If you haven’t already done so please verify that your BLF name is correct on one of the 2 spreadsheets referenced in post #2. No valid name means no PM when they are sent out.
For those verifying that their blf name is correct you must check one of the links on post #1. Those are the names stored in my database and will be used for generation of pm’s. The names are taken from the same table on both lists so you can use either one.
Thanks
Edited to change the post number to the correct one.
Ooops sorry….yes it’s post number 1. The files in the links are the correct ones and the names, etc are generated from my database. I’ll correct my prior post to fix the error.
