What did you mod today?
My TCR-01 is currently sporting a Noctigon triple star and a Carclo 10507 optic.
The reflector compartment in the TCR-01 has a handy ledge in it just big enough for a slightly filed down 20mm triple Noctigon. And it’s just at the right height for a standard Carclo star without lens. Slather on some Arctic Silver 5 on the sides of the compartment around the ledge, insert star and you’re good too go as a triple. Might need to lengthen the driver wires slightly I think.
That said, I’m thinking of converting this back to a single-emitter light. It was really cool when I made this light a triple several years ago. But now that I’ve experienced high-power FET driven triples and quads, the low-power driver in the Jetbeam just isn’t ideal for a triple.
Based on what I saw with my triple TCR-01 I suspect 7 White Flats in an E07 won’t produce a very attractive beam. In my TCR-01, I get a narrow hotspot as expected, but it also has less throw and spill than a single-emitter XPL HI in the same light. And the beam with the White Flats is cool tint and very ringy.
Also, I tried a white flat in a 1x14500 zoomie with FET driver and the beam turned blue and dimmed almost instantly. Granted this was with an unusual star where I have the LED mounted on a narrow pillar the same width as the LED made of 4 strips of copper and arctic alumina. The LED sits on the pillar and the pillar sits on the Noctigon.
This setup isn’t as good at removing heat as sitting the emitter directly on the Noctigon, but I wasn’t encouraged by seeing the beam turn blue in a fairly low-powered setup, especially when other LEDS like XPL HI and SST20 worked fine in the same setup. I’m not sure 7 white flats in an E07 will even work at full FET.
Best use for the White Flat seems to be when you want max throw and are willing to sacrifice beam pattern, tint, lumens and CRI to get it. It actually worked pretty well in the new 2019 RRT-01. The low-powered driver wasn’t enough to damage the emitter, and it produced good throw with the small smooth reflector (Vinh measured a similar RRT-01 at 400 lumens and 30k lux).
One tip for anyone working with White Flat: the pads at the bottom don’t quite line up exactly right with a Noctigon XP star. You may have to move the emitters back and forth a few times during reflow to confirm that neither positive or negative is accidentally connected to the central heatsink bondpad. With White Flat, I recommend using a multimeter to check your star prior after reflow prior to installing it in your light.
Agreed. The old RRT-01 and TCR-01 look better than the new 2019 RRT-01 in my opinion.
The older models also feature better feeling rings, are lighter weight which is better for pocket EDC, and have a more cylindrical shape which feels better in the pocket.
I think the new version’s driver may be slightly higher powered though. I wonder if the drivers are identical in shape. Maybe I should pull the driver out of my 2019 RRT-01 and install it in my TCR01.
I got an interesting light today, it’s from Ludicrous Lumens in Great Britain. The Night Saber Alpha with 67mm aspheric and a pistol grip that houses 2S 18650’s. This came with an XM-L2 but is only on/off, no modes. Didn’t take me long to get a White Flat in it with an LD-4A 6A driver. :slight_smile: 345Kcd using a Samsung 30Q and a dummy cell. Pretty neat, physical build is decent enough but the electronics and lack of o-rings is depressing.
Nice enough once it gets some new quality hardware, not really worth the price as shipped though, in my opinion.
Thanks so much - although I’m looking at their website and their right-angle headlamps appear to be XHP70.2 and XHP35 HI, is it the TH20 driver? Feeling pretty dumb right about now.
It doesn’t look like it’s completely focused like maybe the head needs to be further out? I think there’s probably more room for gains cause the Z1 does a bit more. I see they have several other 67mm lights with different configs and this pill system.
The picture from my phone doesn’t show the tight hot spot. I modded it further with a White Flat that does some 345Kcd on an LD-4A at 5.5A. They offer the brass pill with other emitter choices, well a few, mainly XP-G2, for like $15 apiece. Should have gotten some, the pill is left hand thread…
Trees in the beam are at about 535 yards distance…
Newbie’s second mod… Put a XHP 50.2b 5700 (3V) from Cutter into a S2+ with FT medium spot TIR and swapped A17-DD. Hella hawt on turbo!!
Does it have an aespheric lens or reflector, Dale?
Seems a nice “thrower”!
It’s a fairly large aspheric. Looks pretty clear and free of bubbles or warps. Not AR coated like the Z1 glass though.
Thanks for the explanation and photos Dale!
Seems a nice light to mod as you did :wink:
If it had a push-pull “zooming” function (B158 style) would be even nicer for some flood here and there!
Any possibility to post the link of purchase, in case I wanna give it a try, please? Thanks again :wink:
It has fast threads to screw out the head for zoom. :wink:
Ludicrous Lumens in Great Britain is where I got it. It’s apparently an Alpha and the model is Night Saber in 67mm, they have a 50mm as well.
Thanks so much :wink: Will give a look at it!!
De-tripled my Jetbeam TCR-01 last night. Previously it had 3x Olson Flat White with Carclo 10507 optic. Now it has 1x XPL HI 4000K 5A2 with orange peel reflector.
The new setup produces a more pleasing beam. However the light doesn’t look as unique aesthetically.
First time I’ve de-tripled a light.
I've been taking my long, sweet time for this one but when I saw the Luminus SST-40, I knew it would be going into this large plastic, OP/SMO reflector, Utilitech thrower:
https://1drv.ms/f/s!AqeZmZFhBiGK3EGnMCKsGQwQWWBl
I had to file down the star a bit and tapped screws to ensure heat went into the body in the hope it wouldn't get too hot and destroy the reflector.
I'm trying the linear driver first and perhaps, I'll bump up output with a FET driver.
Nice battery spacer.
Uh, yeah, about that spacer… you want to always put the spacer behind the cell not in front of it. The reason for this is that if the spacer manages to short against the body if it’s at the rear it will only cause the light to come on, bypassing the switch. If it’s in front of the cell it’s positive and a short will not be good, at the very least damaging your light and causing it to not function…
Thank you! It's super simple but I just use what's on hand and whatever pops in my head.
It can be a good heat sink as well.
Great point! I learned a lot from the Cometa discussions. This light came with a foam spacer. Just to make sure, I'll add some electrical tape around the caps. Card board sleeves stop the rattle.
Truth be told, the copper will anodize and reduce transmission… you’ll have to periodically clean the ends with something like De-Oxit Gold. :wink:
Anodize
Solder blobs to the rescue?
It's bizarre that the inside of the cap stays shiny but the outside oxidizes. I scraped the patina and took some DMM measurements just to check on performance.
