Convoy L2 XHP50.2 K2-1C outdoor performance
i’m waiting for the driver
L2 XHP50.2 must run on 2pcs cells
Hi Simon, do you possibly have some update ?
H1-A driver makes it possible with a single cell. Available in LHT Flashlight Store and its sister shop Kaidomain. I have one running inside a super modified SK98, using additional stacked R100 + R330 + R330 sense resistors for up to ≈4.20A of output current without issues (using an additional 47µF output capacitor too).
Cheers ^:)
driver for XHP35 HI?
i got the sample ,
i will get suitable gasket soon
The entire L2 flashlight with XHP35 HI :slight_smile:
i’m ready to launch L6 with XHP35 HI ,
the original reflector of L6 is not suitable .
manufacturer is designing new reflector and gasket
Hi Simon,
Can you please give us some more information about the XHP35 HI driver?
Is it a new developed driver from your usual supplier or does it come from KD?
Will it also work 1S (1x 26650) or 2S (2x26650) only?
What is the maximum current it can apply to the XHP35 HI?
What diameter sizes of the driver can you offer?
Thank you!
Looking forward to it Simon, Thank you for going to the extremes for us! :slight_smile:
Thank you Simon, in return I’ll keep buying Convoy as most often of all :beer:
This is going to be awesome. Be a great addition to the collection.
2A output ,diameter 30mm ,
only runs on 2*26650
what’s the max intensity of BLF GT?
i got a L6 reflector today ,it’s bad ,
i use L2 reflector ,i got 160000CD if XHP35 HI runs on 2A current
(the bin of XHP35 HI is D4 50E)
Okay, so it’s not possible to boost to 12V with only one battery. :frowning: I guess Kaidomain’s H1-A will still need some tuning for providing 1.5A to the XHP35HI from a single cell. But I see that Sofirn will soon launch the C8G (1x 21700 with XHP35 HI, SMO and 2.000lm). In my opinion the Convoy L2 makes much more sense with XHP35 HI. The L6 is quite a large light for this little amount of lumens (max. 2.000lm), its small reflector diameter in comparison to its length and its moderate power consumption. The XHP35 HI is - to my mind - for throwers and the L6 is more or less an allround-like flashlight but no thrower, perfect for XHP50.2 or XHP70.2. Just sayin’… :wink:
According to Jensen567's figures the H2-C still did well at “2A” gear, but pay attention to the already low efficiency at that point (1S input with R075 + R075 sense resistors). Since high mode uses a 60 second stepdown you may try an R100 over the stock R050 (2.25A maximum), but beware of the low efficiency risks, high current losses in switches, springs, etc.
If I were Simon I would go to driver designers and manufacturers and tell them to “stop complaining and make an outstandingly powerful driver, this is for enthusiasts”.
boosting to 12V with only one battery can be designed,But the efficiency is too low,
The BLF GT has 800 to 1200kcd. Depends on how good batch one get.
Simon, just so you know, Richard at MTN Electronics has designed a Boost driver that works with one or two cells and delivers 2.3A to the XHP-35. This is good for over 2000 lumens in your C8+. :slight_smile: Perhaps you should work out a deal with Richard?
For what it’s worth, this same driver of Richards also excels in the L2, amazing lights these 2! :smiley:
Oof that would be super expensive.
Maybe a special BLF edition at 70-80$US?
uh ,thanks,i still want to install XHP35 HI in L6,
At present, the design of the reflector is not ideal.
I put a 3v XHP50.2 in my L2 @12A (single cell). it’s a nice light, easy to focus. just guesstimating by eye, CD is a little higher than stock, but quadruple the lumens.
About the anodizing, my l2 came like it was wrapped in sandpaper compared to the super smooth ano from the S2+’s
Can I buy drivers on aliexpress or banggood. I want to upgrade convoy L2 with XHP70.2. Thank you
