Literally only one of those things has changed though.
ANYWAAAYY…
Can’t wait for these… Modding them will still be fun ,too, it turns out :slight_smile:
Are we there yet??
I want to buy this flashlight.
Please, add me to the list.
Thank you.
This light is turning 2 next month :smiley:
Still looks like new :slight_smile:
Timeless design!
Two years is hard to believe, and I’ve read all 8350 posts in this thread. I’m not the only one, either. I guess we sure do like our lights.
I’m fearlessly predicting now that this will be done by Christmas. :wink:
Yep, it should be here by Christmas 2020!
Call me what you will but I think I like the revised grey version better than the original…
Should I be interested in the LH351D version at all? What will it do differently than the XP-L? I’m thinking about adding a second one to my request and I’m wondering if I should get one of each.
The first post has not been completely updated, but it looks like the second option will likely be the Luminus SST-20, not the LH351D.
The main difference is those two options would 4000K color temperature (warmer appearance) and high CRI, which will be most noticeable when viewing objects with lots of red tons in them, like skin and wood tones.
The SST-20 also would have similar or perhaps a slightly tighter beam than the XP-L HI, and lower output. The LH351D, should the last reported plan change and that emitter be offered, will have a floody beam best for close-up use, and have output nearly as high as the XP-L HI.
Both will likely have a slight greenish-tint at lower power levels that may or may not bother you - different people care different amounts about this - where as the XP-L HI should have a very neutral or perhaps even slightly rosy appearance.
Looking at all these last minute changes, I guess I’ll just hope we get some good emitters.
And I think I’ll be getting the ol’ lathe set up if logos on the button and up the only option. Last time I did a group buy was the 348 and thankfully they sold it with or without markings.
Put me down for one!
please add me to the list, i want one. thanks
Three posts and looking at your second group buy. You’re all action.
ill just be happy to see this come to life…flashlight people designing flashlights
Oh I mostly lurk. I’m not the most active I know… But hey plenty of people sign up just for group buys right?
A group buy is what got me to join. I was also a lurker (active elsewhere, but avoiding BLF because I didn’t need more temptation to buy lights) until the Sofirn C01 started to take shape.
And then once I signed up for the C01, I very shortly afterwards gave in and signed up for the FW3A, too.
I’m hoping to swap some sw45k’s into one of my FW3A’s. When the time comes, how would I go about disabling the FET in firmware? Am I correct that this would require a coding change and then recompiling?
This has come up a few times, so I’ll probably make a config specifically for it. I just need to remember to actually do it…
That would be much appreciated!
