Requesting for code.
What emitter you got ,is the bezel glue ? Some beam shot pls.
code please
interested
I’m interested depending on the price. If this is still going, that is
Hi, code please?
Okay. [quote=zeremefico] Hi, code please? [/quote]
Interested
Ordered today
freeme, You might want to have them change the dimension that they have listed under the specifications it is listed as 36mm and I believe it is 63mm
For the head diameter
Hey Freeme!
Please send me the code for this light!
Is there any info (either from the manufacturer, or approximate ratings from 3rd-party reviews) for each of the LED type of the AmuTorch TC500?
That is, I’d like to know the max lumens and the approximate throw distance numbers for the 4 LED types:
Luminus SST40 CW
Philips Luxeon V NW
XP-L HI CW
XP-L HI NW
I’m in for one
Yes, there seems to be something strange with the TC 500 (SST 40).
My TC 500 has the same behavioral, low, mid, high (102700LUX > 1m), double click > strobe, nothing more, nothing less.
5 modes :question:
Battery LiitoKala 21700 Lii-40A fully charged.
Does anyone know what can be going on there?
I got mine from BG.
For all of you why are wonder what happens here a UI has changed and it is low, mid, high and double click for strobo.
Springs are super quality as a reflector is also.
Problem is that driver is glued
I got an Philips Luxeon V NW which is a little bigger than XP-L V3 HI as you can see.
Measurements for this led are :
High - 1455 lumens
Med - 334 lumens
Low - 41 lumen
Tailcap current is 5.12 A.
I’m not satisfied with the throw, if you want throw avoid a Luxeon V version.
It is better that I got Luminus SST40 CW then then dedome it or order dedomed version and just swap.
As I can see here is no chance to reflow an Luminus SST40 CW since led’s are with different dimensions, Luxeon V is smaller. If anyone know if this can be reflowed plase tell.
it probably will not work, even if it did somehow it wouldn’t be a great idea on a high power FET light
Why not, I’m pretty sure they use same driver for Luxeon V and SST40 just different led foothill ( differen dimensions solder place for led’s ).
Maybe I didn’t understand. I thought you were going to try to reflow the SST40 on the same board as the Luxeon V. If you are going to replace the whole MCPCB then it will be fine.
I just ask if someone know it is possible and try and it works great, if not then
There is no problem to find 16 or 20mm MCPCB’s with this led’s but for this light it is huge don’t know where to find it…
