The ANSI lumen figures are certainly not very useful for comparing these two flashlights, both of which are not designed to operated at turbo for very long…. It’s really a silly technicality to point out… And it’s really a useless metric because you could design a flashlight that sustains a brightness level long enough to get a higher rating but immediately has to severely step down right after 30 seconds…
Also I don’t know much about how the thermal step down works but if you started on say 8k lumens on the d18 would it even get a lower ANSI lumen figure than the m43? Is that a stupid question?
My old M43 had issue in that place. After washing it stopped to turn on(it shows power warnig indication) at turbo with fully charged new hidrain 18650. Than I had disassemble it and had seen oxidation between copper board and host. After cleaning it works fine.
The ground from the aluminum host is made by the screws securing the copper board, and these screw holes are gold plated. So there is no ground through an aluminum to copper contact. The copper is clad in masking and the contacts are, you guessed it, gold plated.
(brass ground screws can up the ante a bit on current draw, just saying)
Thanks for clarifying, but it does not change the essence. This place can have a fairly high resistance due to corrosion. At least in the first batches of M43 it was so. Now the quality of metal working of Henk’s flashlights greatly improved. Maybe something has changed.
None of my batteries fit... lol.. You really need a high positive nipple otherwise it doesnt make contact.. I'm not a fan of doing it this way! But I guess that is the only cheap solution to reverse polarity protection?
I will have one of these but it may take a while for me since my wife continuously gripes about me buying lights. May have to go a month without a purchase just so it doesn’t seem so bad to her. She doesn’t understand.
I don’t have many unprotected button-top cells, so I did the same thing I usually do when I need something like that… solder-blob the top of flat-top cells.
To make button tops usually I cut up some copper sheet into a tiny disk and solder that on top with solder paste. I leave the iron on just long enough for the paste to melt.
I find that copper wears better than bare solder when its rubbing against springs and other parts of a battery compartment.
I don’t think he means solder the giant brass ring. That’s too big for most soldering irons. Plus it would need to be filed flat afterwards (I assume) and that requires even more unnecessary work.
Perhaps it’s best to remove the plastic(?) rings and sand them down just a little. It sounds like they may be a bit too tall.
My will have this mix:
XP-L HI 3A 6 pieces
XP-L HI 5D 3 pieces
XP-L HI 1A 1 piece
Nichia 219CT 4 pieces
XP-G2 S4 3D 4 pieces
I would like to achieve the color of 4800K and Duv zero or slightly under BBL.
I wonder how many lumens it will generate. I invented such a system:
