The 219B is rated at 1.5A, compared to 1.8A for the 219C, so nominally they don’t look much different, especially since the newer V1 219b’s have similar voltage curves to the 219C. However, the 219C is already known to be working very hard on the D4, so the concern is increased when the current your battery can supply is shared between one less emitter, and that emitter has even a slightly lower current capacity.
So dialing back the current for a 219B mod is very likely prudent.
A benefit to modifying the firmware rather than just setting the ramp at a safe level is you retain the short-cut to the firmware max level. Shortcuts are a great feature of firmwares like Anduril.
A firmware modified for the 219B might also be well-suited for the E21A, and Clemence is planning an E21A triple board. However, Carclo says the 219B should have more throw in the 10511 optic than an E21A.
I have no idea. I’ve been trying to get confirmation on a variety of extras… but most of those questions just disappear into the void. In particular, I’m hoping there will be a diffuser cap made to fit it, to allow it to work as a candle or lantern. But I get the impression this sort of question won’t even be acknowledged until after the light itself is in production.
Could someone here do me a favor? Please remind Neal that I still don’t have the two GT Micro’s I paid $90 for and the Fireflies E07 he sent instead is still sitting here waiting for his response from a month ago.
Thank you.
I’m planning to mod one with Nichia 219B sw40 as well, so I’m also following closely on the discussion about disabling the fet. Can it just be a setting instead of hard coded into the firmware?
219B sw40 can handle the turbo on my FW3A just fine when using a somewhat used Sanyo GA. The tint is much less pink in relation to other modes than with some other 219B lights on turbo, such as E07 and ROT66 with more potent batteries.
