If I recall correctly, the old 219B emitters may have had higher Vf than the more recent ones, so the more recent ones are more prone to turning into smoke.
But mostly, I think it’s just because people are more concerned with general safety now, after reports of some Fireflies lights damaging their 219B emitters.
So… I’ll just make a 219 build for the FW3A firmware. It could either have the FET turned off entirely (max output of ~800 lm), or it could have the FET levels decreased to like 25% or 33% or 50%. Not sure which would be better.
Nice! I’ve got a 219B triple board waiting for my FW3A.
I’ve been tempting fate with 219B emitters in a D4. I have the ramp ceiling turned way down and mostly use it on lower levels, but I’ve run it on turbo for a few seconds a handful of times. :partying_face:
Will the FET % be a compile option, or something you determine during testing? BTW, I’ll gladly send you a 219B sw45k R9080 triple board if you need/want one for your FW3A.
I would really like it if the ramp has an indication of when it goes from regulated to hybrid modes like the Emisar D4 standard UI. Or if there’s a pre-defined percentage indication in a leaflet that allows one to adjust the ramp ceiling to max regulated current, leaving turbo for full FET.
The FET percent is generally just a hardcoded thing. I’m just not sure yet what percent it should be. I’ll probably put in a few options which can be selected at compile time, and make the default build something relatively safe. I definitely can’t turn down a 219B triple board though; those are hard to get these days.
It’s too late to change the firmware now, but fortunately that function is already included. It has a brief blip in the ramp when it changes power channels.
About the actual ramp shape, those values are in the config file. They’re also in the user manual.
Can I call dibs on one more (total of 3) but only with samsung emitters (if they show up eventually)? Would it still be as part of the group buy?
Also, I’d really like to have an option to have the bunny on the switch
