I’d say the VAST majority of lights I’ve seen anyone own use mechanical switches or buttons, so any ramping that would require an e-switch is out simply because of that.
If we really want to talk about muggle lights a simple 2-mode low/high UI is really the way to go. Anything else is a solution looking for a problem.
This is not standardization, it is uniformization.
What are we going to do with manufacturers and users not following the Great Standardization, send them to reeducation camps ?
And people trying to innovate, will they be considered deviants ?
Please keep in mind that not all people have the same preferences, needs and way of using things.
The lights with mechanical switches should only have 2 modes, hi and low.
But the switch should only switch between 1 mode and off when using it normally.
The 2nd mode can be activated quickly by pushing forward the button like on the Fenix. Then the light remembers the selected mode for normal switching
Just because people think they need something doesn’t mean they do. Most people believe they need a 4K TV or phone but in reality anything over 720p is an overkill. Just wasted energy for no benefit.
Why would you need 1000s of levels when you just need 3.
Why would you need 820 lumens when 800 makes no differences ?
N.B.: Actually, there is no ramping UI with 1000s of levels.
I wouldn’t go that way!! I guess that even if ramping can give us those “levels” or more, having preset established levels is a way to be sure of what we will have when we do the next press on the switch! For people that don’t use ramping, that is a major thing. You will have level X and then Y and that’s what you expect (or need)
Also, and again, we will all have different UI preferences. So I believe we won’t need to get too rational or too emotional :innocent:
EDIT: There is no “One Ring to Rule them ALL” in what concerns to flashlights! :face_with_monocle:
How do you know that nobody uses it? Just because you don’t, it doesn’t mean nobody does.
I use lock-out on my Nitecore Tip every time I travel with it to prevent accidental turn-on in the bag.
I think you are barking up a wrong tree. The whole beauty of BLF community and the manufacturers that tailor to it is the variety that it offers. We all like different things, and having different UIs and flashlights gives us options.
I guess even with a control ring people would still need/want different things as UI, either it was preset levels, rampings, stepless dimming or anything else
But, for sure, a control ring is a good way to please many people. (While another amount would still dislike )
Finding a particular output quickly is a pain. EVERY ramping UI I have used is either too fast to get exactly the ouput I want, or too slow to do so with.
I just want to point out this is absolutely untrue, at the average distance from a monitor or TV, with their average size the human eye can see WAY more detail than is even offerred by 4K. And what about photo/video editing? Surely those professionals have no idea what improves their product.
