Goggle “circle packing”. 3 circles in a larger one has a lower “packing density” than 4 circles in the same-sized larger one (65% vs 69%. respectively). So 3×21700s would just about fit the same size can as 4×18650. Okay, so 4000mAH for 21700s (12AH total), vs 3000mAH for a decent 18650 (umm, also 12AH total). It’s a wash at best.
Lots easier to find 4 18650s than 3 21700s, and I’m not even sure if the latter comes in buttontops.
Having more lumens is great, but not if they don’t go where you want them to. Any increase in emitter size or number will lead to a floodier beam, unless the reflectors are made proportionally larger too.
I don’t see the benefit unless you want more floody lighting (there are options for that already) or bigger numbers on the spec sheet just to have them.
Any successor to the Q8 needs to be have practical improvements on the positive qualities the current model has IMO.
Wellp, you already got the MT09Rs out there. 35s for throw, 70s for flood, both versions painfully bright, and not terribly bigger’n the Q8.
If 5k lemons isn’t bright enough from a sody-can light…
At least the Q8 keeps the cells in parallel, not series. So no need for balancing, BMS, at the very least protected cells, and all other rot which just complicates things.
And what’s nice about the DC7 I mentioned is the ability to charge the cells in situ.
I realize that some are seeking advancement as its own end. Others are looking to meet specific purposes. Both are interesting and useful parts of this hobby. My interest in the post is application specific.
The Q8 achieves a sort of ideal compromise for one of my primary use cases. Hiking and walking in areas that can be creepy in the dark. One of my single 18650 lights is more than enough for basic navigation. The Q8 adds an additional, sustainable output level that adds a visual security blanket that puts me at ease. It’s big enough to sustain high output. It’s small enough to fit in my coat. It’s throwy enough to see as far as I need. It’s floody enough. It provides big runtime but I find it comfortable to hold for long periods of time. Its neutral tint probably appeals to a broad audience that strikes a middle ground. I’d prefer 5D tint but that’s almost splitting hairs. Almost any deviation seems to be to a bigger detriment. The Sofirn SP36 is a smaller version of these attributes with the associated compromises. I find the Q8 just right.
More output is always fun. I simply don’t need that to fulfill my needs and I have little interest in impressing anyone. Q8 is my outdoor grail light.
My Q8 with 4 of the 3V XHP-50.2’s and 4 brand new Molicel 26P 18650’s just showed me 15,000 lumens on my calibrated light box. Of course, that’s a start value and the numbers fall pretty fast from there, but the hot spot is decent, can be made better by slicing and dicing, so yeah, there it is, why not…
Perhaps someone should be trying to talk Sofirn back into those parallel extension tubes…
I travel for a living and the original BLF Q8 is a permanent fixture in bottom of my bag. Not only is it a great light, but if needed I always have several “spare” 18650s available.
I wonder if it is possible to develop a USB charger retrofit.
I have ZERO circuit design knowledge, but what about a tail pcb replacement that contained a charging circuit… unscrew tailcap to access.
It was the first wow light I looked at because of the USB charging. It’s great for a car because of the ability to recharge BUT, I decided on smaller and redundancy.
Check out the SP36…even more light then the Q8 but smaller, therefore peak will be shorter.
Started a timer upon initiating Turbo, Anduril kept the light under 111º even at up to 2 minutes, I double clicked into Turbo after checking a 2700 lumen reading at that point and the light did go to 120º at 2:34. So Anduril pretty seamlessly manages the output to control the heat, I didn’t notice it stepping down but was watching the heat on my Turnigy gun with the light tail standing pointing at the ceiling. This gave my Turnigy gun a clear shot at the head. I’ll recharge the cells and check to see the timing on step down while reading lumens in the box.
Here’s my thinking….in an emergency walk around, you want max lighting to act both as a light source and a perp blinder. 3-4 minutes does it. Then a step down to what it can on a continuous basis.
Is 120F holdable? I think it is.
Can you do that and give us the numbers? It will go a long way to the next gen justification.
