Is it time for the next generation Q8?
“’If you like your holly grail, you’ll be able to keep your holly grail”…I think I heard that line before! :confounded:
I fully agree on the size. That is why I’m arguing for the same size but to push the envelop.
…and most the suggested changes to the Q8 will quickly push it close to that price range as well.
Emitter options, different UI, etc. cost little or nothing more vs the current Q8s.
I don’t think it’s worth reinventing the wheel until another round of emitters, batteries or driver tech comes out.
The D18 and MFO1S sound very close to what a lot of people are expressing they want here though.
Wellp, a little over a hunnert murrrrcan here.
Why not?
My Q8 with 4 of the 3V XHP-50.2’s and 4 brand new Molicel 26P 18650’s just showed me 15,000 lumens on my calibrated light box. Of course, that’s a start value and the numbers fall pretty fast from there, but the hot spot is decent, can be made better by slicing and dicing, so yeah, there it is, why not…
Perhaps someone should be trying to talk Sofirn back into those parallel extension tubes…
I’d be thrilled with 3 minutes of full blast controlled by a heat sensor. Then back to earth with maybe 1500 continues.
With X-PLs the Q8 get VERY hot after 3 min of turbo, you’re looking at closer to 30 seconds before an aggressive step down with that kind of wattage.
I’d be good to “hot” but hold-able. 120 degrees? If that buys 3 minutes of massive light, I’m good.
DBCustom….you want to weigh in on this? How long does your mod go before it hits 120.F?
I travel for a living and the original BLF Q8 is a permanent fixture in bottom of my bag. Not only is it a great light, but if needed I always have several “spare” 18650s available.
I wonder if it is possible to develop a USB charger retrofit.
I have ZERO circuit design knowledge, but what about a tail pcb replacement that contained a charging circuit… unscrew tailcap to access.
Again, I know nothing and could be way off base.
SP36
It was the first wow light I looked at because of the USB charging. It’s great for a car because of the ability to recharge BUT, I decided on smaller and redundancy.
Check out the SP36…even more light then the Q8 but smaller, therefore peak will be shorter.
Started a timer upon initiating Turbo, Anduril kept the light under 111º even at up to 2 minutes, I double clicked into Turbo after checking a 2700 lumen reading at that point and the light did go to 120º at 2:34. So Anduril pretty seamlessly manages the output to control the heat, I didn’t notice it stepping down but was watching the heat on my Turnigy gun with the light tail standing pointing at the ceiling. This gave my Turnigy gun a clear shot at the head. I’ll recharge the cells and check to see the timing on step down while reading lumens in the box.
Turbo to usable?
Here’s my thinking….in an emergency walk around, you want max lighting to act both as a light source and a perp blinder. 3-4 minutes does it. Then a step down to what it can on a continuous basis.
Is 120F holdable? I think it is.
Can you do that and give us the numbers? It will go a long way to the next gen justification.
<tap, tap> This thing on?
Airpro DC7.
Fitty bux with 26buk-off coupon… right… now.
I started to make a “charging cap” for my Q8. PVC end cap to screw onto the battery tube and charge all 4 cells at once, but don’t quite know how to cut threads on the inside for it to stick. No lathe or anything fancy. Was thinking press-fit, weighted, etc., but nothing jumped out at me.
It’s in my cart… coupon applied… finger twitching… sweat on brow… MUST… RE… ZIST…
Resistance is futile.
dc7 has a lighted switch only when the flashlight is on?
Yeah, and was wondering if it’s settable like the Q8, but couldn’t find anything in the manual.
I did up a review on Amazon, mentioning that, but it wasn’t “published” yet.
Good thing I waited, as I got an invite in email to be an “early reviewer”! I’m gonna get a 3buk gift card, too!
Now Maw kin git that opurashun…
It’s a small inconvenience. It may be related to the charging function
The DC7 keeps getting mentioned…It a decent light? Wanting to get my first soda can and not sure where to start. Q8, D18, Meteor, DC7? Is there another thread that could help me out?
Just 10000-15000lm for several seconds is already boring. There are many such lights.
Is is interesting to see some new hardware features. Good charger with modern parts. CcT adjusting, active cooling and so on.
