Still, they took it over before they made the changes, then they did whatever they wanted to… in a very familiar fashion. Which is why we now have an orange peel shallow wide reflector…
I like the look of what Sofirn did, obviously… I bought one. But of course I will free to change it to suit me like I always do.
I wasn’t getting at anything, I said they changed the plan and they did. I don’t usually hint around as I myself am no good at reading between the lines.
Sofirn said they were going to make an extension tube for the Q8. I spent over $200 after talking with Tracey about this and I made Ham’r, based on the extension tubes, and the plan was for it to use multiple such tubes. I spoke with Barry as well. And then THEY decided not to make the tubes. I’m into this for $230 and then some based on what THEY said, but… whatever. I still have a cool light but after going to a lot of trouble to do the 458 thing based on 4 quads, 5 drivers, and 8 cells it no longer is going to be possible to have 8 cells, so I pulled the .458 Ham’r brass out of the light. I seriously dislike being made a liar. There, that’s what I’m hinting at. Say one thing do another. Good enough?
To add to that, they did show us 7 extension tubes working together powering a Q8. If they decided not to make them they could at the very least let me in on one of them as we had talked about it all so much and I was personally into the plan to such an extent. But Nooooo! Like, they kept you so well informed through all this, right? Uh, huh. Not.
Actually, the factory prepared the material for the extension tubes. Sofirn already spent thousands dollars on the tubes, we want it to be fulfilled as you do. But factory has no time to make them so far. We don’t wanna give an easy promise.
furthermore, even though we showed in the video that the tubes work with BLF Q8 and Sofirn Q8, we still worry about the compatibility.
You know, the threads changed a bit during all those batches.
Max Power (W) 29 W
Max Light Output (lm) 4292 lm
Maximum Efficacy at Binning Conditions (lm/W) 181 lm/W
Do I read it wrongly? I am excited for SP70. It is brighter than the cree parameters announced
Yeah. It’s a FET driver and with high drains cells it should pull some pretty good amps. Sofirn was never able to tell me how many, though. Maybe it will be the 18A-19A I get with my Lexel driver L6, but I’d rather be conservative until I can measure it myself.
My HD batteries were sent back by customs apparently so Sofirn have sent out some more today. My SP70 should arrive this morning according to Royal Mail.
Just received mine,build quality seems ok,threads smooth and lubed,reflector OP similar to L6,anodising shiny black,not sure about UI yet,ceiling bounce a fair bit brighter than L6,will check out later when fully dark.
For anyone interested, I have published the approved manual for Sofirn's SP70 on my sharepoint, both in English and German language.
Please click ►►►here◄◄◄
