New site advice: https://www.intl-outdoor.com/
None of our sources or any other serious source in China has anything U3 nor has had so far.
Thanks a lot. Buying from you will be more enjoyable experience.
I love intl-outdoor. :love:
Osram white flat CSLNM1.TG LED in stock
Thnx! Ordered.
Nice!
Wow!! This is impressive... First time we are seeing V4's in HI's that were legit, and neutral no less. Been listed on Ali, but were fake listings.
It may be above the BBL, but I think in that flux bin you take what you can get.
I purchased 7 of the CREE XP-L HI V4 3C. Just swapped one in my Convoy C8 driven at 3.8 Amps. These seem like the real deal. Very nice neutral white tint. Also seems to produce noticeably more light at lower amperage compared to a CREE XP-L HI V3 3C.
I would like to introduce our new site: http://m.intl-outdoor.com/
Currently, the site is still under working, but you should have no problem to place the order
on the new site, the price is the same as the old site.
There might be some small errors, and you are more than welcome to
give us any advice to correct the problems. Once the new site is fine, we will use it to replace the old site, thanks.
New site looks way better!
Looks good Hank. :+1:
No flashing kits ….
Okay, some notes:
1) Not all items showing - eg. D1S not appearing.
2) Resize down http://m.intl-outdoor.com/media/wysiwyg/slideshow/d18n.jpg - it’s currently 664kb; resize it to the same width of the image of the D4V2 in the scroller (http://m.intl-outdoor.com/media/wysiwyg/slideshow/2483.jpg) which is 153kb, around 23% of the size. More of a way to make the site load faster and reduce your data transfer.
3) Currency cookie! Please drastically extend the length of time this stays. Currently only valid for 1 hour; for those of us not using USD, this is a bit of a pain to have to change every time we visit the site. 7 days, maybe? Longer?
4) The “New Product Added” section - maybe make that to only show products added in the last 2-3 months, at the longest. Newest items first.
5) Could maybe compress some items; an example would be the XPL HI section, instead of having 9 options currently (each of the three CCTs either bare, 16mm, 20mm MCPCB) it could be three - Bare Emitter, 16mm MCPCB, 20mm MCPCB - and inside there, choose your temperature option. Same could be said for the Osram Flat White - only needs one item instead of three, but with options inside of the item.
That one is up to your own style, though - If you prefer to have one item per exact option, that makes sense. I’m just looking at it from a user-experience standpoint.
And my last wish-list item - I’d love to see more spare parts for your light up, eg. replacement glass, buttons, driver boards, etc for the D4/D4V2/D1 etc etc. Time cost of putting them up on the store might be very minimal, but would save time for both yourself and customers by not having to email to ask for custom parts.
Hello Hank,
my browser reports that this is not a secure connection, it is attackable.
Regards
Daniel
Now it works, seems to have done!
  1. The D1S stock is low, that is why we did not add it to the new site, there will be D1SV2 in the near future.
  2. Will fix it.
  3. Will look into it, and fix it.
  4. Yes, we are still working on it.
  5. Nice suggestion, will follow it.
  6. Yes, we will consider it.
It is now “http://”, we will use the “http://s” tomorrow, then it will be secure.
Just add it.
Hello Hank,
it is currently not possible to log in, is that correct?
