That I wouldn’t know :zipper_mouth_face: I believe that it will more or less the same than from US to Europe, maybe 13€-15€/$15-$20. But only the store can tell you that, honestly !
Does it really take 2 seconds (long press) to turn it off? That’s what I’ve read in one review. If so, that would be a huge annoyance to me personally.
I vote for the Wuben also. The one I have (after I put on the DC- Fix) is a great little light. Use it in the warehouse daily and on early morning or late evening walks. Plenty bright on the middle two settings and the turbo is nice when you need it. I just charge it every week whether it needs it or not.
I think I would like the UI better on that TLF edition better (probably the tint and CRI also) but it’s too expensive to get it here in the USA. As it is, I got the standard version for 1/2 off, which is great since it comes with a 14500 battery!
The other puzzling thing that I asked about and never got an answer is runtimes on alkaline vs NiMH. According to Wuben, runtimes on alkalines are twice as long as on NiMH. I find that strange.
NiMh runtime may be due to low-voltage cutoff. If the cutoff voltage is too high, the NiMh won't be using nearly its full capacity. This is a hidden problem with NiMh in many devices.
I can put a fresh charge on a NiMh and put it through a run time test. Do you want all modes or just one or two in particular? I don’t buy Alky’s anymore but I wouldn’t mind seeing about the NiMh.
A follow-up on the NiMh vs Alkaline thing, just as an example Olight rates a longer runtime for NiMh on the i3E. Very interested in the test outcome now, lol.
