I hope that they can find a reflector with tighter hotspot and or less spill. If not i would also be happy with the old one (with 7mm led hole instead of the 9,5 from the old one). But reflector testing is further down the road.
From now on i will update new drawings. . . in the first post. This way it is not necessary to read throu all the pages.
I just used mine last night, and Dale is right, “theatre beam” is a perfect description. I actually also love it, and hope that part doesn’t change. It has a lot of throw outside at night, but the hotspot is much larger than other small, throwy lights. Very useful.
Correct me if i am wrong! But with a different curve in the reflector you will get a different beam shape or not?
I think thats what they want to test.
By tha way i updated the internal structure of the head. The stepped design is not happening. Because of the small space between reflector and head they would have to make many small stepps. It seems it is easier to fabricate this form. But we got the bigger mass un the inside + deeper finns and one more. Not a lot but without changing the appearance this is the best we could do.
I hope you like it. And the Tailcap gets a new end. What do you think about it?
I dropped a 3V XHP50.2 in my D80, with a Sofirn FET driver that I had laying around.
The FET might not be the best one, only pulls 9A from a 30Q but it does produce some photons !
The beam is nice, fat hotspot, well defined and some usable spill.
Pictures later
If everything goes like planned i will get beam pics from the reflector test next week.
And they will make some short video clips from the machining process when they start with production.
Can not wait to see how the D80 emerge from a piece of aluminium.
I need your help guys.
I was asked which CCT we would like to see. They want to offer 2 CCTs. The LED will be a XP-L Hi. Let me know which CCT you prefer in a new D80.
I like the LH351D a lot. But for a thrower like the D80 the XP-L-Hi seems the better option.
And correct me if i am wrong but could it be a problem running only one LH351D on a FET driver with big good springs. . . ?
It is a comercial sold light. So a burned out led would be a problem.
The D80 is more of a general purpose light than it is a thrower, even with the HI it’s not really a thrower. The LH351D should handle any cell that the light can accept, even with bypasses on the springs.
I like the beam profile an XM-L2 gives in the D80 reflector so that will likely be my choice, if I find I have another SBT-70 I may well use it here…
I wasn’t around for the original BLF-D80 development, but over the years it has been mentioned and recommended quite a few times in other unrelated threads. Now that this updated version is in the works, I definitely need at least one.
I talked to LuckySun and they looked into the LH351D. Untill now they did not find a source (that can deliver the needed quantitys / within a reasonble price).
And they are still waiting for the new batch of reflectors. The first batch they tested did not deliver the desired beam.
But they are testing out the driver. For now i have not heard anything bad about it. And i did not expect problems from this side (maybe that they think it is to expensive in comparsion to the drivers they used to use). But with a strong comunity behind it, they can see the advantages of it.
Mine now rocks an SST40 and a BLF FET driver.
8A and 2170 lumens.
It would be a good upgrade of the original design IMO.
The beam is really neat, the hotspot is the same as with the original XM-L2, but with double the lumens !
