Efest IMR26650 5000mAh (Purple) 2017
Official specifications:
Rated capacity: 5000mAh
Nominal voltage: 3.7V
Voltage at end of discharging: 2.5V
Max. charging current: 4A
Standard charge: 2A
Discharging current 35A This text is beside a photo of the cell showing 18A on Efest website
Pulse discharging current: 50A This text is beside a photo of the cell showing 45A on Efest website
Charging temperature range: 0°C ~ 45°C
Discharging temperature range: –20°C ~ 75°C
Inner resistance: 20mOhm
Cell size: 26.5 (±0.2)mm x 65.2 (±0.2)mm
A high current 26650 cell with good capacity.
There is some capacity difference between the cells. They handle up to about 20A without much capacity loss.
At 20A they get hot.
And at 30A I had to termiate the discharge due to temperature.
Conclusion
This cell has good performance at higher currents and a fairly high capacity.
Notes and links
The batteries was supplied by Efest for review.
Compare to 18650 and other batteries
