That should not be the case. A bigger reflector with the same size emitter means a slightly smaller hot spot. Maybe you are referring to the corona? If your looking at it through a camera you have to use very low output levels to see the true hot spot size.
EDIT, are you comparing it to the new L6 that has the SMO reflector? That model might have a slightly smaller hotspot.
Definitely a larger hotspot,tried it on internal wall at 2 meters ,external wall at 10 meters and at bush across the park approx 150 meters.A rough guess about 20% larger.Sorry can’t post pics as I don’t use hosting sites.
Edit, old L6 unmodded with OP reflector.
I’m not sure about that. A noticably bigger hot spot would mean much lower throw numbers, but our throw numbers are still high. I guess we’ll find out later.
You have a high powered L6 with an SMO reflector, right?
You know it can only hit about 172kcd, right?
Why would you expect 300kcd by going from a 63mm SMO reflector to a 73mm(?) OP reflector? I would not expect that big of a jump. Am I not understanding how significant a small bump in reflector diameter can be?
If the hot spot was visably larger than an L6 like gehrmo said (20%) it would indicate a much wider beam angle. You would then expect probably under 100kcd. Maybe under 60kcd. We are not seeing those crazy low numbers.
We are not seeing perfectly optimized numbers either because we know the reflector depth as a bit short for the diameter.
I would much rather wait till I can compare the lights side by side and take measurements. I prefer that to speculating.
Plenty of speculation in that post Jason for someone that prefers not to speculate.
Good that you tell me what I know, because I’m so forgetful and all. I do remember that I have smooth, OP, and Optic Convoy lights, boosted 35’s to 4 cell 35’s, MT-G2’s to 70.2’s. Do I need to put a White Flat in an L6 and see what the reflector is actually capable of? Nobody said this light had to have an XHP-70 variant in it… my little L2’s can sure blow away what this Sofirn light does, I know that.
As I’ve said, I paid for a Sofirn SP70 and it’s on the way, the speculation will soon end.
Conducted an experiment. Cut the emitter shelf in an L6 to fit a 32mm MaxToch MCPCB, cut a copper heat sink to solder one of RMM’s 20mm drivers into to run a White Flat at 5.5A from 2 cells. In the L6, tested with OP reflector and clear polished reflector, the OP did 69Kcd, the mirror did 335Kcd. I know, I couldn’t believe it myself, ran the tests multiple times, but there it is.
