I spotted that tip about using wax paper and resting metal on the top so that the magnet sets flush to the end ā thatās a really good idea. Wish Iād seen it earlier. Mine sits maybe 0.25 mm below the surface, but the magnet still holds pretty strongly. Itāll only work with it on raw exposed metal (painted will work, but it slips) and it will naturally pivot to put the magnet at 12 oāclock.
The magnets feel very strong, and theyāre difficult to separate. So Iām convinced theyāre decent quality.
I tried to dissolve the super glue with acetone, but itās not getting in behind the magnetā¦ so it wonāt come out. I expect Iād have to drill into it to break it, then pull the pieces out.
Thanks. I donāt know how much stronger theyāll be compared to the ones I already have. Can you adhere the light to metal with the magnet positioned at 6 oāclock?
Sofirn just posted a message on Facebook that the final 30 lights of the Original C01 (color red, 5600K) will be sold on Amazon.com for 6.50 USD.
ā> Link
If the magnet wasnāt a tight fit thereās no need to drill it, just heat the tube upā¦ Cyanoacrylate releases/breaks down/softens/whatever at higher temperatures.
Depending on the grade itās strength retention drops to 50% somewhere in the neighbourhood of 80-120*C. Couple hundred degrees celsius should drop it well below 20%. Sure thereās High Temp grades out there as well but I highly doubt you used such a glue.
Djozz, thanks for the pointer.
That bare aluminum look :heart_eyes:
I am going to dress up at least one 5mm-C01 head with a bare aluminum SST20-C01-BLF body :sunglasses:
Also great Sofirn adds a BLF marking to give credit to the origin of the design.
You could carefully (gloves, eye protection, outdoorsā¦) give your C01 a bath in lye (drain cleaner / sodium hydroxide / etc) to strip off the anodizing for a bare-aluminum finish. Just apply some petroleum jelly or something to any areas where you donāt want it intruding (threads, in the reflector area, etc) and then just clean it off after the bath.
It sounds like a good idea. However, a single mode twisty seems less practical for a larger light. Another ui may not differentiate itself. Unsure how this would be implemented.
The stock UI of this light is already perfect its just the stock LED that can be greatly improve with a Luminus SST-20 95CRI and maybe a new unique color as a bonus?
I think Omega_17 is suggesting a BLF-edition SP10 V2, not a AA version of the C01.
That could be a high CRI emitter, and possibly a different firmware. Unfortunately, Narsil or Anduril would probably require a different driver, which is more work for Sofirn, and would likely mean 14500 batteries only - no AA support.
I was going to get another, but the Jetbeam U is only $2 moreā¦ beautiful finish, anodizing, and I like the multi-mode. But Iām glad to have one C01.
Love my c01 lights, though I wish the beam was a bit narrower. Super excited about the c01s. Have one so far but holding out on more until if/when they release a L-H mode order.
I bought one for $9, and a 2nd one for $10. Usually thereās a coupon floating around. For one I used a $4 off AliExpress coupon. The other was on sale.
