I just got this light from FT and it says it has 12-group 55-modes, I read on another site you hit the switch 8 times to change modes. I am not having any luck. Any ideas? Thank you
Try using the methods on this chart, the X-PL HI versions of the M2 should have Biscotti AFAIK:
I finally got it, thank you
8 isn’t enough, just keep going til the light stops responding (i just counted 10 as the diagram shows), it’ll then flash once followed by a burst of crazy strobe, then flash twice followed again by a crazy strobe.
If you click during the first crazy strobe you’ll toggle mode memory and the light come out of programming mode.
If you click during the second crazy strobe you’ll enter the menu to choose between the 12 sets of modes.
Edit:- Cross-posted, cool you got it sorted
Well I thought I had it, I went to use it today and it had all 8 modes, so I started to program it and it’s stuck in low mode and will not do anything else….
