I'm sure someone could explain it, but would love to hear from Enderman on it, or maybe djozz has a good explanation. The white flats are highly throwy of course, but maybe has something to do with the low lumens output, too many lost photons.
Just got home, and sure enough - got the SP70! Looks great, big springs of course, probably to allow 26650's to 21700's. For 2 cells, it's a big length to adjust for. I am suspecting, Dale you are right bout the reflector's shape, leading to less throw, bigger hot spot. I got an L6 (or 2) and an old S70S to compare.
Update - First Impressions:
Yep, I'd have to agree about the relative large hot spot - seems about the same as my L6 OP w/XHP70 and old S70S OP w/XHP70. Hard to say but the OP treatment is roughly bout the same as an L6, maybe worse. The center flat area is OP's while on the L6's with OP reflectors, it's SMO. It's unexpected to see such a large hit spot for such a wide reflector I.D. The spill is clearly wider than the L6 and S70S - also expected for a shallow reflector.
Hard to tell for sure but looks like the LED sits fairly deep down so maybe there's some improvement to be made there. The glass looks untreated, but they didn't claim it was AR coated.
The reflector ID looks bout the same as the HL MT07, but I'm sure my MT07 blows this SP70 away with it's SMO/deep reflector, sliced&diced XHP70.2, and tweaked driver.
Tom, do you think the SP70 beam profile is an excellent GP light? I got the feeling from the parameters that it would be, just a great all around light to have out on a walk or doing night work like clearing a storm felled tree or something like that. I could be wrong, happens more than the other way around.
The L6 came out with an XHP-70 though, so the OP is designed to merge that donut hole. Perfectly understandable there. The 70.2 works much better in a mirror finish reflector than the 70 does, so the differences come through modernization of the emitter.
And yes, I can see where an orange peel surface would just kill the 821 lumens of this White Flat. Nature of the beast and all that.
Been a while since I fiddled with these big single XHP70/XHP70.2 lights. Didn't even realize the MT07 now has an HQ driver in it, does like 368 kcd with the sliced XHP70, think it's not a 70.2, not sure yet.
Yes - it has a wide spill, not a great thrower but wouldn't expect it to be. Nice though it's high amps. I was able to open the bezel, no glue but needed a strap wrench with some decent force (wood clamped the head). The MCPCB is hugh, looks like 40 mm, and i was able to poke thru a LED wire hole and loosen the driver - probably mildly glued, not sure because couldn't remove it without de-soldering the wires. Got charged up blue LK 50A cells now so will take some numbers.
UI is ok - didn't try ramping yet, but modes work the nice way - click to ON, click OFF, press&hold to change modes.
It really depends on the cell. Flat tops that make contact in series should work as long as they aren’t button top. Clearance is tight and they fully compress the springs, so officially they aren’t recommended. It’s a case by case situation.
I really don’t understand why you say stuff like this. I’m saying “Huh?” to every sentence.
So like 100kcd to 134kcd and 200kcd to 268kcd? This sounds quite reasonable.
Since my L6 does 172kcd, if the SP70 had a SMO it could theoretically be capable of 230kcd.
I think Dale’s expectations were a 75% increase which seems too much in my opinion. Plus it seems Sofirn used a heavier OP than they said they would, based on the reports coming in. This is a bummer, they said they were going with a very light OP.
So you think the hot spot is about the same as the OP L6 and not 20% bigger? The same size is better than bigger, but in theory it should be a bit smaller. It can be really hard to determine hot spot size with OP reflectors.
Tom, I think you have a lux meter, can you measure the candela?
About the white Flat in the SMO/OP L6 reflector: I have done a few initial experiments a few years ago that show that throw difference between a SMO reflector and a OP reflector is highly dependent on the size of the die: you tested it with smallest die possible, while Sofirn tested it with about the largest die possible.
See the few tests that I did in my (unfinished/abandoned) reflector thread: Ongoing project: reflector testing
Right djozz, I tested the L6 with the small die intentionally to see what kind of throw the L6 may be capable of. I know when this 70 remake started it was supposed to target throw and power, a hot rodded factory light for the BLF demanding. But then things stalled and Sofirn took up the gauntlet and the ideaology changed along the way somewhere. I am probably closer to the original project because I have assisted the modding of the original prototype. Still, Sofirn made some body design changes that I liked even if the reflector wasn’t where I thought the whole plan was targeted to be. Compromises I guess.
It’s looking a lot like the entire project has been a long way around towards building a different L6.
The “25A” 26650s I ordered arrived. I’m very skeptical of the “25A” rating. IRs seem really high. Mine are between 0.15ohm and 0.25ohm. 0.25ohm seems VERY high for a “high drain” cell.
11.9A on the cyan Liitokala is not bad. We know the 70.2 has the potential for more. Maybe the FET or the wires are a bit too high resistance?
194 kcd is more than Sofirn’s measured 160kcd with light OP. If the texture is heavy, then the candela is even more impressive as they only measured 127kcd. Nice.
The texture does look pretty heavy.
You got 195kcd out of your black L6? Hmm, I can’t remember if I got the same, but decided to sacrifice a little in order to get a nicer-looking hotspot. My notes are showing 172kcd. Still close, though. I always go by what looks best as opposed to outright throw numbers.
Just tried a pair of GOLISI 4300's, solder blob'ed one. Got 14.5 amps, think about 205 kcd, same relative bump in lumens. The LED wires look decent, think about 18 AWG, but the double springs might have some loss's compared to bypasses I would use. Got slightly more amps on a pair of 25S charged to 4.21V - about 15 amps, but they would probably drop fast.
