Interested in the 14500, thanks!
Thanks for the giveaway!
I am interested in 14500.
Thank you for the GAW. I have no Vapcell’s right no.
Therefore I would very much like to try out a pair of 18350.
I use Vapcell 1000mAh 14500 battery as my go to 14500 battery, they are really the best. I’m still looking forward to 16340 to arrive, as their specs looks quite promising, much better than anything I can buy/find elsewhere. So, my advice would be keep up the good work and be careful with your suppliers.
I don’t own a 14500 flashlight yet. If I win some 14500 batteries, it will be a good reason to buy another flashlight!
Thanks for the chance to win!
need 18350 cell for a light on the way. Thanks for the promotion.
18350 works for me . Thanks.
I wish they were giving away a pair of 21700 cells!
Really interested in 14500 and 21700 cells. Thank you.
Thanks
A good chance for me to test the quality and durability of your cells.
If I win… I want the 14500 cells.
Many many thanks again!
I've purchased 10 Vapcell 14500 batteries to date and and I like, gift, and recommend them! The average capacity of all 10 cells is 966 mAh as calculated by my LiitoKala Lii-500. FYIW, here are the measurement details.
I also appreciate Vapcell's participation in this forum. Thanks!
Same!
I’m a sucker for short flashlight and don’t have a single 18350 flashlight at the moment. Will probably have to change it soon.
Thanks for a giveaway!
I’d like to try the 18350 cells, so purty. Thanks for the giveaway!
Thanks for the chance in this giveaway.
I’d choose the 14500 because it would give me a reason to buy another small EDC light.
I’ve heard very good things about Vapcell and would like to try them out for myself.
I would really like to try out the 14500 Vapcell 1000mah batteries. Thanks for the giveaway.
Hmm, like CRX, I’d love a Vapcell 10440 next.
The only decent 10440 cell is the Efest 10440 and it is 6 years old already, it has a good high drain but only limited capacity so with some modern battery tech it could improve a lot.
But I know the position of Vapcell too, it will not be a Vape battery, and for flashlight use it will sell less than the Vapcell 16340. But maybe Vapcell can have a look around for a good 10440 cell in China, if there is one readily available it may be worth the effort.
Oops, you are right. Edited my selection. :+1:
Cool GAW.
Actually just ordered some 14500 today
As mentioned above, some 10440 cells would be cool
I don’t have any vapcells (yet).
But here is something I have noticed on pretty much all lithium cells I own:
the wrapper (heat shrink film) falls apart when the cell is used. This sometimes happens after 1 year (panasonic), after 6-12 months (Samsung cells) or rather quickly (*fire cells) and in most cases this happens on the bottom side of the cell.I have a heat gun and can buy new shrink foil/wrappers on fasttech, but is there something that would last longer than 1 year?
I am in for the GAW, if that is possible. Thanks.
Thank you very much for your feedback. For the first time, we have noticed the service life of shrinkable casing short .
Does the cathode shrinkage film crack because of the battery drop?
Or in use, the shrinkage film is damaged
Thanks
message good 16340 battery there
any chance to get that transplanted to a 14500 cell?
You mean 14500 high drain battery ,800mah 7A?Thankls
